One Wire Communication
Hi!
I Have a question about initializing the one-wire communication specifically for ws2812 led strips. So far I have tried the Neopixels library, the rpi-ws2812 library but with no luck. Can anyone help me how to get it working on the Banana Pi M2 Zero? And which pins I can use? I have already enabled w1-gpio in the armbian config menu, and also checked in /boot/armbianEnv.txt, where I added overlays=w1-gpio. I am using 5.15.89-sunxi with: PRETTY_NAME=“Debian GNU/Linux 10 (buster)” NAME=“Debian GNU/Linux” VERSION_ID=“10” VERSION=“10 (buster)” VERSION_CODENAME=buster ID=debian HOME_URL=“https://www.debian.org/” SUPPORT_URL=“https://www.debian.org/support” BUG_REPORT_URL=“https://bugs.debian.org/”
Thank you very much in advance!
did you try to search / ask on armbian forums?
No I did not try, since it does not seem to be an armbian specific problem. It seems more related to the Banana pi M2 Zero.
And what should be Armbian specific problem? :grinning:
Armbian and community around knows more about those chips then people that are putting chips on PCB and sell it to you. Low level interfaces, overlays, handling … its Armbian. And toolchain. But its probably hard to understand that? https://docs.armbian.com/#what-is-the-difference-between-armbian-and-debianubuntu What is not is - “Rpi library” you are mentioning. This is something adopted for Rpi (my guess / didn’t look into the code). If you want to communicate via one wire protocol peek into Armbian forums. I am running one temp sensor on Alliwinner H5 device (identical as this hardware, even its h3 and 32bit) … Armbian takes over after you attach power to the device. Once it boots up, its “just” a generic Debian like OS.
Dear Igor!
Thank you very much for your help. I will try asking around on the Armbian forums then.
