Unable to provide adequate power to filogic 880 wifi 7 module
I can only recieve a 6 or 7 decibels of power even using the mediatek/filogic firmware
Linux OpenWrt 6.6.104 #0 SMP Fri Sep 19 21:19:38 2025 aarch64 GNU/Linux
root@OpenWrt:~# cat /etc/*release*
DISTRIB_ID='OpenWrt'
DISTRIB_RELEASE='24.10.3'
DISTRIB_REVISION='r28872-daca7c049b'
DISTRIB_TARGET='mediatek/filogic'
DISTRIB_ARCH='aarch64_cortex-a53'
DISTRIB_DESCRIPTION='OpenWrt 24.10.3 r28872-daca7c049b'
DISTRIB_TAINTS=''
NAME="OpenWrt"
VERSION="24.10.3"
ID="openwrt"
ID_LIKE="lede openwrt"
PRETTY_NAME="OpenWrt 24.10.3"
VERSION_ID="24.10.3"
HOME_URL="https://openwrt.org/"
BUG_URL="https://bugs.openwrt.org/"
SUPPORT_URL="https://forum.openwrt.org/"
BUILD_ID="r28872-daca7c049b"
OPENWRT_BOARD="mediatek/filogic"
OPENWRT_ARCH="aarch64_cortex-a53"
OPENWRT_TAINTS=""
OPENWRT_DEVICE_MANUFACTURER="OpenWrt"
OPENWRT_DEVICE_MANUFACTURER_URL="https://openwrt.org/"
OPENWRT_DEVICE_PRODUCT="Generic"
OPENWRT_DEVICE_REVISION="v0"
OPENWRT_RELEASE="OpenWrt 24.10.3 r28872-daca7c049b"
OPENWRT_BUILD_DATE="1758316778"
root@OpenWrt:~# iw dev
phy#0
	Interface phy0.1-ap0
		ifindex 14
		wdev 0x4
		addr 7e:a6:ce:78:f4:8e
		ssid OpenWrt
		type AP
		channel 36 (5180 MHz), width: 80 MHz, center1: 5210 MHz
		txpower 7.00 dBm
		multicast TXQ:
			qsz-byt	qsz-pkt	flows	drops	marks	overlmt	hashcol	tx-bytes	tx-packets
			0	0	0	0	0	0	0	0		0
		Radios: 1
	Interface phy0.0-ap0
		ifindex 13
		wdev 0x3
		addr 7e:a6:ce:78:f4:7e
		ssid OpenWrt
		type AP
		channel 1 (2412 MHz), width: 20 MHz, center1: 2412 MHz
		txpower 6.00 dBm
		multicast TXQ:
			0	0	0	0	0	0	0	0		0
		Radios: 0
root@OpenWrt:~# dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd090]
[    0.000000] Linux version 6.6.104 (builder@buildhost) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 13.3.0 r28872-daca7c049b) 13.3.0, GNU ld (GNU Binutils) 2.42) #0 SMP Fri Sep 19 21:19:38 2025
[    0.000000] Machine model: Bananapi BPI-R4
[    0.000000] OF: reserved mem: 0x0000000042ff0000..0x0000000042ffffff (64 KiB) map non-reusable ramoops@42ff0000
[    0.000000] OF: reserved mem: 0x0000000043000000..0x000000004304ffff (320 KiB) nomap non-reusable secmon@43000000
[    0.000000] OF: reserved mem: 0x0000000047cc0000..0x0000000047dbffff (1024 KiB) nomap non-reusable wmcpu-reserved@47cc0000
[    0.000000] OF: reserved mem: 0x000000004f600000..0x000000004f63ffff (256 KiB) nomap non-reusable wo-emi@4f600000
[    0.000000] OF: reserved mem: 0x000000004f640000..0x000000004f67ffff (256 KiB) nomap non-reusable wo-emi@4f640000
[    0.000000] OF: reserved mem: 0x000000004f680000..0x000000004f6bffff (256 KiB) nomap non-reusable wo-emi@4f680000
[    0.000000] OF: reserved mem: 0x000000004f700000..0x000000004fefffff (8192 KiB) nomap non-reusable wo-data@4f700000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000013fffffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x0000000042ffffff]
[    0.000000]   node   0: [mem 0x0000000043000000-0x000000004304ffff]
[    0.000000]   node   0: [mem 0x0000000043050000-0x0000000047cbffff]
[    0.000000]   node   0: [mem 0x0000000047cc0000-0x0000000047dbffff]
[    0.000000]   node   0: [mem 0x0000000047dc0000-0x000000004f5fffff]
[    0.000000]   node   0: [mem 0x000000004f600000-0x000000004f6bffff]
[    0.000000]   node   0: [mem 0x000000004f6c0000-0x000000004f6fffff]
[    0.000000]   node   0: [mem 0x000000004f700000-0x000000004fefffff]
[    0.000000]   node   0: [mem 0x000000004ff00000-0x000000013fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff]
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 18 pages/cpu s35624 r8192 d29912 u73728
[    0.000000] pcpu-alloc: s35624 r8192 d29912 u73728 alloc=18*4096
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS0,115200n1 pci=pcie_bus_perf root=/dev/fit0 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000fa7dd000-0x00000000fe7dd000] (64MB)
[    0.000000] Memory: 4024500K/4194304K available (9088K kernel code, 1000K rwdata, 1676K rodata, 448K init, 307K bss, 169804K reserved, 0K cma-reserved)
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 416 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: 0xffffffc080010080
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[    0.000064] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[    0.000071] pid_max: default: 32768 minimum: 301
[    0.002145] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002159] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.003642] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.003924] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.004005] rcu: Hierarchical SRCU implementation.
[    0.004007] rcu: 	Max phase no-delay instances is 1000.
[    0.004296] smp: Bringing up secondary CPUs ...
[    0.004512] Detected VIPT I-cache on CPU1
[    0.004546] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[    0.004568] CPU1: Booted secondary processor 0x0000000001 [0x411fd090]
[    0.004816] Detected VIPT I-cache on CPU2
[    0.004836] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[    0.004846] CPU2: Booted secondary processor 0x0000000002 [0x411fd090]
[    0.005076] Detected VIPT I-cache on CPU3
[    0.005096] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[    0.005106] CPU3: Booted secondary processor 0x0000000003 [0x411fd090]
[    0.005132] smp: Brought up 1 node, 4 CPUs
[    0.005137] SMP: Total of 4 processors activated.
[    0.005139] CPU features: detected: 32-bit EL0 Support
[    0.005141] CPU features: detected: CRC32 instructions
[    0.005171] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[    0.005174] CPU: All CPU(s) started at EL2
[    0.005176] alternatives: applying system-wide alternatives
[    0.008684] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.008695] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.009634] pinctrl core: initialized pinctrl subsystem
[    0.010505] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.010794] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.010895] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.010988] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.011266] thermal_sys: Registered thermal governor 'fair_share'
[    0.011269] thermal_sys: Registered thermal governor 'bang_bang'
[    0.011270] thermal_sys: Registered thermal governor 'step_wise'
[    0.011272] thermal_sys: Registered thermal governor 'user_space'
[    0.011310] ASID allocator initialised with 65536 entries
[    0.012005] pstore: Using crash dump compression: deflate
[    0.012011] printk: console [ramoops-1] enabled
[    0.012248] pstore: Registered ramoops as persistent store backend
[    0.012253] ramoops: using 0x10000@0x42ff0000, ecc: 0
[    0.014128] /soc/interrupt-controller@c000000: Fixed dependency cycle(s) with /soc/interrupt-controller@c000000
[    0.019854] Modules: 29600 pages in range for non-PLT usage
[    0.019862] Modules: 521120 pages in range for PLT usage
[    0.020689] cryptd: max_cpu_qlen set to 1000
[    0.021492] SCSI subsystem initialized
[    0.021597] libata version 3.00 loaded.
[    0.022568] clocksource: Switched to clocksource arch_sys_counter
[    0.024234] NET: Registered PF_INET protocol family
[    0.024373] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.026925] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.026949] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.026961] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.027059] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.027468] TCP: Hash tables configured (established 32768 bind 32768)
[    0.027780] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[    0.027911] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.027961] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.028164] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.028195] PCI: CLS 0 bytes, default 64
[    0.029018] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.032706] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.032712] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.064425] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.065362] mtk-xsphy soc:xphy@11e10000: failed to get ref_clk(id-1)
[    0.065956] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[    0.065975] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[    0.065988] mtk-pcie-gen3 11280000.pcie:       IO 0x0020000000..0x00201fffff -> 0x0020000000
[    0.066000] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[    0.066092] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[    0.066103] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[    0.066113] mtk-pcie-gen3 11290000.pcie:       IO 0x0028000000..0x00281fffff -> 0x0028000000
[    0.066123] mtk-pcie-gen3 11290000.pcie:      MEM 0x0028200000..0x002fffffff -> 0x0028200000
[    0.066141] /soc/pcie@11290000: Failed to get clk index: 0 ret: -517
[    0.066150] mtk-pcie-gen3 11290000.pcie: failed to get clocks
[    0.066212] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[    0.066222] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[    0.066231] mtk-pcie-gen3 11300000.pcie:       IO 0x0030000000..0x00301fffff -> 0x0030000000
[    0.066241] mtk-pcie-gen3 11300000.pcie:      MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[    0.066257] /soc/pcie@11300000: Failed to get clk index: 0 ret: -517
[    0.066264] mtk-pcie-gen3 11300000.pcie: failed to get clocks
[    0.066338] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[    0.066348] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[    0.066357] mtk-pcie-gen3 11310000.pcie:       IO 0x0038000000..0x00381fffff -> 0x0038000000
[    0.066366] mtk-pcie-gen3 11310000.pcie:      MEM 0x0038200000..0x003fffffff -> 0x0038200000
[    0.066382] /soc/pcie@11310000: Failed to get clk index: 0 ret: -517
[    0.066389] mtk-pcie-gen3 11310000.pcie: failed to get clocks
[    0.070830] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    0.072958] printk: console [ttyS0] disabled
[    0.093242] 11000000.serial: ttyS0 at MMIO 0x11000000 (irq = 99, base_baud = 2500000) is a ST16650V2
[    0.093277] printk: console [ttyS0] enabled
[    1.111114] 11000100.serial: ttyS1 at MMIO 0x11000100 (irq = 100, base_baud = 2500000) is a ST16650V2
[    1.140974] 11000200.serial: ttyS2 at MMIO 0x11000200 (irq = 101, base_baud = 2500000) is a ST16650V2
[    1.152995] loop: module loaded
[    1.157539] spi-nand spi0.0: Winbond SPI NAND was found.
[    1.162878] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[    1.171111] 2 fixed-partitions partitions found on MTD device spi0.0
[    1.177552] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[    1.184439] OF: Bad cell count for /soc/spi@11007000/spi_nand@0/partitions
[    1.191459] Creating 2 MTD partitions on "spi0.0":
[    1.196263] 0x000000000000-0x000000200000 : "bl2"
[    1.202446] 0x000000200000-0x000008000000 : "ubi"
[    1.280300] ubi0: default fastmap pool size: 50
[    1.284839] ubi0: default fastmap WL pool size: 25
[    1.289619] ubi0: attaching mtd1
[    2.110308] ubi0: scanning is finished
[    2.123742] ubi0: attached mtd1 (name "ubi", size 126 MiB)
[    2.129222] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    2.136090] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    2.142868] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[    2.149817] ubi0: good PEBs: 1007, bad PEBs: 1, corrupted PEBs: 0
[    2.155898] ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
[    2.163108] ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1697192243
[    2.172225] ubi0: available PEBs: 105, total reserved PEBs: 902, PEBs reserved for bad PEB handling: 19
[    2.181609] ubi0: background thread "ubi_bgt0d" started, PID 309
[    2.188288] block ubiblock0_1: created from ubi0:1(rootfs)
[    2.193774] ubiblock: device ubiblock0_1 (rootfs) set to be root filesystem
[    2.334084] i2c_dev: i2c /dev entries driver
[    2.338831] /soc/i2c@11003000/rt5190a@64: Fixed dependency cycle(s) with /soc/i2c@11003000/rt5190a@64/regulators/buck1
[    2.352255] mtk-wdt 1001c000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[    2.360365] mtk-cpufreq mtk-cpufreq: failed to initialize dvfs info for cpu0
[    2.367937] mtk-msdc 11230000.mmc: Got CD GPIO
[    2.368189] NET: Registered PF_INET6 protocol family
[    2.377778] Segment Routing with IPv6
[    2.381444] In-situ OAM (IOAM) with IPv6
[    2.385395] NET: Registered PF_PACKET protocol family
[    2.390451] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.403506] 8021q: 802.1Q VLAN Support v1.8
[    2.420599] phy phy-soc:[email protected]: type_sw - reg 0x218, index 0
[    2.427813] mtk-pcie-gen3 11280000.pcie: host bridge /soc/pcie@11280000 ranges:
[    2.435149] mtk-pcie-gen3 11280000.pcie: Parsing ranges property...
[    2.436423] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.441409] mtk-pcie-gen3 11280000.pcie:       IO 0x0020000000..0x00201fffff -> 0x0020000000
[    2.452922] mmc0: new high speed SDXC card at address aaaa
[    2.457821] mtk-pcie-gen3 11280000.pcie:      MEM 0x0020200000..0x0027ffffff -> 0x0020200000
[    2.463851] mmcblk0: mmc0:aaaa SR128 119 GiB
[    2.479147] Alternate GPT is invalid, using primary GPT.
[    2.484477]  mmcblk0: p1 p2 p3 p4 p5 p6 p7
[    2.802578] mtk-pcie-gen3 11280000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[    2.811391] mtk-pcie-gen3: probe of 11280000.pcie failed with error -110
[    2.818466] mtk-pcie-gen3 11290000.pcie: host bridge /soc/pcie@11290000 ranges:
[    2.825783] mtk-pcie-gen3 11290000.pcie: Parsing ranges property...
[    2.832048] mtk-pcie-gen3 11290000.pcie:       IO 0x0028000000..0x00281fffff -> 0x0028000000
[    2.840483] mtk-pcie-gen3 11290000.pcie:      MEM 0x0028200000..0x002fffffff -> 0x0028200000
[    3.182572] mtk-pcie-gen3 11290000.pcie: PCIe link down, current LTSSM state: detect.quiet (0x1)
[    3.191353] mtk-pcie-gen3: probe of 11290000.pcie failed with error -110
[    3.198233] mtk-pcie-gen3 11300000.pcie: host bridge /soc/pcie@11300000 ranges:
[    3.205546] mtk-pcie-gen3 11300000.pcie: Parsing ranges property...
[    3.211807] mtk-pcie-gen3 11300000.pcie:       IO 0x0030000000..0x00301fffff -> 0x0030000000
[    3.220240] mtk-pcie-gen3 11300000.pcie:      MEM 0x0030200000..0x0037ffffff -> 0x0030200000
[    3.468201] mtk-pcie-gen3 11300000.pcie: set IO trans window[0]: cpu_addr = 0x30000000, pci_addr = 0x30000000, size = 0x200000
[    3.479582] mtk-pcie-gen3 11300000.pcie: set MEM trans window[1]: cpu_addr = 0x30200000, pci_addr = 0x30200000, size = 0x200000
[    3.491047] mtk-pcie-gen3 11300000.pcie: set MEM trans window[2]: cpu_addr = 0x30400000, pci_addr = 0x30400000, size = 0x400000
[    3.502510] mtk-pcie-gen3 11300000.pcie: set MEM trans window[3]: cpu_addr = 0x30800000, pci_addr = 0x30800000, size = 0x800000
[    3.513974] mtk-pcie-gen3 11300000.pcie: set MEM trans window[4]: cpu_addr = 0x31000000, pci_addr = 0x31000000, size = 0x1000000
[    3.525523] mtk-pcie-gen3 11300000.pcie: set MEM trans window[5]: cpu_addr = 0x32000000, pci_addr = 0x32000000, size = 0x2000000
[    3.537072] mtk-pcie-gen3 11300000.pcie: set MEM trans window[6]: cpu_addr = 0x34000000, pci_addr = 0x34000000, size = 0x4000000
[    3.548877] mtk-pcie-gen3 11300000.pcie: PCI host bridge to bus 0000:00
[    3.555489] pci_bus 0000:00: root bus resource [bus 00-ff]
[    3.560966] pci_bus 0000:00: root bus resource [io  0x400000-0x5fffff] (bus address [0x30000000-0x301fffff])
[    3.570783] pci_bus 0000:00: root bus resource [mem 0x30200000-0x37ffffff]
[    3.577648] pci_bus 0000:00: scanning bus
[    3.581668] pci 0000:00:00.0: [14c3:7988] type 01 class 0x060400
[    3.587680] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[    3.594521] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[    3.600604] pci 0000:00:00.0: PME# disabled
[    3.606034] pci_bus 0000:00: fixups for bus
[    3.610209] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[    3.616903] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.624902] pci 0000:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[    3.631641] pci_bus 0000:01: scanning bus
[    3.635666] pci 0000:01:00.0: [14c3:7990] type 00 class 0x028000
[    3.641682] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit pref]
[    3.648907] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00007fff 64bit]
[    3.655793] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    3.661877] pci 0000:01:00.0: PME# disabled
[    3.692600] pci_bus 0000:01: fixups for bus
[    3.696774] pci_bus 0000:01: bus scan returning with max=01
[    3.702334] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    3.708946] pci_bus 0000:00: bus scan returning with max=01
[    3.714523] pci 0000:00:00.0: BAR 9: assigned [mem 0x30200000-0x303fffff 64bit pref]
[    3.722254] pci 0000:00:00.0: BAR 8: assigned [mem 0x30400000-0x304fffff]
[    3.729033] pci 0000:00:00.0: BAR 0: assigned [mem 0x30500000-0x30507fff 64bit]
[    3.736339] pci 0000:01:00.0: BAR 0: assigned [mem 0x30200000-0x303fffff 64bit pref]
[    3.744081] pci 0000:01:00.0: BAR 2: assigned [mem 0x30400000-0x30407fff 64bit]
[    3.751386] pci 0000:00:00.0: PCI bridge to [bus 01]
[    3.756343] pci 0000:00:00.0:   bridge window [mem 0x30400000-0x304fffff]
[    3.763121] pci 0000:00:00.0:   bridge window [mem 0x30200000-0x303fffff 64bit pref]
[    3.770860] pci 0000:00:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  256
[    3.779303] pci 0000:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  256
[    3.787807] pcieport 0000:00:00.0: assign IRQ: got 115
[    3.792944] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    3.799035] pcieport 0000:00:00.0: enabling bus mastering
[    3.804793] mtk-pcie-gen3 11300000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11300c00 data 0
[    3.813232] mtk-pcie-gen3 11300000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11300c00 data 1
[    3.821656] mtk-pcie-gen3 11300000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11300c00 data 2
[    3.830084] mtk-pcie-gen3 11300000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11300c00 data 3
[    3.838511] mtk-pcie-gen3 11300000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11300c00 data 4
[    3.846937] mtk-pcie-gen3 11300000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11300c00 data 5
[    3.855363] mtk-pcie-gen3 11300000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11300c00 data 6
[    3.863789] mtk-pcie-gen3 11300000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11300c00 data 7
[    3.872212] mtk-pcie-gen3 11300000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11300c00 data 8
[    3.880637] mtk-pcie-gen3 11300000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11300c00 data 9
[    3.889063] mtk-pcie-gen3 11300000.pcie: msi#0xa address_hi 0x0 address_lo 0x11300c00 data 10
[    3.897574] mtk-pcie-gen3 11300000.pcie: msi#0xb address_hi 0x0 address_lo 0x11300c00 data 11
[    3.906087] mtk-pcie-gen3 11300000.pcie: msi#0xc address_hi 0x0 address_lo 0x11300c00 data 12
[    3.914600] mtk-pcie-gen3 11300000.pcie: msi#0xd address_hi 0x0 address_lo 0x11300c00 data 13
[    3.923112] mtk-pcie-gen3 11300000.pcie: msi#0xe address_hi 0x0 address_lo 0x11300c00 data 14
[    3.931622] mtk-pcie-gen3 11300000.pcie: msi#0xf address_hi 0x0 address_lo 0x11300c00 data 15
[    3.940136] mtk-pcie-gen3 11300000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11300c00 data 16
[    3.948735] mtk-pcie-gen3 11300000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11300c00 data 17
[    3.957334] mtk-pcie-gen3 11300000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11300c00 data 18
[    3.965932] mtk-pcie-gen3 11300000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11300c00 data 19
[    3.974532] mtk-pcie-gen3 11300000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11300c00 data 20
[    3.983131] mtk-pcie-gen3 11300000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11300c00 data 21
[    3.991728] mtk-pcie-gen3 11300000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11300c00 data 22
[    4.000328] mtk-pcie-gen3 11300000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11300c00 data 23
[    4.008928] mtk-pcie-gen3 11300000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11300c00 data 24
[    4.017528] mtk-pcie-gen3 11300000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11300c00 data 25
[    4.026127] mtk-pcie-gen3 11300000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11300c00 data 26
[    4.034726] mtk-pcie-gen3 11300000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11300c00 data 27
[    4.043325] mtk-pcie-gen3 11300000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11300c00 data 28
[    4.051923] mtk-pcie-gen3 11300000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11300c00 data 29
[    4.060524] mtk-pcie-gen3 11300000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11300c00 data 30
[    4.069125] mtk-pcie-gen3 11300000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11300c00 data 31
[    4.078140] mtk-pcie-gen3 11300000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11300c00 data 0
[    4.086641] pcieport 0000:00:00.0: PME: Signaling with IRQ 116
[    4.092615] pcieport 0000:00:00.0: AER: enabled with IRQ 116
[    4.098307] pcieport 0000:00:00.0: save config 0x00: 0x798814c3
[    4.104224] pcieport 0000:00:00.0: save config 0x04: 0x00100406
[    4.110133] pcieport 0000:00:00.0: save config 0x08: 0x06040001
[    4.116047] pcieport 0000:00:00.0: save config 0x0c: 0x00010000
[    4.121955] pcieport 0000:00:00.0: save config 0x10: 0x30500004
[    4.127866] pcieport 0000:00:00.0: save config 0x14: 0x00000000
[    4.133776] pcieport 0000:00:00.0: save config 0x18: 0x00010100
[    4.139685] pcieport 0000:00:00.0: save config 0x1c: 0x000001f1
[    4.145595] pcieport 0000:00:00.0: save config 0x20: 0x30403040
[    4.151502] pcieport 0000:00:00.0: save config 0x24: 0x30313021
[    4.157412] pcieport 0000:00:00.0: save config 0x28: 0x00000000
[    4.163321] pcieport 0000:00:00.0: save config 0x2c: 0x00000000
[    4.169228] pcieport 0000:00:00.0: save config 0x30: 0x00000000
[    4.175138] pcieport 0000:00:00.0: save config 0x34: 0x00000080
[    4.181045] pcieport 0000:00:00.0: save config 0x38: 0x00000000
[    4.186954] pcieport 0000:00:00.0: save config 0x3c: 0x00020173
[    4.193204] mtk-pcie-gen3 11310000.pcie: host bridge /soc/pcie@11310000 ranges:
[    4.200509] mtk-pcie-gen3 11310000.pcie: Parsing ranges property...
[    4.206779] mtk-pcie-gen3 11310000.pcie:       IO 0x0038000000..0x00381fffff -> 0x0038000000
[    4.215214] mtk-pcie-gen3 11310000.pcie:      MEM 0x0038200000..0x003fffffff -> 0x0038200000
[    4.465688] mtk-pcie-gen3 11310000.pcie: set IO trans window[0]: cpu_addr = 0x38000000, pci_addr = 0x38000000, size = 0x200000
[    4.477074] mtk-pcie-gen3 11310000.pcie: set MEM trans window[1]: cpu_addr = 0x38200000, pci_addr = 0x38200000, size = 0x200000
[    4.488539] mtk-pcie-gen3 11310000.pcie: set MEM trans window[2]: cpu_addr = 0x38400000, pci_addr = 0x38400000, size = 0x400000
[    4.500002] mtk-pcie-gen3 11310000.pcie: set MEM trans window[3]: cpu_addr = 0x38800000, pci_addr = 0x38800000, size = 0x800000
[    4.511465] mtk-pcie-gen3 11310000.pcie: set MEM trans window[4]: cpu_addr = 0x39000000, pci_addr = 0x39000000, size = 0x1000000
[    4.523015] mtk-pcie-gen3 11310000.pcie: set MEM trans window[5]: cpu_addr = 0x3a000000, pci_addr = 0x3a000000, size = 0x2000000
[    4.534564] mtk-pcie-gen3 11310000.pcie: set MEM trans window[6]: cpu_addr = 0x3c000000, pci_addr = 0x3c000000, size = 0x4000000
[    4.546244] mtk-pcie-gen3 11310000.pcie: PCI host bridge to bus 0001:00
[    4.552854] pci_bus 0001:00: root bus resource [bus 00-ff]
[    4.558331] pci_bus 0001:00: root bus resource [io  0x600000-0x7fffff] (bus address [0x38000000-0x381fffff])
[    4.568147] pci_bus 0001:00: root bus resource [mem 0x38200000-0x3fffffff]
[    4.575012] pci_bus 0001:00: scanning bus
[    4.579031] pci 0001:00:00.0: [14c3:7988] type 01 class 0x060400
[    4.585043] pci 0001:00:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[    4.591880] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[    4.597966] pci 0001:00:00.0: PME# disabled
[    4.603464] pci_bus 0001:00: fixups for bus
[    4.607639] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 0
[    4.614333] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    4.622328] pci 0001:00:00.0: scanning [bus 00-00] behind bridge, pass 1
[    4.629070] pci_bus 0001:01: scanning bus
[    4.633094] pci 0001:01:00.0: [14c3:7991] type 00 class 0x028000
[    4.639109] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit pref]
[    4.646335] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x00007fff 64bit]
[    4.653221] pci 0001:01:00.0: PME# supported from D0 D3hot D3cold
[    4.659305] pci 0001:01:00.0: PME# disabled
[    4.692599] pci_bus 0001:01: fixups for bus
[    4.696773] pci_bus 0001:01: bus scan returning with max=01
[    4.702334] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[    4.708946] pci_bus 0001:00: bus scan returning with max=01
[    4.714521] pci 0001:00:00.0: BAR 9: assigned [mem 0x38200000-0x383fffff 64bit pref]
[    4.722253] pci 0001:00:00.0: BAR 8: assigned [mem 0x38400000-0x384fffff]
[    4.729032] pci 0001:00:00.0: BAR 0: assigned [mem 0x38500000-0x38507fff 64bit]
[    4.736338] pci 0001:01:00.0: BAR 0: assigned [mem 0x38200000-0x383fffff 64bit pref]
[    4.744079] pci 0001:01:00.0: BAR 2: assigned [mem 0x38400000-0x38407fff 64bit]
[    4.751384] pci 0001:00:00.0: PCI bridge to [bus 01]
[    4.756343] pci 0001:00:00.0:   bridge window [mem 0x38400000-0x384fffff]
[    4.763121] pci 0001:00:00.0:   bridge window [mem 0x38200000-0x383fffff 64bit pref]
[    4.770860] pci 0001:00:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  256
[    4.779301] pci 0001:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  256
[    4.787814] pcieport 0001:00:00.0: assign IRQ: got 118
[    4.792951] pcieport 0001:00:00.0: enabling device (0000 -> 0002)
[    4.799041] pcieport 0001:00:00.0: enabling bus mastering
[    4.804804] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[    4.813243] mtk-pcie-gen3 11310000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11310c00 data 1
[    4.821668] mtk-pcie-gen3 11310000.pcie: msi#0x2 address_hi 0x0 address_lo 0x11310c00 data 2
[    4.830095] mtk-pcie-gen3 11310000.pcie: msi#0x3 address_hi 0x0 address_lo 0x11310c00 data 3
[    4.838521] mtk-pcie-gen3 11310000.pcie: msi#0x4 address_hi 0x0 address_lo 0x11310c00 data 4
[    4.846946] mtk-pcie-gen3 11310000.pcie: msi#0x5 address_hi 0x0 address_lo 0x11310c00 data 5
[    4.855373] mtk-pcie-gen3 11310000.pcie: msi#0x6 address_hi 0x0 address_lo 0x11310c00 data 6
[    4.863798] mtk-pcie-gen3 11310000.pcie: msi#0x7 address_hi 0x0 address_lo 0x11310c00 data 7
[    4.872221] mtk-pcie-gen3 11310000.pcie: msi#0x8 address_hi 0x0 address_lo 0x11310c00 data 8
[    4.880646] mtk-pcie-gen3 11310000.pcie: msi#0x9 address_hi 0x0 address_lo 0x11310c00 data 9
[    4.889072] mtk-pcie-gen3 11310000.pcie: msi#0xa address_hi 0x0 address_lo 0x11310c00 data 10
[    4.897584] mtk-pcie-gen3 11310000.pcie: msi#0xb address_hi 0x0 address_lo 0x11310c00 data 11
[    4.906097] mtk-pcie-gen3 11310000.pcie: msi#0xc address_hi 0x0 address_lo 0x11310c00 data 12
[    4.914610] mtk-pcie-gen3 11310000.pcie: msi#0xd address_hi 0x0 address_lo 0x11310c00 data 13
[    4.923123] mtk-pcie-gen3 11310000.pcie: msi#0xe address_hi 0x0 address_lo 0x11310c00 data 14
[    4.931632] mtk-pcie-gen3 11310000.pcie: msi#0xf address_hi 0x0 address_lo 0x11310c00 data 15
[    4.940147] mtk-pcie-gen3 11310000.pcie: msi#0x10 address_hi 0x0 address_lo 0x11310c00 data 16
[    4.948746] mtk-pcie-gen3 11310000.pcie: msi#0x11 address_hi 0x0 address_lo 0x11310c00 data 17
[    4.957346] mtk-pcie-gen3 11310000.pcie: msi#0x12 address_hi 0x0 address_lo 0x11310c00 data 18
[    4.965945] mtk-pcie-gen3 11310000.pcie: msi#0x13 address_hi 0x0 address_lo 0x11310c00 data 19
[    4.974544] mtk-pcie-gen3 11310000.pcie: msi#0x14 address_hi 0x0 address_lo 0x11310c00 data 20
[    4.983143] mtk-pcie-gen3 11310000.pcie: msi#0x15 address_hi 0x0 address_lo 0x11310c00 data 21
[    4.991740] mtk-pcie-gen3 11310000.pcie: msi#0x16 address_hi 0x0 address_lo 0x11310c00 data 22
[    5.000340] mtk-pcie-gen3 11310000.pcie: msi#0x17 address_hi 0x0 address_lo 0x11310c00 data 23
[    5.008938] mtk-pcie-gen3 11310000.pcie: msi#0x18 address_hi 0x0 address_lo 0x11310c00 data 24
[    5.017538] mtk-pcie-gen3 11310000.pcie: msi#0x19 address_hi 0x0 address_lo 0x11310c00 data 25
[    5.026137] mtk-pcie-gen3 11310000.pcie: msi#0x1a address_hi 0x0 address_lo 0x11310c00 data 26
[    5.034743] mtk-pcie-gen3 11310000.pcie: msi#0x1b address_hi 0x0 address_lo 0x11310c00 data 27
[    5.043343] mtk-pcie-gen3 11310000.pcie: msi#0x1c address_hi 0x0 address_lo 0x11310c00 data 28
[    5.051941] mtk-pcie-gen3 11310000.pcie: msi#0x1d address_hi 0x0 address_lo 0x11310c00 data 29
[    5.060543] mtk-pcie-gen3 11310000.pcie: msi#0x1e address_hi 0x0 address_lo 0x11310c00 data 30
[    5.069141] mtk-pcie-gen3 11310000.pcie: msi#0x1f address_hi 0x0 address_lo 0x11310c00 data 31
[    5.078161] mtk-pcie-gen3 11310000.pcie: msi#0x0 address_hi 0x0 address_lo 0x11310c00 data 0
[    5.086664] pcieport 0001:00:00.0: PME: Signaling with IRQ 119
[    5.092616] pcieport 0001:00:00.0: AER: enabled with IRQ 119
[    5.098304] pcieport 0001:00:00.0: save config 0x00: 0x798814c3
[    5.104220] pcieport 0001:00:00.0: save config 0x04: 0x00100406
[    5.110129] pcieport 0001:00:00.0: save config 0x08: 0x06040001
[    5.116040] pcieport 0001:00:00.0: save config 0x0c: 0x00010000
[    5.121947] pcieport 0001:00:00.0: save config 0x10: 0x38500004
[    5.127858] pcieport 0001:00:00.0: save config 0x14: 0x00000000
[    5.133767] pcieport 0001:00:00.0: save config 0x18: 0x00010100
[    5.139675] pcieport 0001:00:00.0: save config 0x1c: 0x000001f1
[    5.145584] pcieport 0001:00:00.0: save config 0x20: 0x38403840
[    5.151492] pcieport 0001:00:00.0: save config 0x24: 0x38313821
[    5.157401] pcieport 0001:00:00.0: save config 0x28: 0x00000000
[    5.163310] pcieport 0001:00:00.0: save config 0x2c: 0x00000000
[    5.169217] pcieport 0001:00:00.0: save config 0x30: 0x00000000
[    5.175129] pcieport 0001:00:00.0: save config 0x34: 0x00000080
[    5.181037] pcieport 0001:00:00.0: save config 0x38: 0x00000000
[    5.186946] pcieport 0001:00:00.0: save config 0x3c: 0x00020176
[    5.193789] FIT: Detected U-Boot 2024.10-OpenWrt-r28872-daca7c049b
[    5.199961] FIT: Selected configuration: "config-mt7988a-bananapi-bpi-r4" (OpenWrt bananapi_bpi-r4)
[    5.209047] FIT:           kernel sub-image 0x00001000..0x005635a9 "kernel-1" (ARM64 OpenWrt Linux-6.6.104)
[    5.218874] FIT:          flat_dt sub-image 0x00564000..0x0056fa15 "fdt-1" (ARM64 OpenWrt bananapi_bpi-r4 device tree blob)
[    5.230090] FIT:          flat_dt sub-image 0x00570000..0x00570609 "fdt-mt7988a-bananapi-bpi-r4-emmc" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-emmc)
[    5.246423] FIT:          flat_dt sub-image 0x00571000..0x0057111c "fdt-mt7988a-bananapi-bpi-r4-rtc" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-rtc)
[    5.262583] FIT:          flat_dt sub-image 0x00572000..0x005725c1 "fdt-mt7988a-bananapi-bpi-r4-sd" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-sd)
[    5.278569] FIT:          flat_dt sub-image 0x00573000..0x005738f0 "fdt-mt7988a-bananapi-bpi-r4-wifi-mt7996a" (ARM64 OpenWrt bananapi_bpi-r4 device tree overlay mt7988a-bananapi-bpi-r4-wifi-mt7996a)
[    5.296290] FIT:       filesystem sub-image 0x00574000..0x0104afff "rootfs-1" (ARM64 OpenWrt bananapi_bpi-r4 rootfs)
[    5.307170] block mmcblk0p7: mapped 1 uImage.FIT filesystem sub-image as /dev/fit0
[    5.314929] block mmcblk0p7: mapped remaining space as /dev/fitrw
[    5.444069] mtk_soc_eth 15100000.ethernet: generated random MAC address 65:74:68:25:64:00
[    5.457414] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc082a00000, irq 106
[    5.467118] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc082a00000, irq 106
[    5.476799] mtk_soc_eth 15100000.ethernet eth2: mediatek frame engine at 0xffffffc082a00000, irq 106
[    5.567367] mt7530-mmio 15020000.switch: configuring for fixed/internal link mode
[    5.574883] mt7530-mmio 15020000.switch: Link is Up - 10Gbps/Full - flow control rx/tx
[    5.601705] mt7530-mmio 15020000.switch wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7988 PHY] (irq=121)
[    5.639986] mt7530-mmio 15020000.switch lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7988 PHY] (irq=122)
[    5.678531] mt7530-mmio 15020000.switch lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7988 PHY] (irq=123)
[    5.716999] mt7530-mmio 15020000.switch lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7988 PHY] (irq=124)
[    5.727997] mtk_soc_eth 15100000.ethernet eth0: entered promiscuous mode
[    5.734712] DSA: tree 0 setup
[    5.737915] clk: Disabling unused clocks
[    5.747196] VFS: Mounted root (squashfs filesystem) readonly on device 259:0.
[    5.754442] Freeing unused kernel memory: 448K
[    5.758914] Run /sbin/init as init process
[    5.763003]   with arguments:
[    5.765959]     /sbin/init
[    5.768655]   with environment:
[    5.771784]     HOME=/
[    5.774136]     TERM=linux
[    5.905689] init: Console is alive
[    5.909195] init: - watchdog -
[    6.185277] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    6.207734] usbcore: registered new interface driver usbfs
[    6.213275] usbcore: registered new interface driver hub
[    6.218606] usbcore: registered new device driver usb
[    6.224176] gpio_button_hotplug: loading out-of-tree module taints kernel.
[    6.234045] xhci-mtk 11200000.usb: supply vbus not found, using dummy regulator
[    6.241455] xhci-mtk 11200000.usb: supply vusb33 not found, using dummy regulator
[    6.249347] xhci-mtk 11200000.usb: xHCI Host Controller
[    6.254579] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 1
[    6.264988] xhci-mtk 11200000.usb: hcc params 0x01403f99 hci version 0x110 quirks 0x0000000000200010
[    6.274212] xhci-mtk 11200000.usb: irq 125, io mem 0x11200000
[    6.280012] xhci-mtk 11200000.usb: xHCI Host Controller
[    6.285232] xhci-mtk 11200000.usb: new USB bus registered, assigned bus number 2
[    6.292622] xhci-mtk 11200000.usb: Host supports USB 3.2 Enhanced SuperSpeed
[    6.299951] hub 1-0:1.0: USB hub found
[    6.303761] hub 1-0:1.0: 1 port detected
[    6.307864] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    6.316150] hub 2-0:1.0: USB hub found
[    6.319904] hub 2-0:1.0: 1 port detected
[    6.326229] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    6.341921] init: - preinit -
[    6.564866] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[    6.573017] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[    6.586699] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
[    6.712681] usb 2-1: new SuperSpeed USB device number 2 using xhci-mtk
[    6.762162] hub 2-1:1.0: USB hub found
[    6.766055] hub 2-1:1.0: 4 ports detected
[    6.912567] usb 1-1: new high-speed USB device number 2 using xhci-mtk
[    7.106280] hub 1-1:1.0: USB hub found
[    7.113923] hub 1-1:1.0: 5 ports detected
[    7.812572] usb 1-1.5: new high-speed USB device number 3 using xhci-mtk
[    8.082570] random: crng init done
[   11.080469] F2FS-fs (fitrw): Mounted with checkpoint version = d70cae5
[   11.088972] mount_root: switching to f2fs overlay
[   11.095348] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[   11.107231] urandom-seed: Seeding with /etc/urandom.seed
[   11.150896] procd: - early -
[   11.153851] procd: - watchdog -
[   11.694752] procd: - watchdog -
[   11.698757] procd: - ubus -
[   11.852021] procd: - init -
[   12.092764] kmodloader: loading kernel modules from /etc/modules.d/*
[   12.116439] pca954x 1-0070: supply vdd not found, using dummy regulator
[   12.123702] i2c i2c-1: Added multiplexed i2c bus 2
[   12.128567] i2c i2c-1: Added multiplexed i2c bus 3
[   12.133439] i2c i2c-1: Added multiplexed i2c bus 4
[   12.138296] i2c i2c-1: Added multiplexed i2c bus 5
[   12.143134] pca954x 1-0070: registered 4 multiplexed busses for I2C switch pca9545
[   12.154037] crypto-safexcel 15600000.crypto: can't request region for resource [mem 0x15600000-0x1577ffff]
[   12.163768] crypto-safexcel 15600000.crypto: failed to get resource
[   12.170022] crypto-safexcel: probe of 15600000.crypto failed with error -16
[   12.179033] urngd: v1.0.2 started.
[   12.182623] at24 2-0050: supply vcc not found, using dummy regulator
[   12.214432] at24 2-0057: supply vcc not found, using dummy regulator
[   12.221377] at24 2-0057: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[   12.228441] Loading modules backported from Linux version v6.12.44-0-g11a24528d080
[   12.236021] Backport generated by backports.git v6.1.110-1-35-g410656ef
[   12.246100] sfp sfp1: Host maximum power 3.0W
[   12.250976] sfp sfp2: Host maximum power 3.0W
[   12.270245] mt7996e_hif 0001:01:00.0: assign IRQ: got 118
[   12.275692] mt7996e_hif 0001:01:00.0: enabling device (0000 -> 0002)
[   12.282066] mt7996e_hif 0001:01:00.0: enabling bus mastering
[   12.287903] mt7996e 0000:01:00.0: assign IRQ: got 115
[   12.292967] mt7996e 0000:01:00.0: enabling device (0000 -> 0002)
[   12.298983] mt7996e 0000:01:00.0: enabling bus mastering
[   12.402646] mtk-pcie-gen3 11300000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11300c00 data 1
[   12.411155] mtk-pcie-gen3 11310000.pcie: msi#0x1 address_hi 0x0 address_lo 0x11310c00 data 1
[   12.465554] mt7996e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20250904203308a
[   12.465554]
[   12.677248] mt7996e 0000:01:00.0: WM Firmware Version: ____000000, Build Time: 20250904203304
[   12.726362] mt7996e 0000:01:00.0: DSP Firmware Version: ____000000, Build Time: 20250904202814
[   12.777146] mt7996e 0000:01:00.0: WA Firmware Version: ____000000, Build Time: 20250904203218
[   13.238424] PPP generic driver version 2.4.2
[   13.243289] NET: Registered PF_PPPOX protocol family
[   13.249947] kmodloader: done loading kernel modules from /etc/modules.d/*
[   15.021960] mtk_soc_eth 15100000.ethernet eth0: Link is Down
[   15.045750] mtk_soc_eth 15100000.ethernet eth0: configuring for fixed/internal link mode
[   15.054027] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 10Gbps/Full - flow control rx/tx
[   15.056235] mt7530-mmio 15020000.switch lan1: configuring for phy/internal link mode
[   15.071097] br-lan: port 1(lan1) entered blocking state
[   15.076390] br-lan: port 1(lan1) entered disabled state
[   15.081652] mt7530-mmio 15020000.switch lan1: entered allmulticast mode
[   15.088298] mtk_soc_eth 15100000.ethernet eth0: entered allmulticast mode
[   15.095327] mt7530-mmio 15020000.switch lan1: entered promiscuous mode
[   15.107424] mt7530-mmio 15020000.switch lan2: configuring for phy/internal link mode
[   15.116436] br-lan: port 2(lan2) entered blocking state
[   15.121675] br-lan: port 2(lan2) entered disabled state
[   15.126989] mt7530-mmio 15020000.switch lan2: entered allmulticast mode
[   15.133828] mt7530-mmio 15020000.switch lan2: entered promiscuous mode
[   15.143356] mt7530-mmio 15020000.switch lan3: configuring for phy/internal link mode
[   15.151424] br-lan: port 3(lan3) entered blocking state
[   15.156737] br-lan: port 3(lan3) entered disabled state
[   15.162075] mt7530-mmio 15020000.switch lan3: entered allmulticast mode
[   15.168957] mt7530-mmio 15020000.switch lan3: entered promiscuous mode
[   15.177721] mtk_soc_eth 15100000.ethernet eth1: configuring for inband/10gbase-r link mode
[   15.209895] br-lan: port 4(eth1) entered blocking state
[   15.215254] br-lan: port 4(eth1) entered disabled state
[   15.220518] mtk_soc_eth 15100000.ethernet eth1: entered allmulticast mode
[   15.228104] mtk_soc_eth 15100000.ethernet eth1: entered promiscuous mode
[   15.237930] mt7530-mmio 15020000.switch wan: configuring for phy/internal link mode
[   15.247167] br-wan: port 1(wan) entered blocking state
[   15.252319] br-wan: port 1(wan) entered disabled state
[   15.257508] mt7530-mmio 15020000.switch wan: entered allmulticast mode
[   15.264211] mt7530-mmio 15020000.switch wan: entered promiscuous mode
[   15.273419] mtk_soc_eth 15100000.ethernet eth2: configuring for inband/10gbase-r link mode
[   15.305599] br-wan: port 2(eth2) entered blocking state
[   15.310840] br-wan: port 2(eth2) entered disabled state
[   15.316142] mtk_soc_eth 15100000.ethernet eth2: entered allmulticast mode
[   15.323099] mtk_soc_eth 15100000.ethernet eth2: entered promiscuous mode
[   18.429460] mt7530-mmio 15020000.switch lan3: Link is Up - 1Gbps/Full - flow control off
[   28.701672] br-lan: port 3(lan3) entered blocking state
[   28.706932] br-lan: port 3(lan3) entered forwarding state
[   29.049859] br-lan: port 5(phy0.1-ap0) entered blocking state
[   29.055685] br-lan: port 5(phy0.1-ap0) entered disabled state
[   29.061483] mt7996e 0000:01:00.0 phy0.1-ap0: entered allmulticast mode
[   29.068187] mt7996e 0000:01:00.0 phy0.1-ap0: entered promiscuous mode
[   29.074776] br-lan: port 5(phy0.1-ap0) entered blocking state
[   29.080525] br-lan: port 5(phy0.1-ap0) entered forwarding state
[   29.752620] br-lan: port 5(phy0.1-ap0) entered disabled state
[   29.818179] br-lan: port 5(phy0.1-ap0) entered blocking state
[   29.823922] br-lan: port 5(phy0.1-ap0) entered forwarding state
[   30.174990] br-lan: port 6(phy0.0-ap0) entered blocking state
[   30.180752] br-lan: port 6(phy0.0-ap0) entered disabled state
[   30.186575] mt7996e 0000:01:00.0 phy0.0-ap0: entered allmulticast mode
[   30.193264] mt7996e 0000:01:00.0 phy0.0-ap0: entered promiscuous mode
[   30.199817] br-lan: port 6(phy0.0-ap0) entered blocking state
[   30.205601] br-lan: port 6(phy0.0-ap0) entered forwarding state
[  188.159880] mt7996e 0000:01:00.0 phy0.1-ap0: left allmulticast mode
[  188.166251] mt7996e 0000:01:00.0 phy0.1-ap0: left promiscuous mode
[  188.172574] br-lan: port 5(phy0.1-ap0) entered disabled state
[  188.520488] br-lan: port 5(phy0.1-ap0) entered blocking state
[  188.526286] br-lan: port 5(phy0.1-ap0) entered disabled state
[  188.532062] mt7996e 0000:01:00.0 phy0.1-ap0: entered allmulticast mode
[  188.538755] mt7996e 0000:01:00.0 phy0.1-ap0: entered promiscuous mode
[  188.545275] br-lan: port 5(phy0.1-ap0) entered blocking state
[  188.551013] br-lan: port 5(phy0.1-ap0) entered forwarding state
Just search about the 6dbm issue…there are many threads about this
https://docs.banana-pi.org/en/BPI-R4/BananaPi_BPI-R4_FAQ#_openwrt_mainline_image_txpower_low The latest solution provided on the official website. You can have a look.
Hello,
I tried this, and now the device does not even show up in iwlist:
BusyBox v1.37.0 (2025-11-28 23:46:36 UTC) built-in shell (ash)
  _______                     ________        __
 |       |.-----.-----.-----.|  |  |  |.----.|  |_
 |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
 |_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
 OpenWrt SNAPSHOT, r32142-66672e7021
 === WARNING! =====================================
 There is no root password defined on this device!
 Use the "passwd" command to set up a new password
 in order to prevent unauthorized SSH logins.
 OpenWrt recently switched to the "apk" package manager!
 OPKG Command           APK Equivalent      Description
 opkg install <pkg>     apk add <pkg>       Install a package
 opkg remove <pkg>      apk del <pkg>       Remove a package
 opkg upgrade           apk upgrade         Upgrade all packages
 opkg files <pkg>       apk info -L <pkg>   List package contents
 opkg list-installed    apk info            List installed packages
 opkg update            apk update          Update package lists
 opkg search <pkg>      apk search <pkg>    Search for packages
For more information visit:
https://openwrt.org/docs/guide-user/additional-software/opkg-to-apk-cheatsheet
root@OpenWrt:~# iw list
root@OpenWrt:~# lsmod | grep mt
cfg80211              323584  4 mt7915e,mt76_connac_lib,mt76,mac80211
mac80211              643072  3 mt7915e,mt76_connac_lib,mt76
mt76                   81920  2 mt7915e,mt76_connac_lib
mt76_connac_lib        49152  1 mt7915e
mt7915e               139264  0
usbcore               196608  4 xhci_plat_hcd,xhci_pci,xhci_mtk_hcd,xhci_hcd
xhci_hcd              135168  3 xhci_plat_hcd,xhci_pci,xhci_mtk_hcd
xhci_mtk_hcd           20480  0
root@OpenWrt:~# dmesg | grep -i mediatek
[    4.846931] mtk_soc_eth 15100000.ethernet eth0: mediatek frame engine at 0xffffffc086580000, irq 105
[    4.856583] mtk_soc_eth 15100000.ethernet eth1: mediatek frame engine at 0xffffffc086580000, irq 105
[    4.866210] mtk_soc_eth 15100000.ethernet eth2: mediatek frame engine at 0xffffffc086580000, irq 105
[    5.009528] mt7530-mmio 15020000.switch wan (uninitialized): PHY [mt7530-0:00] driver [MediaTek MT7988 PHY] (irq=120)
[    5.047753] mt7530-mmio 15020000.switch lan1 (uninitialized): PHY [mt7530-0:01] driver [MediaTek MT7988 PHY] (irq=121)
[    5.085931] mt7530-mmio 15020000.switch lan2 (uninitialized): PHY [mt7530-0:02] driver [MediaTek MT7988 PHY] (irq=122)
[    5.124033] mt7530-mmio 15020000.switch lan3 (uninitialized): PHY [mt7530-0:03] driver [MediaTek MT7988 PHY] (irq=123)
root@OpenWrt:~#
Was it shown before? Is 12v switched on and what does lspci tell you? You have to load mt7996e module
Hello, Yes, when I downloaded the banana pi openwrt image the device showed up with iw list. I followed the instructions in the post, however I had to redo it again to include the mt7996e driver, but still the same problem. The instructions seem a little outdated as they’re using opkg, but I tried installing pciutils with apk and get this:
root@OpenWrt:~# apk add pciutils ERROR: unable to select packages: pciutils (no such package): required by: world[pciutils]
I was able to update the package list but it doesn’t see pciutils available in the the latest stable branch of openwrt?
And I’m also unsure about the openwrt banana pi image. https://downloads.openwrt.org/releases/24.10.4/targets/mediatek/filogic/openwrt-24.10.4-mediatek-filogic-bananapi_bpi-r4-sdcard.img.gz. I had tried this image first before I compiled openwrt manually, wouldn’t this image include the mentioned patch?
I was able to make progress by going back to an earlier release instead of the snapshot. Thank you.
