Native compile issues
I have been trying to get the kernel and u-boot to compile natively on the BPi-M3 board since I don’t have a x86 machine any more, well no personal machine.
I noticed a lot of binary only software in the repository. gen_check_code’s equivalent is available on u-boot in /tools. But sadly I have issues to build that one natively too.
Any plans to make a version that will compile from scratch natively ? These boards are fast enough to be self sustained, sad to see the no source code binary only in the tree.
To get it to compile I’ve commented this gen_check_code arch/arm/mach-sunxi/pm/standby/Makefile line 102
Now My next problem is it seems the ‘/root/BPI-M3-bsp/linux-sunxi/modules/gpu/sgx544/android/kernel_mode/eurasia_km/eurasiacon/binary2_sunxi_linux_release/target/pvrsrvkm.ko’
Is missing, is this a binary blob I can get somewhere ?
I’m trying too. Not result for moment
I am trying on gentoo to use crossdev -S -t arm-softfloat-linux-gnueabi but the compiler created is still trying to build a hard float compiler/glibc. I will continue to try a bit later.
