So, I think I’m guilty of leaping before looking here, but I bought a BPI-R4 Pro (8gig) off of Amazon thinking it was more ready to go and recently tried to integrate it into my network with the factory firmware (the only firmware it seems is available for it, the 24.10-snapshot). My use has a 1ge WAN and 2.5ge LAN. Trying to use it everything kind of worked, but uplink was a trickle at best and any attempt to push real data toward the WAN resulted in it entirely dropping and errors from all clients that the network wasn’t available. I’m guessing this software branch is unstable?
Sounds like the 1ge/2.5ge options for the WAN combo port are new, wondering if that’s part of the issue? Reading here at the forum several guys have their own branches/ports that might be further along, anyone know what I could look into beside being patient and waiting for updates?
I just tried connecting it up to my normal 2.5ge lan as a subtended router for a test. Connected the combo wan 2.5/10 rj45 port to my existing lan on a 2.5ge switch and a single laptop to the port 1. Same essential result, no kernel messages or errors. Though there are plenty of weird things in the boot log. Attaching boot log here for you and a sample speedtest attempt that fails. Maybe I was sold a bad board? Not sure what I can do, also I don’t understand what you are referring to “ppe”. Forgive me, I’m quite new to a lot of this.
I’ve updated my thread referenced above - in my case routing is not involved as traffic originates / terminates in BPI, iperf3 is run on it.
maybe you could try similar test to rule out routing
Thanks, friend. I’ve seen those issues, so I gave up on WiFi boards. I have routers in access point mode, and I’ll use those, even though it’s a bit inconvenient that the WiFi setup won’t be in one web interface.
That was exactly my plan, just want a powerful router. But unable to work out of the box in the most basic routing job possible is a deal breaker. I should have waited longer, I expect this will be solved via software in 2 to 6 months.
А не может это быть случайно настройка адаптера самого устройства с которого ты проверяешь выход !? Имею в виду если это ноутбук или комп, то есть физическая настройка адаптера ?
Edit (moderated):
Could it be a setting in the adapter of the device you’re testing the output from? I mean, if it’s a laptop or computer, is the adapter physically configured?
Привет, не, там проблема в драйвере скорее всего, автонег криво работает, я уже разобрался как победить, но как решить проблему пока не знаю. Но отписался в этой теме
Edit (moderated):
Hey, no, it’s most likely a driver issue. Autoneg isn’t working properly. I’ve already figured out how to fix it, but I don’t know how to solve it yet. I’ve posted in this thread, though.
Здравствуй. Понимаю о чём речь (косвенно), просто если работает на один поток 2 канала, то есть вход выход то скорость режется на 2, то есть если поток 1000, то должно получится = 900+100 или 500+500. Ведь в документации не описывается эта как “тонкость” потому что это всем известно. так вот я про что ; если так, то причина может быть именно в этом, что то блочит (ограничивает) отдачу потому что на вход смелые 900. А ты не пытался на сайте openWrt задавать вопрос ? Может это просто в прошивке. По простецки в винде это решается настройками самого адаптера, где есть такая возможность тыками решать проблему 100 или 1000, вот о чём я…
Edit (moderated):
Hello. I understand what you’re talking about (indirectly). It’s just that if two channels are working on a single stream, meaning input and output, the speed is halved. So, if the stream is 1000, it should be 900+100 or 500+500. The documentation doesn’t describe this as a “detail” because everyone knows it. So, that’s what I’m getting at. If so, that could be the problem: something is blocking (limiting) the output because the input is a whopping 900. Have you tried asking the question on the OpenWrt website? It might just be a firmware issue. In Windows, this can be easily resolved by adjusting the adapter settings, which allow you to tweak the settings to change between 100 and 1000, that’s what I’m getting at…
Мне кажется, что Вы не читали мои сообщение в ветке по ссылке
Ethernet работает в full-duplex нет коллизий и классического разделения одной общей среды между направлениями, а speedtest измеряет download и upload последовательно, а не одновременно.
Если отключить auto-neg и зафиксировать режим, соответствующий тому, что реально видно в Link partner advertised link modes, проблема исчезает.
При auto-neg линк поднимается как 2.5G, но advertised modes остаются до 1G, из-за этого ломается TX. Это баг драйвера, а не какие-то два канала.
Edit (moderated):
I don’t think you read my post in the linked thread
Ethernet operates in full-duplex mode, there are no collisions or typical sharing of a single shared medium between directions, and speedtest measures download and upload sequentially, not simultaneously.
If you disable auto-neg and lock the mode to match what’s actually shown in Link Partner advertised link modes, the problem disappears. With auto-neg, the link rises to 2.5G, but advertised modes remain at 1G, which breaks the TX. This is a driver bug, not a specific issue with the two channels.
i believe this is the same issue i was talking about in the other thread. when the aeonsemi phy is attached to a non 10gbit port the upload speeds are very bad.
Good to know,but had not find time yet to find difference to the new driver…they added a nearly complete new driver in sdk which has many additional files (mostly for debugging it seems). It was also mentioned in commit message that there are some adjustments regarding speed issues.
