I’m assuming that as the M2 is pin-compatible with the Pi-Zero it should work with this LoRa board?
Would @BananaPi consider manufacturing that board again if there was enough demand?
we check this hardware, Lora module use SPI interface , BPI-M2 Zero is OK 。 but need to development SPI driver
@sinovoip is the M2 zero closed source hardware? I don’t find any design files or even Gerbers available? https://wiki.banana-pi.org/Banana_Pi_BPI-M2_ZERO#Hardware
