Who knows how to get ROOT SUPER SU more applications running only SuperSu ((( I need to mount a USB HDD as the SD card.
Who knows the way to set SuperSU ? ( root android)
HI: Please use new image to try it .
Android 5.1 3.0 HDMI 3.4 2016-06-13 MD5: 918b1d3707ce58cd203d0b392fa4cc8b Google drive README
Thanks, I will test I hope everything will work as root
Install the new version of android, I was not able to put SuperSu to obtain root privileges. I ask you to install the new images with root privileges SuperSu. I ask you to install Google Play services - GAPS. GAPS, ROOT, SuperSu, the main desired useful features in the new images of android. I ask you very much to set them into new images of android.
HI: Please run this command. And try again .
chmod 777 system/bin/su
thank you very much, have access))
