It’s your turn to help: https://www.armbian.com/get-involved/
What network agent tools are available
The one that are shipped with Network Manager.
hello,How to use Socks5
Like on any other Linux? If something is not enabled, build tools are here https://github.com/armbian/build
Is there an armbian China update source
Who launched this version of Ubuntu, answer - how?
Hey folks, I tried both buster and focal armbian images successfully from sd, but I couldn’t install it on emmc (neither dd and nand-sata-install)… any clue about it? thanks in advance
Hi. Is there somewhere a step-by-step guide for a home assistant installation for the M2 Berry?
Did you try at Home assistant page?
Hello yes i have. I get an error message after entering the command
"sudo -u homeassistant -H -s cd / srv / homeassistant python3.9 -m venv. source bin / activate "
I tried Raspbian Stretch
pi@bpi-iot-ros-ai:~ $ sudo useradd -rm homeassistant pi@bpi-iot-ros-ai:~ $ sudo mkdir /srv/homeassistant pi@bpi-iot-ros-ai:~ $ sudo chown homeassistant:homeassistant /srv/homeassistant pi@bpi-iot-ros-ai:~ $ sudo -u homeassistant -H -s homeassistant@bpi-iot-ros-ai:/home/pi $ cd /srv/homeassistant homeassistant@bpi-iot-ros-ai:/srv/homeassistant $ python3.9 -m venv . bash: python3.9: command not found homeassistant@bpi-iot-ros-ai:/srv/homeassistant $ source bin/activate bash: bin/activate: No such file or directory homeassistant@bpi-iot-ros-ai:/srv/homeassistant $
Now I’ve made some progress but still won’t start
" homeassistant@bpi-iot-ros-ai:/srv/homeassistant $ hass Unable to find configuration. Creating default one in /home/homeassistant/.homeassistant 2021-12-11 00:31:00 ERROR (MainThread) [homeassistant.auth.providers] Unable to load auth provider homeassistant: libffi.so.7: cannot open shared object file: No such file or directory 2021-12-11 00:31:00 ERROR (MainThread) [homeassistant.bootstrap] Home Assistant core failed to initialize. Further initialization aborted 2021-12-11 00:31:00 WARNING (MainThread) [homeassistant.bootstrap] Unable to set up core integrations. Activating safe mode 2021-12-11 00:31:00 ERROR (MainThread) [homeassistant.auth.providers] Unable to load auth provider homeassistant: libffi.so.7: cannot open shared object file: No such file or directory 2021-12-11 00:31:00 ERROR (MainThread) [homeassistant.bootstrap] Home Assistant core failed to initialize. Further initialization aborted "
