Banana pi BPI-M2 Berry quad core single-board computer with Allwinner V40
BPI-M2 Berry public sale . easy to buy sample :slight_smile:
https://www.aliexpress.com/snapshot/0.html?spm=a2g0s.9042311.0.0.F9S05t&orderId=503446847031746&productId=32823650244
Banana Pi M2 Berry - unboxing, boot, thermal imaging pictures
BPI M2-Berry where WiringPi is downloaded
image have include Wiring Pi support . or you can download source code at github.
newest version:
I downloaded version 2.44 of WiringPi, it prompts me that the version is not correct and my development board is BPI M2-Berry
Hello, I bought a Banana Pi M2 Berry. Unfortunately I have not found a system with the Banana Pi booted. The image “2017-05-25-raspbian-jessie-preview3-bpi-m2u-sd-emmc.img” can not be started. The Banana Pi hangs up in an endless loop when booting. For help, I would be grateful. Greetings Jürgen Rieger
Hi Jürgen
Schreib das img neu auf die SD, die zip hast entpackt ?
Wenn das nicht Hilft musst du es neu Downloaden .
Write the img new to the SD, the zip have unpacked?
If this does not help you have to re-download it.
Hello Wolfgang, thank you very much for your answer. Yes I have extract the ZIP-File and I have write the Image multiple times at the SD-Card. If I open the Google Download Side a Message appears: Google Drive kann keinen Virenscann für diese Datei Durchführen. Trotzdem herunterladen? Where is a better Link to download this Image? Where can I find a better download? Regards Jürgen
V40 datasheet:
https://drive.google.com/file/d/0B4PAo2nW2KfneE54VzVOdHpITzA/view?usp=sharing
Hello sinovoip bpi Team, thank you for your answer. I need not a datasheet and a schematic diagram, I need a Image to flash a SD-Card. For days I try to burn a SD card however without succes. Is there an image running on the Banana Pi M2 Berry? The images you have proposed do not run at my Banana Pi. Best Regards Jürgen
you can use this miage
Thank you very much for your answer. My Model is “Banana Pi M2 Berry”, V40 Quadcore 1,2 GHz, SATA WLAN, GBLAN, BT Serial# 4250236815510 CR-1573544 Best Regards Jürgen
Dear Sir, Thank you for your hint. I have used this Image. But it did not work. You can watch the result in a video. The Link to the Video: https://www.magentacloud.de/lnk/AcgCiu3M. Use VLC Media Player to watch the Video-Stream. Regards Jürgen
Hallo Sie müssen darauf achten wie die Bezeichnung ist Ich habe das gleiche gerät Banana PI BPI-M2 / BPI-M2 Berry Funktioniert einwandfrei. Achim
Let’s talk wedge pillows! Numerous studies have shown that sleeping in an elevated position not only helps alleviate symptoms from acid reflux or GERD, but also help with flu, back pains, and swollen feet.
My M2 berry v1.0 board is shutting down after running for some minutes without warning. I’m running the official image, Ubuntu 16.04, downloaded from the M2 berry wiki page. I’d like to investigate if one of the components is broken. The schematics have been posted here, but I’m missing the board view. Would it be possible to share that? Or if it is already, where can I find it?
