rmandrad
(rmandrad)
November 5, 2025, 12:59pm
Hi
so I managed to install grub-efi, and add trixie
I have the boot and efi on mmc partitions, and the root on the nvme.
I have now a problem as that /boot and /efi both on the mmcblk0p5 & mmcblk0p5 can’t be found during boot (they are on fstab)
[DEPEND] Dependency failed for systemd-fsck…ile System Check on /dev/mmcblk0p5.
[DEPEND] Dependency failed for boot.mount - /boot.
[DEPEND] Dependency failed for local-fs.target - Local File Systems.
[DEPEND] Dependency failed for boot-efi.mount - /boot/efi.
[ TIME ] Timed out waiting for device dev-mmcblk0p6.device - /dev/mmcblk0p6.
[DEPEND] Dependency failed for systemd-fsck…ile System Check on /dev/mmcblk0p6.
any clues why this is happening ? thank you
all works fine if I boot via u-boot and fit image
ericwoud
(Eric W.)
November 5, 2025, 1:30pm
2
Is fsck.vfat installed? What is the output of
lsblk
rmandrad
(rmandrad)
November 5, 2025, 1:56pm
3
yes all is installed - as said if I use u-boot with fit all is fine … when I use grub-efi the mmc is not loaded
I check the dtb that is attached to the devicetree entry on grub and has the mmc …
frank-w
(Frank W.)
November 5, 2025, 2:15pm
4
Applied the sdmmc/emmc dts overlay?
rmandrad
(rmandrad)
November 5, 2025, 2:27pm
5
I have the devicetree on the grub entry and run u-boot using the following command
rungrub=setenv kaddr 0x48000000;setenv dtaddr 0x50000000; load mmc 0:6 0x48000000 EFI/BOOT/grubaa64.efi;load mmc 0:5 0x50000000 bpi-r4-new1.dtb;bootefi ${kaddr} ${dtaddr}
grub entry
menuentry 'Debian (EFI) test' --class debian --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-ccb30712-0dd6-447f-97de-d45ef39e3e76' {
load_video
gfxmode $linux_gfx_mode
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_gpt
insmod ext2
set root='hd0,gpt5'
insmod part_msdos
insmod fat
search --no-floppy --fs-uuid --set=root C6D9-D3B2
echo 'Loading Linux ...'
linux (hd0,gpt5)/Image.gz root=UUID=1c65c141-24ad-4de5-9bbf-623e26c53f51 rootfstype=ext4 rootwait console=ttyS0,115200n1 earlycon=uart8250,mmio32,0x11000000
echo 'Loading initial ramdisk ...'
initrd (hd0,gpt5)/initrd.img-6.17.0-bpi-r4-mda-main-gf81d87edf2f1-dirty
echo 'Loading Devicetree ...'
devicetree (hd0,gpt5)/bpi-r4-new1.dtb
ericwoud
(Eric W.)
November 5, 2025, 2:31pm
6
Can you check the contents of bpi-r4-new1.dtb, using the dtc tool to output in text format?
Dump it here in a code block?
rmandrad
(rmandrad)
November 5, 2025, 2:33pm
7
dtc -I dtb -O dts -o - bpi-r4-new1.dtb | grep -A4 -E 'mmc|sdhci|mmc@'
<stdout>: Warning (unit_address_vs_reg): /soc/t-phy@11c50000: node has a unit name, but no reg or ranges property
<stdout>: Warning (unit_address_vs_reg): /soc/xs-phy@11e10000: node has a unit name, but no reg or ranges property
<stdout>: Warning (simple_bus_reg): /soc/t-phy@11c50000: missing or empty reg/ranges property
<stdout>: Warning (simple_bus_reg): /soc/xs-phy@11e10000: missing or empty reg/ranges property
mmc0-emmc-45-pins {
phandle = <0x4b>;
mux {
function = "flash";
groups = "emmc_45";
mmc0-emmc-51-pins {
phandle = <0x4c>;
mux {
function = "flash";
groups = "emmc_51";
mmc0-sdcard-pins {
phandle = <0x4d>;
mux {
function = "flash";
mmc@11230000 {
compatible = "mediatek,mt7988-mmc";
reg = <0x00 0x11230000 0x00 0x1000 0x00 0x11d60000 0x00 0x1000>;
interrupts = <0x00 0x8f 0x04>;
clocks = <0x09 0x3f 0x09 0x40 0x09 0x42 0x09 0x41>;
assigned-clocks = <0x03 0x28 0x03 0x29>;
mmc0_pins_emmc_45 = "/soc/pinctrl@1001f000/mmc0-emmc-45-pins";
mmc0_pins_emmc_51 = "/soc/pinctrl@1001f000/mmc0-emmc-51-pins";
mmc0_pins_sdcard = "/soc/pinctrl@1001f000/mmc0-sdcard-pins";
spi0_flash_pins = "/soc/pinctrl@1001f000/spi0-flash-pins";
pwm = "/soc/pwm@10048000";
sgmiisys0 = "/soc/syscon@10060000";
sgmiipcs0 = "/soc/syscon@10060000/pcs";
mmc0 = "/soc/mmc@11230000";
pcie2 = "/soc/pcie@11280000";
pcie_intc2 = "/soc/pcie@11280000/interrupt-controller";
pcie3 = "/soc/pcie@11290000";
pcie_intc3 = "/soc/pcie@11290000/interrupt-controller";
ericwoud
(Eric W.)
November 5, 2025, 2:35pm
8
Please show the entire (or full mmc node) output?
rmandrad
(rmandrad)
9
let me know if you want the entire dtb …
ericwoud
(Eric W.)
November 5, 2025, 2:36pm
10
mmcblk0 is not listed with lsblk?
rmandrad
(rmandrad)
November 5, 2025, 2:54pm
12
mmc@11230000 {
assigned-clock-parents = <0x03 0x11 0x1c 0x0b>;
clock-names = "source", "hclk", "axi_cg", "ahb_cg";
#address-cells = <0x01>;
#size-cells = <0x00>;
status = "disabled";
max-frequency = <0x3197500>;
phandle = <0x5f>;
ericwoud
(Eric W.)
November 5, 2025, 2:57pm
14
rmandrad:
This may explain it a bit.
The emmc overlay has not been applied. You can use the fdtoverlay command.
rmandrad
(rmandrad)
November 5, 2025, 3:32pm
15
ericwoud:
fdtoverlay
but this is exactly the same dtb i am using for u-boot and mmc show’s up there
rmandrad
(rmandrad)
November 5, 2025, 3:52pm
16
ok so would it be something like ?
fdtoverlay -v -i bpi-r4-new1.dtb -o bpi-r4-new1-emmc-merged.dtb mt7988a-bananapi-bpi-r4-emmc.dtbo
ericwoud
(Eric W.)
November 5, 2025, 4:06pm
17
Looks ok, just examine the result with dtc to text as you did before…
ericwoud
(Eric W.)
November 5, 2025, 4:35pm
18
Athough I really appreciate the efforts and there is also much to gain, I do believe it is a more simple setup to enable distroboot in U-Boot. You can have ATF+U-Boot in emmc or nand and the boot partition on the nvme, or even just a boot folder on the rootfs, if it is btrfs, using just 1 partition in total on nvme. Distroboot should also support loading and applying the overlay by U-Boot (although I am already using the fdtoverlay command, because of other bootchain options.)
extlinux.conf also gives you a menu
See:;
Here is some instruction how to change U-Boot to use distroboot instead.
Copy this file:
[root@bpir3 ~]# cat include/configs/mt7xxx.h
/* SPDX-License-Identifier: GPL-2.0 */
* Configuration for MediaTek MT7622/MT7986 SoC
#ifndef __MT7XXX_H
#define __MT7XXX_H
/* Uboot definition */
#define CFG_SYS_UBOOT_BASE CONFIG_TEXT_BASE
/* SPL -> Uboot */
#define CFG_SYS_UBOOT_START CONFIG_TEXT_BASE
/* DRAM */
#define CFG_SYS_SDRAM_BASE 0x40000000
/* This is needed for kernel booting */…
