I think this problem is not like that. I have intenet now. And did not change any things in “/etc/config/firewall”. Actually I just change the ifname for “wan” and “wan6” in the "/etc/config/network" to “wan” but not “eth1”. And it works.
Could you send pull request back to github. Lets us make support lede better.
There is no wifi available yet, right?
Wifi-ap-driver is currently in testing state for debian-kernel (4.4.70)
Install commands not work… ‘cannot Install package’
Do you mean that both luci-theme-bootstrap and luci-mod-admin-full can’t be installed, right?
Yup, some packages can be installed eg. curl but some cannot eg. htop
can’t download uImageLede by this link. root.squashfs downloaded without problem.
Hello Tohin, I succeeded selecting both files and clicking on the Download button on the top of the page. You should retrieve a zip file including both files. I had the same problem trying to donwload the files one by one …
There is a new problem. I cant change my macaddr in either Luci or "/etc/config/network". Ones I change it, it cant get any IP with dhcp. Just like dead. Even I use static IP, i still can`t ping my gateway.
Another question: The mac of “wan@eth1” changed in each boot. My network have IP-MAC bind. I need a stationary MAC so that i can use the internet.
Please fix it.
Add: It can get Ipv6 address. And it can also send DHCP Discover. The MAC is which i write in “/etc/config/network”. But it don’t get DHCP Offer packet or just drop it.
ps:I don’t know how to write pull request. Sorry for the inconvenience.
Hello. Tell me please how to set ip-address and netmask in uboot-shell?
- Set IP Address
- Use DHCP U-Boot> dhcp
- Or use static IP address U-Boot> setenv ipaddr setenv netmask
2.Configure server IP U-Boot> setenv serverip
- If the R2 board and server are not in same local area network, you need to configure the gatewayip.
Hit any key to stop autoboot: 0
BPI-R2>
BPI-R2> dhcp
Unknown command 'dhcp' - try 'help'
BPI-R2> setenv ipaddr
BPI-R2> setenv ipaddr 192.168.2.150
BPI-R2> setenv netmask 255.255.255.0
BPI-R2> ping 192.168.2.1
Enter mt7623_ethifsys_init()
[mt7623_pinmux_set]start
[mt7623_pinmux_set]end
Waitting for RX_DMA_BUSY status Start... done
Enter setup_internal_gsw()
MT7530 Reset Completed!!
change HW-TRAP to 0x1015edf
Release MT7623 RXC Reset
Using Eth0 device
ping failed; host 192.168.2.1 is not alive
Doesn’t work. I tried to connect the patch cord in turn to WAN and LAN ports.The gateway is not available.
Hi Tohin
Sorry, the cmd dhcp isn’t included in our Uboot .
can you please confirm if the cable is connected to one of interfaces lan1-4? And what’s status of the link?, up or down?
Yes, I tried to connect the patch cord in LAN ports. according to led on port, link is up.
Can you please run command to saveenv to save environment variables and then reset? Also please share me all environment variables(run command printenv to show them).
I think I have a problem with switch. I boot to previous version LEDE and try to connect LAN:
root@LEDE:/# ifconfig eth0 Link encap:Ethernet HWaddr 86:E8:E3:B0:C3:C7 inet addr:192.168.2.150 Bcast:192.168.2.255 Mask:255.255.255.0 inet6 addr: fe80::84e8:e3ff:feb0:c3c7/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:145 errors:0 dropped:0 overruns:0 frame:0 TX packets:15 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:27379 (26.7 KiB) TX bytes:1646 (1.6 KiB) Interrupt:68 [ 215.588820] mt7623-gsw gswsys@1b100000: port 4 link up root@LEDE:/# route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 192.168.2.0 * 255.255.255.0 U 0 0 0 eth0 root@LEDE:/# ping 192.168.1.2 PING 192.168.1.2 (192.168.1.2): 56 data bytes **ping: sendto: Network unreachable**
printenv.txt (2,7 КБ)
Can I use eth1 in uboot by setehv ethact Eth1? (update: It doesn’t work. after reset I see eth0 in env)
After all experiments I loosed link in Uboot… Update2: Link is up after command “tftpboot”
I really don’t know how I did it.
BPI-R2> ping 192.168.2.1 Using Eth0 device host 192.168.2.1 is alive
root@LEDE:/# ping 192.168.1.2 PING 192.168.1.2 (192.168.1.2): 56 data bytes ping: sendto: Network unreachable
vs.
In the 1st test you pinged the wrong ip…router is in net 2.x,ping to 1.2
My bad. Sorry.
solved:new trouble
After all I flashed r4757-700175b to BPI. But here new trouble. I connect WAN (I understand correctly that WAN=eth1?) to my old router with dhcp (network 192.168.2.x).
On BPI I have no IP-address:
root@LEDE:/# ifconfig eth1 Link encap:Ethernet HWaddr 1A:F8:2C:C0:4C:12 inet6 addr: fe80::18f8:2cff:fec0:4c12/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:1 overruns:0 frame:0 TX packets:1268 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:403209 (393.7 KiB) Interrupt:205
If I set IP manually, network doesn’t work.
root@LEDE:/# ifconfig eth1 192.168.2.242 netmask 255.255.255.0 up root@LEDE:/# ping 192.168.2.1 PING 192.168.2.1 (192.168.2.1): 56 data bytes ^C --- 192.168.2.1 ping statistics --- 5 packets transmitted, 0 packets received, 100% packet loss
solution:
root@LEDE:/# ifconfig wan up root@LEDE:/# udhcpc -i wan
