3D printable BPI-R4 Case
I’m sorry but I cannot relate. Public projects for things like RPi work - this deviates a lot from BPi I have.
I created a v2 ceiling access point case. I converted two bpi-r4 to use poe+ and mounted both of them on the ceiling in my home. They’ve been working well with a 120mm fan. I’m seeing idle temps of 33c and peaks of 59c.
May I ask which antennas you used? I plan something similar!
10Pcs/1pc 5DBI 2.4G 5G 5.8G WIFI built in PCB antenna Wifi antenna IPEX interface dual band omnidirecational IPEX/U.FL connector - AliExpress 13
Could you maybe upload the latest version of your case in stl again. I like it but have the same problem as the guy before with dividing the parts of 3mf. Since the original metal case creates more RF noise I would switch to a 3D printed case.
@ShawnO
Your case looks awesome, just im also needing access to the boot switches without needing to open the case
very cool. How about for the other side?
Hi guys :v:
Has anyone modeled just the top cover of the original case to add some ventilation? If such a model exists, please share it.
would you consider uploading to printables or makerworld? would be easier for others to find it and reuse the design
most stuff I found had very specific use cases like rack mount, etc.
Here are a few ideas. Work in progress…
I am working on this thing (without any ETA), firstly for myself, because I want something that looks like a standard desktop router from any other brands. A decade ago I had an Archer C7 with very fancy LEDs. I designed something similar by myself and it came out in very good shape from my 3D printer (transparent PLA).
Here is how it looks now: iCloud Photo Sharing
For the technical perspective, for the LEDs, I am using pogo pins, to hijack the ETH LEDs from the connector solder points and three more pogo pins for the reset and WDS button (by this test print, this idea looks like a working one). For the other LEDs (system, storage, internet, wifi1,2,3 and the two SFP LEDs) I defined LED devices on the free GPIOs. Because I wanted to use vanilla, unmodified OpenWRT I had to figure out how to add something for the device tree without touching anything which was provided by the OpenWRT (link). Because my plan is to only use one SIM, this was the only one which has been “extended” to the outer world via some extension cable. I am trying to design it to use as few supports as I can.
It looks great, too. I just wanted something that could be mounted in a 10“ or 19” rack. At the same time, I wanted to address the cooling issue. The fact that there’s no option to mount a fan on top bothers me the most. But since the manufacturers aren’t offering anything, I’ll just have to build something myself…
jens1976, a practical compromise could be a two-piece design: a rack-ear/tray base that holds the board and a separate ventilated top with a 50 mm fan cutout over the CPU. Printing the top face-down avoids most supports, and the fan can pull air across the board and out through side slots. czo, a removable top grille would also let you keep the router-like front while adding cooling later.
What I showed above was just an idea. I’ve since designed something for the BPI-R4 Pro as well. 1U, full 19“ width. There’s also a version with a cutout for a 2.8” display. That one is 1.5U tall.
The BPI-R4 will probably end up being 1U or 1.5U as well. But then it won’t fit in a 10“ rack anymore. Sure, you could squeeze it in so it fits in a 10” rack, but it would be really tight, and there wouldn’t be any room left for upgrades or other modifications.
I should note, however, that these ideas are not primarily intended for 3D printing, but rather for 1.25 mm metal. However, they can be adapted for 3D printing. I’ve already done some test prints. I think that with the necessary wall thickness, these designs can also be used for 3D printing.
