Hi all, I have couple questions to which I cannot find clear answer:
- Is it possible to power supply BPi-M2+ over header ? If no, then, are there any workarounds/reworks I can made to achieve that ?
- What is maximum number of USB and UART ports I can use on BPi-M2+ assuming configuration of some pins on header ?
- Is BPi-M2+ immune to RTC issue ? I can’t see any RTC on board so I assume it is not. I see typically you use external DS1307, are there any other solutions worth consider ?
I would be glad to any materials that describe RTC issue in more technical terms.
