prepare: (1) 1x 16GB SD card, or more than 16GB
(2) 1x udisk
(3) 1X SD card reader
(4) 1xUSB-Serial Connect line
(5) M64, 5V/2A DC
- Choosing image to download on PC:https://wiki.banana-pi.org/Banana_Pi_BPI-M64#Image_Release
For example: 2020-08-26-ubuntu-18.04-mate-desktop-bpi-m64-aarch64-sd-emmc.img
Installing Balena Ethche(burning tool) on your PC: https://www.balena.io/etcher/
Installing the SD card in card reader, then installing the card reader in PC. (if your SD card have no any other files in it. If not, we suggest to format the SD card firstly)
Opening Balena Ethche, please choose” Flash from file”,choose the image you download
Go on the next steps, choose sd card
Choose Flash
Flash complete
Removing card reader on PC
Download mobaxterm app on PC:https://mobaxterm.mobatek.net/
Installing SD card on board, connect USB-Serial Connect line from M64 to PC,and power on
Select the corresponding serial cable, if can’t find it, you need to download the driver, and then select the baud rate 115200
Observe whether the SD card is successfully booted, which proves that the board hardware is OK, and the burned image is also OK.
Connecting a Udisk to PC, copy your image to Udisk. After finished, removing it.
Connecting Udisk on M64’USB
Login: pi passwork: bananapi
The system automatically mounts the U disk and checks the partitions. Enter the command: lsblk
use command “bpi-copy xxx-emmc-xxx.img” to install image on Emmc, enter
For example: sudo bpi-copy /media/pi/7A4F-F486/020-08-26-ubuntu-18.04-mate-desktop-bpi-m64-aarch64-sd-emmc.img.zip
Writing password, start burning.
After completion, power off, pull out the card, and pull out the U disk. Then power on again to test whether the EMMC startup is successful.
If the system starts successfully and prompts for login, it proves that there is no problem.
