M4Berry Installing Chromium Browser on Ubuntu
sudo apt update
sudo apt install chromium-browser
After installation, you need to install it again using Snap.
If Snap isn’t available,
sudo apt install snap
Then restart the Snap service.
sudo systemctl restart snapd
Then execute:
sudo snap install chromium
If you can’t install it, you can add a proxy to Snap and then reinstall it.
Note: The device with this IP address needs to use the same router as the M4 Berry and have port 7890 open.
sudo snapsetsystem proxy.http="http://xxx.xxx.xxx.xxx:7890"
sudo snapsetsystem proxy.https="http://xxx.xxx.xxx.xxx:7890"
After installation, you can open it using the command line.
Chromium
Clearing the proxy
sudo snap unset system proxy.http
sudo snap unset system proxy.https
