I just discovered this article showing a sample of use (blink) with GPIO.
Could you please explain what is the differences between MikuDuino and WiringPi ?
Sincerely thanks.
Sincerely thanks.
WiringPi was write for Raspberry Pi, it is widely everyone, It has also been ported to various versions of BPI, such as BPI-M1,M2 & M3. MikuPi is an Arduino like Library, it is basic & tiny, We use this library more like Arduino, it could work all versions of BPI include BPI-M2+, MikuPi is a new thing, in our efforts to grow rapidly.
Thank you for your attention, we hope more valuable advice
Dear BPI_Q,
thank you for your reply.
Then I presume it could be easy to get back informations coming from 433 MHz sensors by using the standard 433 MHz receiver.
I means I thing to use my BPi M2P to get 433 MHz Temperature and Humidity from 3 place of my house. For this I will use this available 433 MHz mini weather station that gives both temperature and humidity. And I will put three of them in different place in my house.
In the same idea I though to get the sensor value of this motion detection PIR 433 MHz sensor.
When tested could you please add the schematic connection and samples code on your book ?
Could you also tell us what is the shield board (in black you used on the main page of this ebook ? Because I never saw it before and that could perhaps be interesting for my projects
Could you confirm that the GPIO map you mentioned here has the same GPIO order than the BPi M2+ ?
Sincerely thanks for all
you are great to find out MikuDuino’s gitbook!
That has just begun, not add details, we will make reference to the gradual improvement of your suggestions.
I am also very interested in the project weather station, you need is a universal demand, we will consider giving priority to related testing
MikuDuino have two GPIO map, one is same as WiringPi(wPi 8\9\7…), one is Physical pin (D3\D5\D7), it define in MikuDuino.h & MikuPi.cpp
Dear BPI_Q,
Do you know if mikuduino could receive 433 MHz from three mini weather station or only fom one ? How are they identified separatly ?
Does Mukuduino also work on Orange Pi and as I already have a Banana Pi R1 (router) on which run the OpenWRT operating system how could I get Mikuduino working on this operating system (to be able to use my router GPIO) ?
Sincerely thanks.
In general, 1 to n of the collection we use more 24L01 +, one kind of SPI module in 2.4G or WIFI/BLE/Zigbee…
MikuDuino on BPI-R1 can be used, but linux system, is not OpenWRT, not tried。
by using the OpenWRT in Virtualbox you may test if it works and give some feedback. I talk about feedback because I need to know how to install and use it on OpenWRT.
I will wait your feedback.
Thank you
