It does not turn on, LED 1 red LED, what to do?
Hey, I got a parcel - banana bpi-m3 does not turn on, LED 1 red LED. Changed power supply 5V 2A 5V 2.5a. Connect to different monitors and TV does not work there is no signal from the device. What to do ?
what image are you use???
please use right way burn image to your SD card.
please tell me what kind of image is needed for 100% start.?
https://bananapi.gitbooks.io/bpi-m3/content/bpi-m3_quick_start.html
you can test android image at first.
thank you very much, downloading the image and check it now!
Did everything according to instructions, the download does not go lights 1 red LED. After 3 minutes extinguished.
Thank you ))) boot with the flash cards ubuntu 15.10 Android could not run.
OK ,you can use DC port power it . if not , write a mail to [email protected] , ask judy send a sample to you ,
