Hello,
i just bought a BPI-R3, and discovered that my MA5671 doesn’t work in SFP1 or SFP2. While it works in a Mikrotik RB4011.
My MA5671 was flashed with a modded firmware in order to work with my ISP.
Some people reported the MA5671 works with original firmware and rooted.
Can you please report here what brand/model or firmware hack you are successfuly using in the BPI-R3 Please ?
i installed the debian image, the one in the wiki, and the sfp ont is working here !
I succeded to compile an image from @dangowrt tree, with all the latest patch, but the SFP ONT is still not working…
i’d like to use Openwrt not debian…
Looks like the TX_FAULT pin is used for something else, maybe a serial port. Hence we will need to add a quirk for this SFP indicating that. This can also be because the external (xPON/fiber) link does not come up yet because you did not configure the MAC address and key in the module.
Unfortunately there is currently no way to temporarily ignore the TX_FAULT indication in order to be able to access the system running inside the ONT and configure it despite the external link not being up.
This is a shortcoming which will have to be addressed in Linux at some point, hopefully…
With SinoVoip’s image it’s working because they just configure both SFP slots to work in 2500Base-X mode fixed without caring about any the SFP’s signals other than the SerDes lanes.
maybe he can simply disable the tx pin in dts (or patch out the possible tx-fault-requirement/handling in his codebase)? to use it for uart or anything else?
text says it will disable TX-Fault (i guess on the ONT) and serial, but r3 will still try to read tx-fault gpio…so what state will the pin have when it is disabled?
fw_setenv is for setting an variable in uboot environment. i am sure openwrts uboot does not call the preboot-var, so this will do nothing. also the gpio numbers will not match bpi-r3.
so i guess you need to enter the system on the gpon-stick…maybe it uses uboot too
and here the gpio are correct and preboot is called…make sure you can enter the falcon-bootloader before do the gpio command…
If you can login to the ONT somehow via SSH or Telnet and use fw_setenv asc0 1 only without seeting or modifying preboot. If you are afraid to break things, dump the env first with fw_printenv and lets discuss here.
looks like it fixed the problem as i can’t see any errors now
root@OpenWrt:/# logread | grep 'sfp'
Sat Aug 19 14:01:10 2023 kern.info kernel: [ 11.683303] sfp sfp-1: Host maximum power 1.0W
Sat Aug 19 14:01:10 2023 kern.info kernel: [ 11.688496] sfp sfp-2: Host maximum power 1.0W
Sat Aug 19 14:01:10 2023 kern.info kernel: [ 12.019752] sfp sfp-1: module ALCATELLUCENT G010SP rev 10 sn ALCLFAB44018 dc 161205
Sat Aug 19 14:01:10 2023 kern.info kernel: [ 12.059671] sfp sfp-2: module TP-LINK TL-SM410U rev 2.0 sn 122C304001372 dc 221228
Sat Aug 19 14:01:13 2023 kern.info kernel: [ 19.273990] mt7530-mdio mdio-bus:1f sfp2: configuring for inband/2500base-x link mode
Sat Aug 19 14:01:13 2023 kern.info kernel: [ 19.283870] br-lan: port 5(sfp2) entered blocking state
Sat Aug 19 14:01:13 2023 kern.info kernel: [ 19.289098] br-lan: port 5(sfp2) entered disabled state
Sat Aug 19 14:01:13 2023 kern.info kernel: [ 19.296781] device sfp2 entered promiscuous mode
root@OpenWrt:/#
root@OpenWrt:/# logread | grep 'eth1'
Sat Aug 19 14:01:10 2023 kern.info kernel: [ 1.181362] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc009780000, irq 136
Sat Aug 19 14:01:13 2023 kern.info kernel: [ 19.305501] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/2500base-x link mode
Sat Aug 19 14:01:13 2023 kern.info kernel: [ 19.315595] br-wan: port 1(eth1) entered blocking state
Sat Aug 19 14:01:13 2023 kern.info kernel: [ 19.320850] br-wan: port 1(eth1) entered disabled state
Sat Aug 19 14:01:13 2023 kern.info kernel: [ 19.326233] device eth1 entered promiscuous mode
Sat Aug 19 14:01:13 2023 kern.info kernel: [ 19.332371] br-wan: port 1(eth1) entered blocking state
Sat Aug 19 14:01:13 2023 kern.info kernel: [ 19.337600] br-wan: port 1(eth1) entered forwarding state
Sat Aug 19 14:01:14 2023 kern.info kernel: [ 20.151135] br-wan: port 1(eth1) entered disabled state
root@OpenWrt:/#
But it keeps going into disabled state so i still can’t acces the onu on it’s ip address at 192.168.20.10
OMG ! i can’t access my ONT anymore with ssh with debian now…
root@bpi-r3:/# ping 192.168.20.10
PING 192.168.20.10 (192.168.20.10) 56(84) bytes of data.
64 bytes from 192.168.20.10: icmp_seq=1 ttl=64 time=0.306 ms
64 bytes from 192.168.20.10: icmp_seq=2 ttl=64 time=0.273 ms
64 bytes from 192.168.20.10: icmp_seq=3 ttl=64 time=0.318 ms
64 bytes from 192.168.20.10: icmp_seq=4 ttl=64 time=0.262 ms
root@bpi-r3:/# ssh [email protected]
ssh: connect to host 162.168.20.10 port 22: No route to host
root@bpi-r3:/#
i can’t revert to fw_setenv asc0 0
EDIT:
Fortunately i could revert the setting using a mediaconverter (TP-LINK MC220L)
But i’m still getting that route error…I must have a configuration problem somewhere
