Tryed for the past week to have my banana pi m2 working on andriod (BPI-M2_Android-4.4_hdmi, 3.0)
Without any success. The only thing that i can see is the red led is light up.
Bought a extra power adapter so i used both the barrel dc and usb dc.
Dident change a thing!
Trying rebooting the device and restet no change.
Boots up fine with the other os/linux. But need andriod as it supports the xmbc…and a few other stuff.
Now iam out of ideas and getting pretty frustrated, buying a device iam unable to use.
So any ideas how i continue with this or should i just trash this board? and go for something that works…
XBMC not perfectly running on Android. Overheating problem for BananaPi M2. Video playing cut off. XBMC for M2 will be published when ? Is there a any work ?
I can see light blinking on the ethernet port but no connection and when i try to get i ip from therminal it looks like it takes it from wrong dhcp server? it should take it from 192.168.1.1 but takes it from 169. somthing… could it be that its hosting its own dhcp server? there for just gives itself a ip?tryed adding as a static ip does not work
Can you see the Banana Pi from the router home page? If it did take it from the wrong dhcp server, then the software configuration may be wrong. I guess honestly another OS would be my suggestion.
