Hello, I have a problem with controlling the PIGPIO ports of the BPI-M2 Zero. Normally I use Node-Red but it doesn’t load RPI-GPIO nodes also does not work i can control PIGPIO ports with python
How can I make the PIGPIO ports control work?
Error: Welcome to Node-RED
13 Aug 13:17:20 - [info] Node-RED version: v0.20.7 13 Aug 13:17:20 - [info] Node.js version: v8.11.1 13 Aug 13:17:20 - [info] Linux 4.4.55-BPI-M2Z-Kernel arm LE 13 Aug 13:17:21 - [info] Palette editor disabled : npm command not found 13 Aug 13:17:21 - [info] Loading palette nodes 13 Aug 13:17:23 - [warn] rpi-gpio : Raspberry Pi specific node set inactive 13 Aug 13:17:30 - [info] Settings file : /root/.node-red/settings.js 13 Aug 13:17:30 - [info] Context store : ‘default’ [module=memory] 13 Aug 13:17:30 - [info] User directory : /root/.node-red 13 Aug 13:17:30 - [warn] Projects disabled : editorTheme.projects.enabled=false 13 Aug 13:17:30 - [info] Flows file : /root/.node-red/flows_bpi-iot-ros-ai.json 13 Aug 13:17:30 - [info] Creating new flow file 13 Aug 13:17:30 - [warn]
Information: Board: BPI-M2 Zero
System Install and upgrade 2020-04-10-raspbian-jessie-ap6212-bpi-m2z-sd-emmc.img.zip
Linux version 4.4.55-BPI-M2Z-Kernel (dangku@dangku-desktop) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP PREEMPT Fri Apr 10 16:05:55 HKT 2020
PRETTY_NAME=“Raspbian GNU/Linux 9 (stretch)” NAME=“Raspbian GNU/Linux” VERSION_ID=“9” VERSION=“9 (stretch)” VERSION_CODENAME=stretch ID=raspbian ID_LIKE=debian
processor : 0 model name : ARMv7 Processor rev 5 (v7l) BogoMIPS : 22.85 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 …(4 CPU)
