lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.4 LTS
Release: 22.04
Codename: jammy
I wanted to mount an external drive on SATA port, but it is mounting only every second start.
Trying to mount it manuel fails with hanging of the mount process.
dmesg -T shows the disk:
[So Feb 18 09:12:15 2024] scsi 0:0:0:0: Direct-Access ST500LT0 12-1DG142 0016 PQ: 0 ANSI: 4
[So Feb 18 09:12:15 2024] sd 0:0:0:0: Attached scsi generic sg0 type 0
[So Feb 18 09:12:15 2024] sd 0:0:0:0: [sda] 976773164 512-byte logical blocks: (500 GB/466 GiB)
[So Feb 18 09:12:15 2024] sd 0:0:0:0: [sda] Write Protect is off
[So Feb 18 09:12:15 2024] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[So Feb 18 09:12:15 2024] sd 0:0:0:0: [sda] No Caching mode page found
[So Feb 18 09:12:15 2024] sd 0:0:0:0: [sda] Assuming drive cache: write through
[So Feb 18 09:12:16 2024] sda: sda1
[So Feb 18 09:12:16 2024] sd 0:0:0:0: [sda] Attached SCSI disk
First i thought the drive has a damage, but other drives failed too.
Can anybody confirm that behavior ?
Some very old kernel that nobody knows much about … Try here for start: Bananapi M3 – Armbian Not warranty that it will work, but this is what you should try first.
Ok, i deleted the /dev/mmcblk2 and made a new partition with ext4 filesystem.
Then i have new Options in armbian-install named:
“Boot from eMMC - system on eMMC” but it gives me Errors:
Error: Could not stat device mmcblk2
/dev/mmcblk2 - No such file or directory.
mount: /mnt/armbian-install.cgBDNB/rootfs: special device mmcblk2
/dev/mmcblk2p1 does not exist.
mount: /mnt/armbian-install.cgBDNB/bootfs: special device mmcblk2
fdisk -l say:
Disk /dev/mmcblk2: 7,28 GiB, 7818182656 bytes, 15269888 sectors
Disklabel type: dos
Disk identifier: 0x8aa5ce97
Device Boot Start End Sectors Size Id Type
/dev/mmcblk2p1 2048 15269887 15267840 7,3G 83 Linux
But armbian-install is just a bash script, maybe i can find the error there.
Edit: After rebooting i can try one time with armbian-install, if it fails i have to reboot to give another try.
After deleting some big files. it is copying to eMMC now.
Finished, but not booting without SD.
I will use eMMC as Swap.
I tried again, but it does not work.
Then i choose boot from SD and system on SATA, this works.
Choosing boot on SD and system on eMMC works.
But not booting without SD.
I made dist-upgrade, Banana Pi hangs by installing u-boot.
No reaction, even with keyboard. I flash SD again, but now Banana Pi does not boot anymore.
Not from SD or other. I think, the upgrade killed something.
But thanks for your help.
