i always load it as a module … let me try your 6.18 repo
btw … probably the 6.18-crypto is not ready to load via the emmc …
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd090]
[ 0.000000] Linux version 6.18.0-rc1-bpi-r4-crypto-g38c2790e1ccd-dirty (aarch64-linux-gnu-gcc (Ubuntu 15.2.0-4ubuntu4) 15.2.0, GNU ld (GNU Binutils for Ubuntu) 2.45) #3 SMP Sun Nov 16 05:58:56 GMT 2025
[ 0.000000] Machine model: Banana Pi BPI-R4 (2x SFP+)
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000011000000 (options '')
[ 0.000000] printk: legacy bootconsole [uart8250] enabled
[ 0.000000] efi: EFI v2.11 by Das U-Boot
[ 0.000000] efi: RTPROP=0xfa7c5040 SMBIOS 3.0=0xffb09000 INITRD=0xfa4e8040 MEMRESERVE=0xfa4e7040
[ 0.000000] OF: reserved mem: 0x0000000042ff0000..0x0000000042ffffff (64 KiB) map non-reusable ramoops@42ff0000
[ 0.000000] OF: reserved mem: 0x0000000043000000..0x000000004304ffff (320 KiB) nomap non-reusable secmon@43000000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000023fffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000042ffffff]
[ 0.000000] node 0: [mem 0x0000000043000000-0x000000004304ffff]
[ 0.000000] node 0: [mem 0x0000000043050000-0x00000000fa3fffff]
[ 0.000000] node 0: [mem 0x00000000fa400000-0x00000000fa400fff]
[ 0.000000] node 0: [mem 0x00000000fa401000-0x00000000fa7c4fff]
[ 0.000000] node 0: [mem 0x00000000fa7c5000-0x00000000fa7c5fff]
[ 0.000000] node 0: [mem 0x00000000fa7c6000-0x00000000fa7c6fff]
[ 0.000000] node 0: [mem 0x00000000fa7c7000-0x00000000fa7e8fff]
[ 0.000000] node 0: [mem 0x00000000fa7e9000-0x00000000ffb08fff]
[ 0.000000] node 0: [mem 0x00000000ffb09000-0x00000000ffb09fff]
[ 0.000000] node 0: [mem 0x00000000ffb0a000-0x00000000ffedffff]
[ 0.000000] node 0: [mem 0x00000000ffee0000-0x00000000ffeeffff]
[ 0.000000] node 0: [mem 0x00000000ffef0000-0x00000000fffa2fff]
[ 0.000000] node 0: [mem 0x00000000fffa3000-0x00000000fffa4fff]
[ 0.000000] node 0: [mem 0x00000000fffa5000-0x000000023fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000023fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.5
[ 0.000000] percpu: Embedded 30 pages/cpu s84184 r8192 d30504 u122880
[ 0.000000] pcpu-alloc: s84184 r8192 d30504 u122880 alloc=30*4096
[ 0.000000] CPU features: detected: GICv3 CPU interface
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 858921
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: BOOT_IMAGE=(hd0,gpt5)/Image-bpi-r4_6.18.0-rc1-crypto.gz root=UUID=1c65c141-24ad-4de5-9bbf-623e26c53f51 rootfstype=ext4 rootwait console=ttyS0,9600n1 earlycon=uart8250,mmio32,0x11000000
[ 0.000000] printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbb09000-0x00000000ffb09000] (64MB)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2097152
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 416 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: GICD_CTLR.DS=0, SCR_EL3.FIQ=0
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000c080000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: Enabling local workaround for ARM erratum 858921
[ 0.000000] arch_timer: CPU0: Trapping CNTVCT access
[ 0.000000] arch_timer: cp15 timer running at 13.00MHz (phys).
[ 0.000000] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.095834] Console: colour dummy device 80x25
[ 0.148912] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.272682] pid_max: default: 32768 minimum: 301
[ 0.327912] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.418418] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.514619] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.587895] rcu: Hierarchical SRCU implementation.
[ 0.645101] rcu: Max phase no-delay instances is 1000.
[ 0.707599] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[ 0.804527] Remapping and enabling EFI services.
[ 0.859775] smp: Bringing up secondary CPUs ...
[ 0.914130] Detected VIPT I-cache on CPU1
[ 0.914174] GICv3: CPU1: found redistributor 1 region 0:0x000000000c0a0000
[ 0.914184] arch_timer: Enabling local workaround for ARM erratum 858921
[ 0.914198] arch_timer: CPU1: Trapping CNTVCT access
[ 0.914204] CPU1: Booted secondary processor 0x0000000001 [0x411fd090]
[ 0.914502] Detected VIPT I-cache on CPU2
[ 0.914525] GICv3: CPU2: found redistributor 2 region 0:0x000000000c0c0000
[ 0.914531] arch_timer: Enabling local workaround for ARM erratum 858921
[ 0.914536] arch_timer: CPU2: Trapping CNTVCT access
[ 0.914541] CPU2: Booted secondary processor 0x0000000002 [0x411fd090]
[ 0.914807] Detected VIPT I-cache on CPU3
[ 0.914829] GICv3: CPU3: found redistributor 3 region 0:0x000000000c0e0000
[ 0.914835] arch_timer: Enabling local workaround for ARM erratum 858921
[ 0.914840] arch_timer: CPU3: Trapping CNTVCT access
[ 0.914844] CPU3: Booted secondary processor 0x0000000003 [0x411fd090]
[ 0.914882] smp: Brought up 1 node, 4 CPUs
[ 2.005854] SMP: Total of 4 processors activated.
[ 2.062020] CPU: All CPU(s) started at EL2
[ 2.110902] CPU features: detected: 32-bit EL0 Support
[ 2.172268] CPU features: detected: CRC32 instructions
[ 2.233637] CPU features: detected: PMUv3
[ 2.281511] alternatives: applying system-wide alternatives
[ 2.348412] Memory: 8111500K/8388608K available (15488K kernel code, 2882K rwdata, 5384K rodata, 1536K init, 376K bss, 272620K reserved, 0K cma-reserved)
[ 2.513491] devtmpfs: initialized
[ 2.555082] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 2.672639] posixtimers hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 2.761076] futex hash table entries: 1024 (65536 bytes on 1 NUMA nodes, total 64 KiB, linear).
[ 2.865117] 26304 pages in range for non-PLT usage
[ 2.865120] 517824 pages in range for PLT usage
[ 2.922369] pinctrl core: initialized pinctrl subsystem
[ 3.039129] SMBIOS 3.7.0 present.
[ 3.078664] DMI: mediatek mt7988-rfb/mt7988-rfb, BIOS 2025.10-bpi-gd5698ecbbec2-dirty 10/01/2025
[ 3.183713] DMI: Memory slots populated: 0/0
[ 3.235860] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 3.306989] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 3.392465] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 3.486252] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 3.582223] thermal_sys: Registered thermal governor 'fair_share'
[ 3.582226] thermal_sys: Registered thermal governor 'bang_bang'
[ 3.655031] thermal_sys: Registered thermal governor 'step_wise'
[ 3.726795] thermal_sys: Registered thermal governor 'user_space'
[ 3.798642] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 3.952601] ASID allocator initialised with 65536 entries
[ 4.017670] printk: legacy console [ramoops-1] enabled
[ 4.079408] pstore: Registered ramoops as persistent store backend
[ 4.153258] ramoops: using 0x10000@0x42ff0000, ecc: 0
[ 4.215352] /soc/interrupt-controller@c000000: Fixed dependency cycle(s) with /soc/interrupt-controller@c000000
[ 4.339517] /soc/pcie@11280000: Fixed dependency cycle(s) with /soc/pcie@11280000/interrupt-controller
[ 4.450937] /soc/pcie@11290000: Fixed dependency cycle(s) with /soc/pcie@11290000/interrupt-controller
[ 4.562329] /soc/pcie@11300000: Fixed dependency cycle(s) with /soc/pcie@11300000/interrupt-controller
[ 4.673716] /soc/pcie@11310000: Fixed dependency cycle(s) with /soc/pcie@11310000/interrupt-controller
[ 4.787404] iommu: Default domain type: Translated
[ 4.844652] iommu: DMA domain TLB invalidation policy: strict mode
[ 4.922110] SCSI subsystem initialized
[ 4.966943] libata version 3.00 loaded.
[ 5.012804] usbcore: registered new interface driver usbfs
[ 5.078350] usbcore: registered new interface driver hub
[ 5.141807] usbcore: registered new device driver usb
[ 5.202247] pps_core: LinuxPPS API ver. 1 registered
[ 5.261535] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 5.370750] PTP clock support registered
[ 5.417653] efivars: Registered efivars operations
[ 5.475964] vgaarb: loaded
[ 5.508470] clocksource: Switched to clocksource arch_sys_counter
[ 5.581505] VFS: Disk quotas dquot_6.6.0
[ 5.628356] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 5.713512] NET: Registered PF_INET protocol family
[ 5.772001] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 5.866058] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 5.968033] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 6.060620] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 6.155480] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 6.244717] TCP: Hash tables configured (established 65536 bind 65536)
[ 6.322824] UDP hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 6.404136] UDP-Lite hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 6.490748] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 6.558701] RPC: Registered named UNIX socket transport module.
[ 6.629451] RPC: Registered udp transport module.
[ 6.685618] RPC: Registered tcp transport module.
[ 6.741785] RPC: Registered tcp-with-tls transport module.
[ 6.807312] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 6.884806] PCI: CLS 0 bytes, default 64
[ 6.931727] Trying to unpack rootfs image as initramfs...
[ 6.996718] Initialise system trusted keyrings
[ 7.050016] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 7.127325] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 7.197362] NFS: Registering the id_resolver key type
[ 7.257780] Key type id_resolver registered
[ 7.307740] Key type id_legacy registered
[ 7.355656] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 7.375321] Freeing initrd memory: 19276K
[ 7.435773] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 7.435832] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 7.657115] cryptd: max_cpu_qlen set to 1000
[ 7.736096] Key type asymmetric registered
[ 7.784990] Asymmetric key parser 'x509' registered
[ 7.843270] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 7.931751] io scheduler mq-deadline registered
[ 7.985846] io scheduler kyber registered
[ 8.033713] io scheduler bfq registered
[ 8.080203] mtk-xsphy soc:xs-phy@11e10000: failed to get ref_clk(id-1)
**[ 8.165865] mtk-socinfo mtk-socinfo.0.auto: error -ENOENT: Failed to get socinfo data**
**[ 8.259522] mtk-socinfo mtk-socinfo.0.auto: probe with driver mtk-socinfo failed with error -2**
[ 8.381272] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 8.458449] printk: legacy console [ttyS0] disabled
[ 8.537068] 11000000.serial: ttyS0 at MMIO 0x11000000 (irq = 99, base_baud = 2500000) is a ST16650V2
[ 8.646321] printk: legacy console [ttyS0] enabled
[ 8.760744] printk: legacy bootconsole [uart8250] disabled
[ 8.895842] loop: module loaded
[ 8.935764] spi-nand spi0.0: Winbond SPI NAND was found.
[ 8.999253] spi-nand spi0.0: 256 MiB, block size: 128 KiB, page size: 2048, OOB size: 128
[ 9.097144] 2 fixed-partitions partitions found on MTD device spi0.0
[ 9.173409] Creating 2 MTD partitions on "spi0.0":
[ 9.230631] 0x000000000000-0x000000200000 : "bl2"
[ 9.289421] ftl_cs: FTL header not found.
[ 9.337896] 0x000000200000-0x000008000000 : "ubi"
[ 9.468284] ubi0: default fastmap pool size: 50
[ 9.522410] ubi0: default fastmap WL pool size: 25
[ 9.579622] ubi0: attaching mtd1
[ 10.044878] ubi0: scanning is finished
[ 10.094087] ubi0: attached mtd1 (name "ubi", size 126 MiB)
[ 10.159631] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 10.241801] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 10.322929] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 10.406139] ubi0: good PEBs: 1008, bad PEBs: 0, corrupted PEBs: 0
[ 10.478947] ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
[ 10.565272] ubi0: max/mean erase counter: 6/3, WL threshold: 4096, image sequence number: 0
[ 10.665119] ubi0: available PEBs: 0, total reserved PEBs: 1008, PEBs reserved for bad PEB handling: 40
[ 10.776412] ubi0: background thread "ubi_bgt0d" started, PID 893
it gets stuck with the ubi0
