Problem with USB-OTG in U-Boot
I need to run musb controller in device mode but I am facing the following error:
=> usb start
starting USB...
No host cable detected: Bus usb@1c13000: Port not available.
=> fastboot 0
No USB device found
USB init failed: -19
What’s already been done:
Added dts files
--- sun8i-r40.dtsi ---
		usb_otg: usb@1c13000 {
			compatible = "allwinner,sun8i-h3-musb";
			reg = <0x01c13000 0x400>;
			clocks = <&ccu CLK_BUS_OTG>;
			resets = <&ccu RST_BUS_OTG>;
			interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>;
			interrupt-names = "mc";
			phys = <&usbphy 0>;
			phy-names = "usb";
			extcon = <&usbphy 0>;
			dr_mode = "otg";
			status = "disabled";
--- sun8i-v40-bananapi-m2-berry.dts ---
&usb_otg {
	status = "okay";
&usbphy {
	dr_mode = "peripheral";
	usb0_id_det-gpios = <&pio 8 4 GPIO_ACTIVE_HIGH>;
	usb0_vbus-supply = <&reg_vcc5v0>;
	status = "okay";
menuconfig includes the following settings
  • Enable driver model for USB Gadget
  • MUSB host mode support
  • MUSB gadget mode support
  • Enable sunxi OTG/DRC USB controller
  • Hardcode MUSB CONFIGDATA register
  • USB Gadget support
  • USB Gadget support in SPL
What’s wrong or what should I add?
Thanks in advance
The status is still disabled. Try changing it to enabled.
