It’s already fixed at 2.5Gbps, I’m referring to ALCATELLUCENT
Did you try the second firmware as well?
root@OpenWrt:/# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.1.0 * 255.255.255.0 U 0 0 0 br-lan
192.168.20.0 * 255.255.255.0 U 0 0 0 br-wan
root@OpenWrt:/#
eth1 is still down and the bridge br-wan too
i’m going to do it now
i changed my /etc/config/network and did a /etc/init.d/network restart
that’s not enough ?
take a look onto “ip a”, eth1 needs to be up to receive packets (maybe you need a link there). also the bridge.
maybe it is easier to remove eth1 from the bridge and give the ip directly
can you tell me first if there is a command to do this from the shell ?
ip link set eth1 up
ip link set br-wan up
to remove eth1 from bridge
ip link set dev eth1 nomaster
ip a del 192.168.20.1/24 dev br-wan
ip a add 192.168.20.1/24 dev eth1
root@OpenWrt:/# ip link set eth1 up
root@OpenWrt:/# ip link set br-wan up
root@OpenWrt:/# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1504 qdisc mq state UP qlen 1000
link/ether 72:68:4d:0f:ba:92 brd ff:ff:ff:ff:ff:ff
inet6 fe80::7068:4dff:fe0f:ba92/64 scope link
3: eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq master br-wan state DOWN qlen 1000
link/ether 72:68:4d:0f:ba:93 brd ff:ff:ff:ff:ff:ff
4: wan@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-wan state LOWERLAYERDOWN qlen 1000
5: lan1@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
6: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
7: lan3@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
8: lan4@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
9: sfp2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
17: br-lan: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN qlen 1000
inet 192.168.1.1/24 brd 192.168.1.255 scope global br-lan
inet6 fd33:6451:7ce0::1/60 scope global tentative noprefixroute
18: br-wan: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN qlen 1000
inet 192.168.20.1/24 brd 192.168.20.255 scope global br-wan
root@OpenWrt:/#
mhm, seems it is still down because of the link…but maybe you can ping the bridge-IP and then the one from the ONT
root@OpenWrt:/# ip link set dev eth1 nomaster
[ 1657.560205] device eth1 left promiscuous mode
[ 1657.564654] br-wan: port 1(eth1) entered disabled state
root@OpenWrt:/# ip a del 192.168.20.1/24 dev br-wan
root@OpenWrt:/# ip a add 192.168.20.1/24 dev eth1
3: eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN qlen 1000
inet 192.168.20.1/24 scope global eth1
root@OpenWrt:/#
no…still no answer to the pings
root@OpenWrt:/# cat /etc/config/network
config interface 'loopback'
option device 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd33:6451:7ce0::/48'
config device
option name 'br-lan'
option type 'bridge'
list ports 'lan1'
list ports 'lan2'
list ports 'lan3'
list ports 'lan4'
list ports 'sfp2'
config interface 'lan'
option device 'br-lan'
option ipaddr '192.168.1.1'
option netmask '255.255.255.0'
option ip6assign '60'
config device
option name 'br-wan'
list ports 'wan'
config device
option name 'eth1'
option macaddr '72:68:4d:0f:ba:93'
config device
option name 'wan'
config interface 'wan'
option device 'br-wan'
option proto 'dhcp'
config interface 'wan6'
option proto 'dhcpv6'
config interface 'ont'
option device 'eth1'
option ipaddr '192.168.20.1'
root@OpenWrt:/#
I removed ETH1 from the br-wan, and set the ONT interface with eth1, and still no ping after a /etc/init.d/network restart
maybe we need to wait till the other quirks are in (at least the waiting one)
can you do a
ethtool -m eth1
Try installing via opkg, if it doesn’t require kmods it will work
i’m with the serial…
well, i just installed your latest firmware and here is the bootlog : https://pastebin.com/KUidtq7d
root@OpenWrt:/# logread | grep 'eth1'
Fri Sep 1 00:03:19 2023 kern.info kernel: [ 1.118308] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc009680000, irq 136
Fri Sep 1 00:03:22 2023 kern.info kernel: [ 21.334824] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
Fri Sep 1 00:03:22 2023 kern.info kernel: [ 21.345379] br-wan: port 1(eth1) entered blocking state
Fri Sep 1 00:03:22 2023 kern.info kernel: [ 21.350633] br-wan: port 1(eth1) entered disabled state
Fri Sep 1 00:03:22 2023 kern.info kernel: [ 21.356423] device eth1 entered promiscuous mode
Fri Sep 1 00:03:22 2023 kern.info kernel: [ 21.363034] br-wan: port 1(eth1) entered blocking state
Fri Sep 1 00:03:22 2023 kern.info kernel: [ 21.368285] br-wan: port 1(eth1) entered forwarding state
Fri Sep 1 00:03:23 2023 kern.info kernel: [ 22.176483] br-wan: port 1(eth1) entered disabled state
root@OpenWrt:/# logread | grep 'sfp'
Fri Sep 1 00:03:19 2023 kern.info kernel: [ 11.824483] sfp sfp-1: Host maximum power 3.0W
Fri Sep 1 00:03:19 2023 kern.info kernel: [ 11.829668] sfp sfp-2: Host maximum power 3.0W
Fri Sep 1 00:03:19 2023 kern.info kernel: [ 12.164794] sfp sfp-1: module ALCATELLUCENT G010SP rev 10 sn ALCLFAB44018 dc 161205
Fri Sep 1 00:03:22 2023 kern.info kernel: [ 21.302764] mt7530-mdio mdio-bus:1f sfp2: configuring for inband/2500base-x link mode
Fri Sep 1 00:03:22 2023 kern.info kernel: [ 21.312733] br-lan: port 5(sfp2) entered blocking state
Fri Sep 1 00:03:22 2023 kern.info kernel: [ 21.318016] br-lan: port 5(sfp2) entered disabled state
Fri Sep 1 00:03:22 2023 kern.info kernel: [ 21.325791] device sfp2 entered promiscuous mode
Fri Sep 1 00:03:22 2023 kern.err kernel: [ 21.449760] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:22 2023 kern.err kernel: [ 21.574545] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:23 2023 kern.err kernel: [ 21.688574] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:23 2023 kern.err kernel: [ 21.800604] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:23 2023 kern.err kernel: [ 21.912614] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:23 2023 kern.err kernel: [ 22.024693] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:23 2023 kern.err kernel: [ 22.136642] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:23 2023 kern.err kernel: [ 22.251750] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:23 2023 kern.err kernel: [ 22.364434] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:23 2023 kern.err kernel: [ 22.481775] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:27 2023 kern.warn kernel: [ 26.464576] sfp_soft_get_state: 37 callbacks suppressed
Fri Sep 1 00:03:27 2023 kern.err kernel: [ 26.464594] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:27 2023 kern.err kernel: [ 26.584567] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:28 2023 kern.err kernel: [ 26.696548] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:28 2023 kern.err kernel: [ 26.808555] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:28 2023 kern.err kernel: [ 26.920555] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:28 2023 kern.err kernel: [ 27.032554] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:28 2023 kern.err kernel: [ 27.144553] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:28 2023 kern.err kernel: [ 27.256525] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:28 2023 kern.err kernel: [ 27.368523] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:28 2023 kern.err kernel: [ 27.480543] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:32 2023 kern.warn kernel: [ 31.544523] sfp_soft_get_state: 38 callbacks suppressed
Fri Sep 1 00:03:32 2023 kern.err kernel: [ 31.544539] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:33 2023 kern.err kernel: [ 31.664521] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:33 2023 kern.err kernel: [ 31.776520] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:33 2023 kern.err kernel: [ 31.888521] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:33 2023 kern.err kernel: [ 32.000522] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:33 2023 kern.err kernel: [ 32.112569] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:33 2023 kern.err kernel: [ 32.232639] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:33 2023 kern.err kernel: [ 32.344551] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:33 2023 kern.err kernel: [ 32.456540] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:33 2023 kern.err kernel: [ 32.568535] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:38 2023 kern.warn kernel: [ 36.632521] sfp_soft_get_state: 38 callbacks suppressed
Fri Sep 1 00:03:38 2023 kern.err kernel: [ 36.632536] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:38 2023 kern.err kernel: [ 36.752521] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:38 2023 kern.err kernel: [ 36.864524] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:38 2023 kern.err kernel: [ 36.976520] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:38 2023 kern.err kernel: [ 37.088520] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:38 2023 kern.err kernel: [ 37.200520] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:38 2023 kern.err kernel: [ 37.312520] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:38 2023 kern.err kernel: [ 37.424543] sfp sfp-1: failed to read SFP soft status: -6
Fri Sep 1 00:03:38 2023 kern.err kernel: [ 37.536536] sfp sfp-1: failed to read SFP soft status: -6
i created my ONT interface on eth1, and removed eth1 from the bridge.
option device 'lo'
option ula_prefix 'fd75:0574:8ab0::/48'
config device
list ports 'lan1'
list ports 'lan2'
list ports 'lan3'
list ports 'lan4'
list ports 'sfp2'
config device
list ports 'wan'
config device
option name 'eth1'
option macaddr '9a:a6:82:d4:c2:52'
config device
option name 'wan'
option proto 'dhcp'
root@OpenWrt:/#
Still no answer to the pings
