Using FBTFT driver in Banana M2
Please,
Someone who installed and configured the FBTFT driver to use LCD via GPIO in Banana M2? I’m using a Waveshare 3.5 with the driver here:
In Raspberry work but would like to use Banana M2.
Armbian already contains the necessary drivers for SPI connected LCD displays. You find here a small guide how to combine Armbian with U-Boot/DTB for the M2: http://www.bananapi.com/index.php/forum/general-discussion-for-bpi-m2/995-working-wifi-on-modern-kernels-4-1-tested?start=6#2765 (just ignore the weird comments in the thread from a user called ‘sinovoip’).
sinovoip is not official user the supplier of Banana M2? I will check your tip. Thanks!
