it applies to the 5 GHz band, the noise level for 2.4 GHz is constant between the reboots, I did not test the 6 GHz band as I do not have the antennas for that band,
router stands still between the reboots (i.e. nothing changes regarding the router position nor element placement, antennas stand still, connectors and cables too)
the different noise levels result in different Rx throughput of the router (obviously higher throughput is observed when the noise level is lower)
it is less common to get low noise level value than high noise value (read it as: 1 per ~20 reboots I get low noise while all the others bring high noise value)
@Betonmischer I get quite high (-77 dBm) noise values with the BE14 and the metal case/provided pigtails. I get -91 dBm noise on my previous router, so about 25x more noise or so. It makes the AP pretty much unusable. Pretty disappointing, all things considered, especially for how much it cost. I guess it’s on me for not reading the forum before buying.
I will try switching to the plastic case and better pigtails.
Hello @hyf,
You didn’t do anything wrong, that just confirms two things:
- your BPI-NIC-BE14 module is all fine,
- my module is faulty, which I try to prove since the very beginning.
Yes, if you had carefully gone through the whole thread I presume. I recall from memory what @Betonmischer told me in a forum discussion elsewhere.
In your test, you have to close the case in its assembled shape, not open air like shown in your photo. The signal will drop to 80dBm or worse. Can’t recall the values exactly.
(Note personally I use R4 as a wired router. Can’t test or vouch for anything related to WiFi.)
