Perhaps work with older snapshot 2023-04-20, I use 2.5GbE sfp to rj45 and I haven’t had any issues.
i don’t have any issues too, with a tplink 2.5g sfp to rj45. Looks like the poblem occures only with ONT SFP…
Then I am curious why it does not work on openwrt, but it does on debian.
I did not understand that part from the above…
and now my BPI-R3 doesn’t want to boot from sdcard anymore ?!
all jumpers are high, and i keep getting this message
Using ethernet@15100000 device
TFTP from server 192.168.1.254; our IP address is 192.168.1.1
Filename 'openwrt-mediatek-filogic-bananapi_bpi-r3-initramfs-recovery.itb'.
Load address: 0x46000000
Loading: *
ARP Retry count exceeded; starting again
Wrong Image Format for bootm command
ERROR: can't get kernel image!
* spi-nand0
- device: spi_nand@1
- parent: spi@1100a000
- driver: spi_nand
- type: NAND flash
- block size: 0x20000 bytes
- page size: 0x800 bytes
- OOB size: 64 bytes
- OOB available: 24 bytes
- 0x000000000000-0x000008000000 : "spi-nand0"
- 0x000000000000-0x000000080000 : "bl2"
- 0x000000080000-0x000000380000 : "factory"
- 0x000000380000-0x000000580000 : "fip"
- 0x000000580000-0x000008000000 : "ubi"
Loading: *
i’ll try to help you, hold on i’m building a test firmware for you (it includes lots of stuff you probably don’t want, just check if your sfp module works)
thanks but now what ever i burn on my sdcard, nothing boot. looks like the sdcard is not detected, or it try to boot from nand ??
https://easyupload.io/x80su7 try this, i’ve created a patch for your module, let me know if that helps
finaly it worked with another sdcard…
unfortunately
i still can’t ping the ont
i created my ont interface, added it the ip address 192.168.20.1/24 and added it in the firewall wan zone. everything is correctly configured, but it still doesn’t want to respond to the ping.
the problem = i can’t ping the ont, so no ssh, it just doesn’t work.
The ont is working, i can access it if i put it in a media converter (MC220L) and connect it to the wan port. that way i can access to its ip, and of course i can access internet.
now I wonder if I’m waiting long enough for the sfp to boot…
since, i made this from the ONT : fw_setenv asc0 1
if i remember well, this wasn’t necessary with Debian. And with openwrt, if it fixes the error message, it doesn’t fix the problem anyway.
a ping/access normally need 2 ip adresses in same subnet (if not completely locally)…
please share your ip configuration (ip a)…if your ONT has 192.168.20.10 as ip address imho you need another one e.g. on a dummy bridge
with openwrt i just need to create a new interface on eth1, give it the ip address 192.168.20.1, and add it in the firewall wan zone. that’s enough, and that 100% works if i do it with the wan(rj45) port. my ONT is on ip 192.168.20.10
i can’t do ‘ip a’ actually i’m in my office, i’ll be back home later
I
I see you can edit the eeprom vendor and model ID.
static void sfp_fixup_halny_gsfp(struct sfp *sfp)
/* Ignore the TX_FAULT and LOS signals on this module.
* these are possibly used for other purposes on this
* module, e.g. a serial port.
sfp->state_hw_mask &= ~(SFP_F_TX_FAULT | SFP_F_LOS);
SFP_QUIRK_F("HALNy", "HL-GSFP", sfp_fixup_halny_gsfp),
So perhapse you can edit
Setting SFP vendor name
fw_setenv sfp_vendor_name "YOUR_SFP_VENDOR_NAME"
Setting SFP part name
fw_setenv sfp_part_name "YOUR_SFP_PART_NAME"
And pretend it is the HALNy HL-GSFP module, so the quirk is activated.
Then assuming it shows the correct speed (2.5Gbps) also in the eeprom, then you should be pretty close to a solution.
Edit:
But it depends which kernel version is running, as this quirk is introduced in kernel 6.1…
Ho ! interesting.
i’ll see if i can do that in a few hours…
Check the kernel version, as this quirk is introduced in kernel 6.1…
Perhapse @Dale can check if the quirk is in drivers/net/phy/sfp.c as he build it from the source…
Or he can add it to the patch he made…
I’ve added the MA5671 quirk for his module .it’s not the halny one
Btw i have 2 ONT, the Huawei MA5671A, and the Alcatel Lucent G-010S-P
They both have the same problem, so i guess all ONT have the problem…why the “Quirck” is only for one brand, and not generic ?
I’ll build you one with the halny quirk as well… hold on
What do you have in this quirk?
