Matching these strings? Or which one are we trying to get working…
Just tx_fault_ignore flag
This is just to avoid using the command : fw_setenv asc0 1 in the ONT ?
i’ll be back at home in 1h30 max to check.
Did you post the ethtool output somewhere? I did not find it…
this one with halny quirk, try both images i created
yes, but I think i have to be in the right environment otherwise it doesn’t make sense.
Thank you ! I’ll try it as soon as I get home.
I found some more intersting fixes, that might need applying also:
if (!memcmp(id.base.vendor_name, "ALCATELLUCENT ", 16) &&
!memcmp(id.base.vendor_pn, "3FE46541AA ", 16))
sfp->module_t_start_up = T_START_UP_BAD_GPON;
else
sfp->module_t_start_up = T_START_UP;
if (!memcmp(id.base.vendor_name, "HUAWEI ", 16) &&
!memcmp(id.base.vendor_pn, "MA5671A ", 16))
sfp->tx_fault_ignore = true;
else
sfp->tx_fault_ignore = false;
See the ALCATELLUCENT SFP needs a 60 seconds delay…
May need sfp->tx_fault_ignore = false; as well, but does the string match with @Rooot his module?
There’s a quirk for long startup as well, i can mix them, but let’s see if the halny quirk worked
Are all gpon modules with embedded system? Maybe it makes sense to delay all of them (e.g. by a sfp-type field) this can be shown in userspace…afair in userspace all sfp are shown as fibre,also copper ones
mine are openwrt based, so i’d say yes.
if i remember well when i insert the Huawei MA5671A i see a message speaking about “something slow detected”…
back at home
when i plug the G-01S-P
root@OpenWrt:/# [ 75.125741] sfp sfp-1: module ALCATELLUCENT G010SP rev 10 sn ALCLFAB44018 dc 161205
when i plug the MA5671A
[ 143.585495] sfp sfp-1: please wait, module slow to respond
root@OpenWrt:/# [ 189.949737] sfp sfp-1: module Lantiq Falcon SFP rev 0 sn 032WDY10J8020978 dc 180607
[ 189.959228] mtk_soc_eth 15100000.ethernet eth1: switched to inband/1000base-x link mode
[ 189.996109] hwmon hwmon2: temp1_input not attached to any thermal zone
[ 194.683833] sfp sfp-1: module transmit fault indicated
[ 198.697366] sfp sfp-1: module transmit fault recovered
[ 198.702528] sfp sfp-1: module transmit fault indicated
[ 200.016101] sfp sfp-1: module persistently indicates fault, disabling
If there is no known PHY to communicate with, then better it reports as fibre.
@frank-w you asked me ‘ip a’
root@OpenWrt:/# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1504 qdisc mq state UP qlen 1000
link/ether 72:68:4d:0f:ba:92 brd ff:ff:ff:ff:ff:ff
inet6 fe80::7068:4dff:fe0f:ba92/64 scope link
3: eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq master br-wan state DOWN qlen 1000
link/ether 72:68:4d:0f:ba:93 brd ff:ff:ff:ff:ff:ff
inet 192.168.20.1/24 brd 192.168.20.255 scope global eth1
4: wan@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-wan state LOWERLAYERDOWN qlen 1000
5: lan1@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
6: lan2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
7: lan3@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
8: lan4@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
9: sfp2@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue master br-lan state LOWERLAYERDOWN qlen 1000
15: br-lan: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN qlen 1000
inet 192.168.1.1/24 brd 192.168.1.255 scope global br-lan
inet6 fd33:6451:7ce0::1/60 scope global tentative noprefixroute
16: br-wan: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN qlen 1000
inet6 fe80::7068:4dff:fe0f:ba93/64 scope link
root@OpenWrt:/#
At 2.5Gbps inband negotiation is a pain in the … Better also include in the quirk:
linkmode_clear_bit(ETHTOOL_LINK_MODE_Autoneg_BIT, modes);
here you see that eth1 is attached to br-wan, so assigning an IP address to the physical interface does not work…try to remove it there and add it to the bridge or take eth1 out of bridge
and of course interface needs to be put up
And add a route? Maybe?
nope, same subnet is always routed to the interface having the same subnet…if you add an ip to an interface the corresponding route will be added automaticly
you only need to manually add routes if the target-subnet is not known by your device…
17: br-lan: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN qlen 1000
18: br-wan: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN qlen 1000
inet 192.168.20.1/24 brd 192.168.20.255 scope global br-wan
root@OpenWrt:/# ping 192.168.20.10
PING 192.168.20.10 (192.168.20.10): 56 data bytes
OK, did it.
no ping answer
root@OpenWrt:/# cat /etc/config/network
config interface 'loopback'
option device 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd33:6451:7ce0::/48'
config device
option name 'br-lan'
option type 'bridge'
list ports 'lan1'
list ports 'lan2'
list ports 'lan3'
list ports 'lan4'
list ports 'sfp2'
config interface 'lan'
option device 'br-lan'
option ipaddr '192.168.1.1'
option netmask '255.255.255.0'
option ip6assign '60'
config device
option name 'br-wan'
list ports 'eth1'
list ports 'wan'
config device
option name 'eth1'
option macaddr '72:68:4d:0f:ba:93'
config device
option name 'wan'
config interface 'wan'
option device 'br-wan'
option proto 'dhcp'
config interface 'wan6'
option proto 'dhcpv6'
config interface 'ont'
option ipaddr '192.168.20.1'
root@OpenWrt:/#
