Read CPU temperature
Hello,
is there a possibility to read the current CPU temperature?
HI: Run command
cat /sys/class/thermal/thermal_zone0/temp
‘thermal_zone1’ works too (identical values).
But it’s rather useless to look into it from time to time since without a heatsink/fan you will experience throttling behaviour. I already prepared a RPi-Monitor template for A83T: http://linux-sunxi.org/User_talk:Tkaiser#Thermal_issues
It takes you 5 minutes to install RPi-Monitor on any of the Debian based images and then all that’s needed is to create a template with the contents of the link above saved as Allwinner_A83T.conf.
You could follow the steps I outlined for Allwinner’s H3. Just replace the template names: Allwinner_H3.conf --> Allwinner_A83T.conf and OrangePi_H3.conf --> BananaPi_M3.conf
In case you use RPi-Monitor (highly recommended since it gives you insights through visualisation – stuff otherwise being invisible) and in case you use SinoVoip’s Ubuntu 15.10 image I would not uncomment the “/etc/rpimonitor/template/swap.conf” line since you will end up with your system swapping to death.
The enabled irqbalanced does nothing useful on ARM – see below – and just wastes CPU ressources and eats up all your memory over time. And it would be nice if you can watch this through RPi-Monitor also :slight_smile:
Here is a fixed irqbalanced version for ARM: https://github.com/dv1/irqbalanced
But in my opinion it’s way better to assign IRQs manually to specific CPU cores, eg. by adding this to /etc/rc.local prior to “exit 0”
echo 2 >/proc/irq/$(awk -F":" '/usb2/ {print $1}' </proc/interrupts)/smp_affinity
echo 4 >/proc/irq/$(awk -F":" '/gmac0/ {print $1}' </proc/interrupts)/smp_affinity
echo 8 >/proc/irq/$(awk -F":" '/sunxi-mmc/ {print $1}' </proc/interrupts | head -n1)/smp_affinity
echo 16 >/proc/irq/$(awk -F":" '/sunxi-mmc/ {print $1}' </proc/interrupts | tail -n1)/smp_affinity
echo 32 >/proc/irq/$(awk -F":" '/dispaly/ {print $1}' </proc/interrupts)/smp_affinity
Just compare with
cat /proc/interrupts
before and after.
Can you send me a RPi-Monitor template for BananaPi (first version)? I want to install RPi-Monitor on my banana pi :wink:
Already included in the official distribution: https://github.com/XavierBerger/RPi-Monitor/blob/master/README_sunxi.md
I think it is included in 2.11, so I should install beta version of RPi-Monitor with BananaPi support. Am I correct?
