however the the banchmark result looks too much positive than raspberry 3 b
M64 CPU test result total time 3.2352s ???
raspberry3 b CPU test result 45.7901s ( the result comes from http://www.eeboard.com/bbs/thread-47335-1-1.html)
I want to clarify whether the benchmark result is valid or there is something wrong makes the result even faster than a pc?
$ sudo sysbench --test=cpu --num-threads=4 run
sysbench 0.4.12: multi-threaded system evaluation benchmark
Running the test with following options:
Number of threads: 4
Doing CPU performance benchmark
Threads started!
Done.
Maximum prime number checked in CPU test: 10000
Test execution summary:
total time: 4.5504s
total number of events: 10000
total time taken by event execution: 18.1898
per-request statistics:
min: 1.81ms
avg: 1.82ms
max: 5.21ms
approx. 95 percentile: 1.82ms
Threads fairness:
events (avg/stddev): 2500.0000/4.12
execution time (avg/stddev): 4.5474/0.00
I’m running Armbian arm64 on it.
I use the SD Card as main hard drive because i do not have eMMC access.
It shows 10 times faster than raspberry pi 3, i also run the same benchmark on an Azure vm instance ( DS1 v2 (1 core, 3.5 GB memory)) it took around 9s to finish the test.
this keep me wondering whether the result is comparable …
