When I first set up a Banana Pi board, the part that slowed me down was not the board itself. It was getting the operating system image onto a microSD card correctly. Copying the image file to the card does not work, because the card needs the boot sector, partition table, and file system written exactly as the image defines them. That is the job Win32 Disk Imager is made for, and it has become my usual starting point on Windows before I power up a new board.
Win32 Disk Imager is a small Windows utility that writes raw disk image files to SD cards and USB drives, and it can also read a card back into an image file. It does not try to be a full disk manager. It has one clear purpose, a simple window, and a small set of controls: choose an image file, choose a device, then Read, Write, or Verify. That focus is useful when you are preparing a board and do not want to learn a large new tool first.
The usual workflow is straightforward. Download the Banana Pi image for your model and extract it if it arrives compressed, because the tool expects an uncompressed image file. Insert a good-quality microSD card into a USB reader, open the tool as administrator, and check the drive letter twice before you continue. Select the image, select the card, and use Write. Writing replaces everything on the card. After the write finishes, use Verify to compare the card with the image. That extra minute is worth it, because a card that looks finished can still have a bad write that only shows up as a strange boot failure later.
One feature I value most is the Read function. Once a Banana Pi card is set up the way I like it, I read the whole card back into an image file and keep that file as a backup. If a later experiment breaks the system, I can write the backup back to the same card, or to a spare card, instead of starting from a clean image and repeating the setup. For a classroom, a small cluster, or several boards doing the same job, that also makes it easy to prepare identical cards from one working master.
The tool also includes built-in MD5, SHA-1, and SHA-256 hashing. Before writing, I compare the hash of the downloaded image with the value published with it. If the values do not match, I download the image again instead of flashing a file that may be incomplete or damaged. It is a small check, but it removes one common cause of confusing first-boot problems.
There are limits worth knowing. Win32 Disk Imager runs on Windows only, so Linux and macOS users will need a different tool. It does not extract compressed images, format cards, or create partitions, and it is not meant for making a Windows installation USB drive. It also writes from the start of the device, so choosing the wrong drive can erase the wrong storage.
