Banana Pi BPI-BE14 Wifi7 Module Heat sink and FAN
This is hair-splitting, faulty also stands for misdesigned/unusable.
The card is useless for a normal usage scenario and even more when you have a multi-AP-setup. And even when applying all tricks to lower the SNR, it does not work well (clients keep being glued to BE14 instead of roaming to better SSIDs).
On the other hand everyone buying this card (this includes myself) knew, that early adopters sometimes get a non-usable product. That’s live. So I myself hope at least for some discount for us early testers, which would be really honorable.
If you buy a new smartphone and the USB cable is missing, then the smartphone is broken too, right? Or if you buy a new car and the ashtrays are full, then the car is broken too, right???
Exactly, some people forget that it’s a developer board. And we’re also among the first to get these new things. It should have been clear to us that not everything would work right away. That’s just the risk. As for the problem with connecting clients to the BE14, I think it could be a software issue. I only have the BE14 as an access point myself, so I probably haven’t noticed it yet. I think we should wait and see what the manufacturer comes up with in the next few days/weeks.
No, your comparison is wrong. A USB-cable is something I could add on my own - the shielding cannot be added (or even if done so by someone experienced does not seem to have the expected effect - have a look into @Betonmischer’s project). If I adopt your comparison it would be some resistor for the USB-interface missing which does restrict data transfer to very low speeds only or something like that.
its a dev board, yeah, but your comparisons are far away from a fair comparison. its like comparing apples with bananas. when the ash tray is full, i empty it. thats a common task. adding some special shielding to a highly sensitive pcb is something far off a regular scenario. whats next, replacing some SMD chips because “its just missing this little resistor”? :smiley:
Its not like “we can buy the shielding and plug it into the pcb and it will auto-fit without any skills”, like your usb-cable comparison…
Hehe, the resistor thing already happened with first version of BPI-R4 board (something regarding NVME if I remember correctly).
I know the argument “it’s a developer board” comes up frequently, but what does that actually mean?
  1. A developer board is a relatively raw platform intended for building your own projects — similar to the former Arduino boards. The hardware itself is already largely stable and free of major bugs when it reaches the market.
  2. A developer board is a work-in-progress product that developers effectively buy into. As a developer, you help the company get the board across the finish line by identifying and debugging issues — in other words, you’re receiving something closer to a beta board, not yet ready for mass production.
I purchased it under the assumption that it was category #1, but it increasingly feels like what’s being sold is actually category #2.
Be14 = there was not only one bad batch with missing epprom data. I buy one in November and it’s faulty to. So I’m limited to frimware with patches that will never go to mainstream openwrt!
The issue is not just shielding, we tried shielding and it done nothing, the issue is in the isolation of the PA as stated by sinovoip
imho
1- If the answer to fixing a problem is replacing a board → then this would imply the board is faulty beyond repair.
2- If the answer to fixing a problem is doing a hardware modification to the board → this would imply the board is faulty, but within the realm of end users fixing it.
3- If the answer to fixing a problem is doing a firmware/software upgrade → this would imply the board could be faulty and software should be deployed to fix it (e.g., an acceptable workaround).
Given the above three;
If #1 → It would be respectable to be able to replace the board under warranty, exchange, or discount. I think we all feel that this will not happen.
If #2 → It would be respectable to replace the board under warranty, get documentation on how to fix it, or send it in to a repair service to fix it. I think we all feel this will not happen.
If #3 → We’ve seen evidence of mtk making software changes almost daily (mtk-openwrt-feeds). I would like to think if the SNR issue was a software issue, this would have been solved a very long time ago. Same with the bad eeprom issue.
My take? Observe the behavior of the manufacturer. If they do not ‘make it right’ by your standards, do not buy from them again. This is an educational moment.
I think exchange/discount/etc in exchange for our feedback, helping diagnose, troubleshoot, provide end user to end user guidance, etc, is an acceptable tradeoff for being the early adopters.
This heatsink with and without fan doesn’t fit in bpi-r4 with be14. It’s too big, and the holes don’t line up. It looks like this is intended for BPI-R4 Lite. It would be nice to know before i bought it. Please include it in the description of these items !
:exploding_head:
  • It appears to match only with the R4 Lite and the R4 Pro.
  • Combined with this information:
… it doesn’t smell good :see_no_evil:
Yeah, i’m little pissed, but oh well. I just hope there will be some proper heatsink for the original bpi-r4 and be14 especially since i bought the taller case.
it looks like there may be an issue with compatibility for your heat- and fansink assembly.
→ It does not fit the standard R4. Could you please mention this in the product description?
I have a question in mind:
Do you plan to revise the design of the standard R4? :thinking:
I think sales isn’t aware of this. Otherwise, they wouldn’t label it as “BPI-R4-BE14”.
or …
Does the new BE14 get a new heatsink?
… and the old heatsink will not be supported?
Yeah, they should put it in the description, that it’s intended for the Lite and Pro version.
thank you for your advice. I have already responded to this issue and it should be revised soon.
I still don‘t know how that fan would fit on the lite or pro, they use the same BE14 board?
Or do they also need a modified BE14 with spacers soldered to the gold-holes (like the same problem as with the massive fan)? And then rotate the fan 90° and screw them with 2 screws on the BE14 board and 2 screws on the main-router board?
Image of the modified BE14 boards with spacers soldered to it: BE14 with spacers
Good, I said it fits the heatsink perfectly. It should have come with some screws and brackets like these.
You should first insert the gold brackets into the motherboard and then insert the screws.
I’ve attached some pictures.
Regards
OK, that would make more sense - but at least for the normal BPI-R4 you could only screw two of those into the BE14 board, as the spacing on the heatsink are larger than the board itself.
I guess the same could work for the larger heatsink then… I ask Judy if that would work as well…
Good afternoon. As the images show, the one they sent me fits perfectly once installed on the board.
Mine arrived as I’ve shown you: first, place the gold-plated components on the motherboard, then the heatsink, and finally the screws.
It fits perfectly, at least what they sent me.
I’ll leave you with the current temperatures.
Regards
