BPI-R2 LEDE source code for hardware NAT
(gary) #1
Source code
The source code is at: https://github.com/garywangcn/bpi-r2_lede
Please clone the code to local and checkout the code from branch bpi-r2-on-lede-v1.
Build
Follow the LEDE building instruction to compile the lede system, the target system is MediaTek Ralink ARM, the config file is attached.
Please download the image I built from below link http://pan.baidu.com/s/1nuXqAVJ
Boot with LEDE image
Step 1: Please program LEDE 2017-09-08 image to emmc by following BPI-R2 New image : Openwrt/LEDE 2017-09-08
Step 2: Boot the board from EMMC, and enter U-boot shell.
Step 3: Load build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_32/uImage-mt7623n-bananapi-bpi-r2-initramfs from host pc(tftp 84000000 uImage-mt7623n-bananapi-bpi-r2-initramfs). Before loading image, you may need to set/ipaddr/netmask/serverip in uboot
Step 4: Program the image to EMMC by run command:
   mmc dev 0
   mmc write 84000000 1000 5800
IP Forwarding Performance based on hardware NAT
Known limitation
  1. PCIE is disabled because it may cause OS to be hang
  2. HDMI is not validated.
Banana Pi BPI-R2 Open Source smart router with MTK 7623N design
BPI-R2 Ethernet MAC address
Performance of IP forwarding over both GMACs(eth0 and eth1)
(gary) #2
Before testing IP forwarding, please change the firewall setting in /etc/config/firewall, and then restart firewall(/etc/init.d/firewall restart). Below is for you reference
firewall (4.1 KB)
#3
Hi gary, I built the system and transfered it to my pi and copied it on emmc. But it cant boot. The uboot promp shows:
MMC read: dev # 0, block # 4096, count 22528 ... 22528 blocks read: OK
bootm flag=0, states=70f
Booting kernel from Legacy Image at 84000000 ...
  Image Name:   MIPS OpenWrt Linux-4.9.44
  Data Size:    3692431 Bytes = 3.5 MiB
  Load Address: 80008000
  Entry Point:  80008000
  Verifying Checksum ... OK
  Loading Kernel Image ... OK
Starting kernel ...
what did I do wrong?
(Frank W.) #4
Did you changed something with uart in dtsi?
#5
I only did set the ip environment settings, download the file via tftp and write it with mcc…
(Frank W.) #6
does it boot from sd-card?
#7
I tried it again and … it works :sweat_smile:
(gary) #8
The pcie issue has been fixed, please get the latest code from https://github.com/garywangcn/bpi-r2_lede
A pull request has been created for submitting commits to moore-bros/bpi-r2-on-lede.
#9
I build the system and I use the mkimage in staging_dir/host/bin create a Multi-File Image.
I can boot the system. But I can`t get any freespace like the image form BPI-R2 New image : Openwrt/LEDE 2017-09-08
How can I do?
command:
mkimage -A arm -T multi -C none -a 80008000 -e 80008000 -n ‘Multi-File Test Image’ -d lede-mediatek-32-uImage-mt7623n-bananapi-bpi-r2-initramfs:lede-mediatek-32-root.squashfs uMulti
And it return:
Image Name: Multi-File Test Image
Created: Thu Oct 12 22:26:59 2017
Image Type: ARM Linux Multi-File Image (uncompressed)
Data Size: 9897528 Bytes = 9665.55 kB = 9.44 MB
Contents:
Image 0: 5965351 Bytes = 5825.54 kB = 5.69 MB
Image 1: 3932164 Bytes = 3840.00 kB = 3.75 MB
(gary) #10
Can you please try to build and program image to emmc by following instruction?
Instruction
  1. Please clone the latest code from github(https://github.com/garywangcn/bpi-r2_lede/tree/bpi-r2-on-lede-v1) and then follow below steps to build/program both rootfs and uImage :
  2. Run make menuconfig in root directory of bpi-r2_lede
  3. Enable squashfs: Target Images ->squashfs
  4. Rebuild lede by executing command: make
  5. The root.squashfs and uImage-mt7623n-bananapi-bpi-r2 will be programmed to EMMC via tftp, they are located at build_dir/target…/linux-mediatek_32/
  6. Copy above images to /tftpboot/(please enable tftp service first)
  7. Boot the board to Uboot prompt, configure the IP address/netmask/gatewayip/serverip, make sure the R2 board is able to access tftp server.
  8. Run below command to program uImage-mt7623n-bananapi-bpi-r2:
    mmc dev 0
    mmc write 84000000 1000 6000
  9. Run below command to program root.squashfs to EMMC:
    tftp 84000000 root.squashfs
    mmc dev 0
    mmc write 84000000 20A00 6000
10.Run command: boot
Please note that the first reboot will take a few minutes to sync file system.
BPI R2 LEDE(openwrt) source code
#11
Thanks garywang. It works!
“df -h” :
And in LUCI:
(gary) #12
Good news, thanks for your informatio, please let me know if you have any question.
(gary) #13
New test images(kernel and root.squashfs) are available: http://pan.baidu.com/s/1nuXrUTb
How to program both uImage and root file system
  1. Copy both uImagelede and root.squashfs to tftp server
  2. Run below command to program uImagelede
tftp 84000000 uImagelede
mmc dev 0
  1. Run below command to program root.squashfs to EMMC:
mmc dev 0
  1. Run command: boot
  2. Configure an available IP address and then run below commands when entering OS
opkg update
opkg  install luci-theme-bootstrap
opkg  install luci-mod-admin-full
  1. Connect R2 board via web
(Paweł Kalemba) #14
With this image it Will possible to use R2 as a normal router?, i got problems with nat on Ubuntu.
(gary) #15
Yes, it’s possible to make R2 to be a router.
On Ubuntu, the HNAT will NOT be supported, the HNAT is supported based on DSA structure, but there is no DSA within kernel 4.4(ubuntu is using), so it’s a huge task to port HNAT from lede(4.9 kernel) to Ubuntu(4.4 kerenl).
(Frank W.) #16
Can 4.9 from lede be used for ubuntu? Where are problems? If the problem with sd-card in 4.14 can be solved it can also be used.
#17
Replace the current uImage with v4.14 kernel so that you can run HNAT on Ubuntu. I’ve done it before…
(Frank W.) #18
@Ryder.Lee Is sd-card-problem solved?
#19
How a can configure my IP Address? I tried it with ifconfig br-lan add … and route add default gw … I can ping my PC successfully but I got no internet
(gary) #20
Hi RW2003
The DNS should be configured and the /etc/config/firewall will be changed, please refer to http://forum.banana-pi.org/uploads/default/original/2X/8/84d6c0336af978c299fb73556fd67d896e719d52.png
