New hardware revision of R1?
The R1 in the current stage needs 2 minor changes for major improvement
  1. Power inlet - change to barrel jack 4,0 x 1,7mm
  • a small change on the PCB layout and BoM (bill of material)
  1. add a resistor - to disable frame forwarding by the switch in the unconfigured/booted state !
  • a small change in the BoM - R1308 with a 2k2 ohm resistor
et voila you have nice working Switch with SATA.
and 1 bigger improvement for WLAN.
  1. the current WLAN module RTL8192 is not worth the silicon. Replace it with: MT5572 wifi-modul
    I don’t know about re-certification - so it could become bigger.
If at least two of the three changes would be done by @noralee & @lionwang they would have two different Routers to sell - and one with the well supported Allwinner A20.
Well, compare the supported functions of R2 with this table for the A20:
Linux mainlining effort - linux-sunxi.org
thank you , good advice, we will think about it .
Hi @noralee,
Hi @lionwang,
Any chance that you think about such a hardware revision ?
Br, Tido
Hi @noralee,
Hi @lionwang,
Have you seen all the changes coming along from Bootlin https://bootlin.com ?
A hardware revision of R1 could be interesting for many - have ever read my ideas above ?
Br, Tido
yes ,we think about it , will change ,and do sample to test. so , we need to do CE,FCC,again.:slight_smile:
This would improve the HW at no cost, do you consider that for the next production batch ?
Hi @lionwang Hi @Nora
I see on your tour pictures that you still promote the BPi-R1, is there a HW update coming soon? Are you working on it ?
I haven’t heard from you a single word :frowning: In 2019, Kernel 4.20 with even more support for A20 is released… did you do one or two quick wins from my list at the top ?
Br, Tido
With this news New kernel patch brings 120MB/s SATA Write-Speed with Banana Pi's, it is even more worth time spending at my first post in this thread. None of your router SBCs have such a good mainline support as the A20
Did you already make some changes the R1 BillofMaterial?
Br, Tido
