edit: found an issue in second hostapd service file which prevents hostapd to be started…passed pidfile is wrong…just add the “2” like in PID-variable above
edit: uploaded new version with fixed uboot (missing emmc-partconf, sata-config) and fixed service file and prepared pppoe/ipv6tunnel
i try to extract some parts of my very complicated firewall file as basic config for r3…
But it seems like there is missing something to load the driver…
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 0cf3:7015 Qualcomm Atheros Communications TP-Link TL-WN821N v3 / TL-WN822N v2 802.11n [Atheros AR7010+AR9287]
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
[ 145.751888] usb 1-2: USB disconnect, device number 3
[ 149.112288] usb 1-2: new high-speed USB device number 4 using xhci-mtk
[ 525.118105] usb 1-2: USB disconnect, device number 4
[ 530.412270] usb 1-2: new high-speed USB device number 5 using xhci-mtk
[ 1071.635854] usb 1-2: USB disconnect, device number 5
[ 1074.902278] usb 1-2: new high-speed USB device number 6 using xhci-mtk
I am using the Bookworm image - but could not find better place to put the question??
@frank-w
if i use your bullseye image , why can´t use your kernel deb package , he
will not boot the new installed kernel by dpkg -i .
the bullyseys dist boot allways the default kernel.
with your debain image for the r2 and your kernel build deb package work this
well , i upgrade the kernel with dpkg and the r2 boot the new version.
how can do this behavior with the r3 bullseye dist with your kernel build repository
and the generated deb package.
The default kernel deb only unpacks the kernel,but not tell uboot to use the new file.
So you just need to add the new filename to the uEnv.txt
fit=bpi-r3-6.6.x.itb
I want to avoid overwriting the old kernel so added version to the file,but have not tried to modify uEnv.txt in deb script of kernel as this needs to add a script in the deb.
the modification , and copy , of the uEnv.txt did not work .
per default in your bullseys dist , there is no uEnv.txt in /boot
i try to copy and modify out of the deb file , this file but the bpir3 will allways boot the default kernel.
There is no uEnv.txt in the deb file…there is an itb which should be in /boot now…this file is the one fit var in uEnv.txt has to point to. /boot needs to be mountpoint of mmcblkXp5 (default in my image)
Just create the file there and add the fit line with correct filename
You do not need uImage_nodt and dtb…only the itb. The other 2 files are for making tests with overlays or using separate dtb. And i see no uEnv.txt there…default value for fit var is bpi-r3.itb,so this is why it works
