BPI-R4 WiFi range
bro, sadly that’s true :joy:, ther other one have okey wifi (but only 1Gbps peak) and broken 2.5GbE.
details here: Banana Pi BPI-BE1900 Wifi7 Module design - #45 by tutugreen
that is their first try to make a wifi router…
I’M A KAMIKAZE, wish me luck :rofl::
Just have fun, nice hardware toys ax211 ↔ BE14 5 GHz 160 MHz ~5m in clear vision, i have 2x be14 zero/normal eeprom,works quite well i think
Screenshot 2025-10-20 141512
Should’ve waited for thr be19000 card lol
My single BPI-R4 standard installation (metal enclosure + BE-14) has inacceptable high noise levels of -76dBM. The covered area on this floor is really really poor, so I need to do something.
  • Did anyone try and replace the metal enclosure by the (initial available) plastic one to reduce the noise? The noise reports from @Betonmischer with and without enclosure make me think the plastic case could be a solution. I just ordered one to see whether this might help. Other than that I will try and use a different metal enclosure, which works already well with a installation of BPI-R4 + 2xMT7916 + 1xMT7915 (noise levels around -90dBm).
  • Regarding SFP: I have right now only a DAC attached (via which this access point is connected). Will it really help to input the second SFP? If so - will it make any difference which one I choose or can I get any cheap from ebay?
  • Will it make a difference to add a heatsink in this case (with only a DAC connected this doesn’t seem necessary)?
Yes, switching to a plastic case and populating both SFP cages (either a DAC or a transceiver will work) will make the biggest impact on noise level. A heatsink on top of the cages won’t help, but will come in handy should you ever use 10G copper transceivers. Also, route the pigtails away from the mini-PCIe connectors, try a different Wi-Fi channel and don’t use the bandwidth of 160 or 320 MHz if you don’t have a need for it.
Is there a difference in which pigtails I deploy?
You’ll want to use 20cm RG178 cables
So with all those measures the area coverage becomes acceptable?
Better than stock for sure
Wow, you’ve been much luckier than me with your hardware, haha.
Mine came with a broken EEPROM, which makes it practically useless out of the box.
What a disaster. What a waste of time and money this thing is to get functional Wi-Fi.
That’s the first thing that comes to mind, I know haha.
But I see that the BE19000 is much larger than the BE14, so I don’t think it would fit in the box that my BPI-R4 came in.
Also, I think the R4 Pro is much more over-engineered. Which already raises doubts because Banana Pi is already struggling with the current hardware…
its easy, patch eeprom and take this regulatory.db and regulatory.db.p7 to /lib/firmware then iw reg reload and start playing with wireless config. i tested patched be14 looks the same, good vs bad eeprom (-test) 20db power
be14vs
be14vs2
be14vs3
You use 10 antennas, did you include a 5G-modem?
yes, im using Fibocom FM350-GL
Ok, so I can confirm that with
  • the plastic enclosure installed
  • replacing that thin low-grade pigtailes by RG178-pigtailes, that are routed away from the mPCIe-connectors
  • populating the unused SFP cage with a random module (the cheapest I could get were 2,5€ each)
  • reducing bandwidth from 160MHz to 80MHz (in BE-mode)
I get a really satisfying throughput (/higher usable coverage) for the floor I installed this device for. Thanks a lot for your help!
Insert a (not used) SFP increases you wifi range (rx level on client/reduce noise)?
Doesn’t for me, doesn’t do anything at all tbh
I precised my feedback.
It reduces noise for me by 1-2dBi.
I observe different noise levels across reboots:
  • high noise values (seen in > 90% of the board boots)
root@bpi-r4:~# iw dev wlan0 survey dump | grep -B1 noise
        frequency:                      2442 MHz [in use]
        noise:                          -88 dBm
        frequency:                      5180 MHz [in use]
        noise:                          -75 dBm
root@bpi-r4:~#
  • relatively (as for this HW) low noise values (seen in < 10% of the board boots):
        noise:                          -88 dBm
        noise:                          -83 dBm
root@bpi-r4:~#
worth pointing out:
  • it applies to the 5 GHz band, the noise level for 2.4 GHz is constant between the reboots, I did not test the 6 GHz band as I do not have the antennas for that band,
  • router stands still between the reboots (i.e. nothing changes regarding the router position nor element placement, antennas stand still, connectors and cables too)
  • the different noise levels result in different Rx throughput of the router (obviously higher throughput is observed when the noise level is lower)
  • it is less common to get low noise level value than high noise value (read it as: 1 per ~20 reboots I get low noise while all the others bring high noise value)
  • I’m using the latest mt7996 firmware:
[   14.388511] mt7996e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20250904203308a
[   14.627003] mt7996e 0000:01:00.0: WM Firmware Version: ____000000, Build Time: 20250904203304
[   14.676271] mt7996e 0000:01:00.0: DSP Firmware Version: ____000000, Build Time: 20250904202814
[   14.717602] mt7996e 0000:01:00.0: WA Firmware Version: ____000000, Build Time: 20250904203218
  • as for my understanding/knowledge the noise levels are being calculated and reported by the HW/FW, so it is a HW/FW issue
