Build U-Boot that boots with menu from extlinux.conf or boot.scr
Here is some instruction how to change U-Boot to use distroboot instead.
Currently tested on R64 , R3, R3mini and R4.
Copy this file:
Apply this patch:
Append this to emmc-defconfig:
Apply patch to add pcie support if you want to use nvme and it is not part of your U-Boot version.
And build U-Boot, install it on nand or emmc.
When booting, your emmc, nvme, sata and nand-ubifs are scanned for an extlinux.conf file. For emmc/nvme/sata two options:
  1. Separate boot partition, fat32 formatted and any rootfs partition supported by your linux. Set the boot flag of the bootpartition. Edit /extlinux/extlinux.conf on the bootpartition.
  2. Only 1 partition, btrfs formatted, with a /boot/ folder. Set the boot flag of this partition. Edit /boot/extlinux/extlinux.conf on this partition.
Set the bootflag of nvme0n1p1 with:
parted /dev/nvme0n1 set 1 boot on
Example extlinux.conf:
[root@bpir3 ~]# cat /boot/extlinux/extlinux.conf
DEFAULT linux-bpir-git
  MENU title U-Boot menu
  PROMPT 0
  TIMEOUT 50
LABEL linux-bpir-git
  MENU LABEL Archlinux ARM for BananaPi Routers
  LINUX /boot/Image
  INITRD /boot/initramfs-bpir.img
  FDT /boot/dtbs/mt7986a-bananapi-bpi-r3-plus-emmc.dtb
For option 1. remove ‘/boot’ from the path in extlinux.conf
This FDT has already overlays applied and cmdline appended, but extlinux.conf does also support:
  FDTOVERLAYS /boot/dtbs/xxxxxxx.dtbo
And support:
  APPEND root=/dev/mmcblk0p3
Or any other cmdline options you wish to add.
Then you can enter a second label (menu entry) with, for example, the same files and different cmdline options. Or perhaps an entry with a different initrd image or a different kernel image.
If you don’t want to use extlinux.conf, you can save a /boot/boot.scr file instead. It is build in for backwards compatibility. See example howto create a bootscr for distroboot how to make one for distroboot.
boot.cmd
echo "Loaded boot.scr!"
if test -z "$bootargs"; then
    setenv bootargs root=/dev/mmcblk1p2 rootdelay=2
fi
echo "Loading device tree from ${devtype} ${devnum}:${distro_bootpart}..."
load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}dtbs/mt7986a-bananapi-bpi-r3-plus-emmc.dtb
echo "Loading kernel from ${devtype} ${devnum}:${distro_bootpart}..."
load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} ${prefix}Image.gz
echo "Booting with arguments: ${bootargs}"
booti ${kernel_addr_r} - ${fdt_addr_r}
Or:
boot.cmd
setenv ipaddr 192.168.1.8
setenv serverip 192.168.1.2
tftp ${fdt_addr_r} boot/dtbs/mt7986a-bananapi-bpi-r3-plus-emmc.dtb
tftp ${kernel_addr_r} boot/Image
tftp ${ramdisk_addr_r} boot/initramfs-bpir.img
setenv bootargs "root=/dev/mmcblk0p3"
booti ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r} ; reset
Then create /boot/boot scr with:
mkimage -C none -A arm64 -T script -d boot.cmd /boot/boot.scr
But extlinux.conf is the preferred method, boot.scr for backward compatibility.
Finally:
Prebuild binaries can be found in bpir-uboot-git-xxxxx.tar.xz archive from:
https://ftp.woudstra.mywire.org/repo/aarch64/
This is also part of my ArchLinuxARM image, where this U-Boot, together with linux initrd bash based rescue system, are installed to nand with the command bpir-toolbox --nand-format.
Based on the process of building my bpir-uboot-git package:
https://github.com/ericwoud/archlinuxarm-repo/blob/bpir-uboot-git/PKGBUILD
Patches for U-Boot 2025.04:
mt798x-pcie.patch
r4-nand.patch
This post may be corrected/amended later.
