Ladies?? and Gentlemen!
After so loooooooooong silence, I have several good news for you guys who care about Windows 10 IoT Core on BPI-M64.
We have released the latest RS2 version image, and it will be uploaded soon.
In this release, we have fixed some serious bugs such as Ethernet. (oh oh oh~~~ we can use Ethernet eventually!!! )
Here is some notes:
Some updates:
Update the OS version to build v.10.0.15063.0 (Creators Update) -
New page style of Device Portal, visit https://deviceipaddr:8080 to check it -
Built-in Cortana assistant, need to be enabled in settings page in default app and Device Portal -
Support on-screen keyboard, need to be enabled in Device Portal -
Enable 100M Ethernet and fix some bugs -
Support built-in UART bus in A64 SoC(not built in the ffu, later provide driver binary and deployment helper) -
Support built-in IR module in A64 SoC(not built in the ffu, later provide source code and dev doc for developers in community)
Known Issues:
Kernel debug is enabled by default. This will slow the bring-up process. If a kernel debug is not necessary for you, visit Device Portal and navigate to Processes->Run Command page, run this command to disable:
Bcdedit /store C:\EFIESP\EFI\Microsoft\boot\BCD /set {default} debug off 2. An PnP bug in audio device may cause a blue screen when acting software shutdown 3. Ethernet device may not start with problem code 12 at the first time to bring up
And another bomb! I uploaded core driver binaries and packaging toolchains on GitHub!
Here is the repo address: GitHub - AricGamma/BSP-aw1689: BSP for Allwinner A64
And also some driver source code here with A64 datasheet in readme: GitHub - AricGamma/driver-samples
Welcome makers developers and anyone-elsers to post your feedback.
