Reliable USB3 - SATA bridge (for BPI-R4)
i use a BPI-R4 with OpenWrt as a router + NAS at home. it has a large HDD connected to it through one of those SATA-USB3 cables, but they are not reliable, or some enclosures require the press of a button to start.
after a few days the drive starts to have issues and it only recoveres if i power cycle the bridge.
i researched the issue with LLM’s, and the situation is dismal: many of the bridge chipsets are buggy, but it’s very hard to know which chipset is inside a bridge when i try to buy a good one. i already have 3 buggy ones.
even if i find some info about a bridge, it’s usually one of those standing bridges where the HDD must be plugged in in a standing position; i.e. optimized for hot-swap on table, not sitting stable on a shelf.
here’s my current understanding:
JMicron sucks!
  • usb id 152d:xxxx 0583 = JMS58x
Replace with a known-good bridge:
  • ASM1153E (best cheap stable option)
  • RTL9210 (very solid for SSD/HDD)
  • JMS578 only if firmware is known-good
i’d appreciate any help in how to buy a reliable bridge, and/or receive some known-good recommendations for a NAS setup.
Often the unreliability is related to power, not the chipset. Many of these bridges come with bad power adapters or the USB port does not provide enough power for the disk. Bridges that have only one power pin and internal regulators for the lower voltages built-in tend to work better.
I would bet on something like this: Delock Products 64188 Delock USB Type-C™ 3.2 Gen 2 to SATA Converter but don’t have this particular cable. This manufacturer also gives the chip type in the description of most products which comes handy when you have chips that you prefer or chips you want to avoid.
