Hello friends! I have BPI-M2 Zero with H2+ chipset. I have tried to load various armbian images to BPI board from here: https://imola.armbian.com/archive/bananapim2zero/archive/ And list of images: Armbian_21.08.1_Bananapim2zero_bullseye_current_5.10.60.img Armbian_21.08.1_Bananapim2zero_buster_current_5.10.60.img Armbian_21.08.1_Bananapim2zero_focal_current_5.10.60.img Armbian_21.08.1_Bananapim2zero_hirsute_edge_5.13.12.img
The first three images freezing after the “Starting kernel…”, but last image
a few more information:
U-Boot SPL 2020.10-armbian (Aug 08 2021 - 14:47:26 +0200) DRAM: 512 MiB Trying to boot from MMC1 U-Boot 2020.10-armbian (Aug 08 2021 - 14:47:26 +0200) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Banana Pi BPI-M2-Zero DRAM: 512 MiB MMC: [email protected]: 0, [email protected]: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: [email protected] Out: [email protected] Err: [email protected] Net: No ethernet found. starting USB... No working controllers found Autoboot in 1 seconds switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3964 bytes read in 3 ms (1.3 MiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 202 bytes read in 3 ms (65.4 KiB/s) 11083717 bytes read in 558 ms (18.9 MiB/s) 8188608 bytes read in 398 ms (19.6 MiB/s) Found mainline kernel configuration 34099 bytes read in 10 ms (3.3 MiB/s) 4185 bytes read in 11 ms (371.1 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 45000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11083653 Bytes = 10.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Loading Ramdisk to 4956e000, end 49ffff85 ... OK Loading Device Tree to 494fd000, end 4956dfff ... OK Starting kernel ... [ 7.501840] thermal thermal_zone0: binding zone cpu_thermal with cdev cpufreq-cpu0 failed:-22 [ 8.007616] lima 1c40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19 [ 8.772483] debugfs: File 'Capture' in directory 'dapm' already present! [ 10.933143] Bluetooth: hci0: command 0xfc18 tx timeout [ 18.933167] Bluetooth: hci0: BCM: failed to write update baudrate (-110) [ 18.939974] Bluetooth: hci0: Failed to set baudrate
How I could understanding whats happened? Big thanks.
