This is what I did
root@bpi-r2:~# modprobe wlan_gen2
[ 219.227826] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 219.266336] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 219.276124] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 219.284950] cfg80211: failed to load regulatory.db
[ 219.304175] [MTK-WIFI] WIFI_init: mtk_wmt_WIFI_chrdev driver(major 155) installed.
[ 220.816372] [WMT-STP-EXP][E]mtk_wcn_wmt_msgcb_reg(384):ERROR! mtk_wcn_wmt_msgcb_reg_f cb is null
root@bpi-r2:~# wmt_loader
init combo devic[ 243.928446] [WMT-DETECT][I]wmt_detect_open:open major 154 minor 0 (pid 481)
e
[ 243.936815] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191037),arg(0)
Opened combo dev[ 243.944428] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (1074034433),arg(30243)
ice
get device[ 243.953067] set current consys chipid (0x7623)
[ 243.958905] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191036),arg(30243)
set device id : [ 243.967550] [WMT-MOD-INIT][I]do_common_drv_init:start to do common driver init, chipid:0x00007623
30243
[ 243.984982] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[ 243.992513] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[ 243.999982] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
[ 244.010457] [WMT-MOD-INIT][I]do_common_drv_init:finish common driver init
[ 244.017353] [WCN-MOD-INIT][E]do_connectivity_driver_init(58):do common driver init failed, ret:-1
[ 244.026269] [WLAN-MOD-INIT][I]do_wlan_drv_init:CONFIG_MTK_COMBO_WIFI is not defined
do module init: [ 244.034492] [WMT-DETECT][I]wmt_detect_close:close major 154 minor 0 (pid 481)
30243
failed to init module
root@bpi-r2:~# /usr/bin/stp_uart_launcher -p /etc/firmware &
[1] 500
open device node[ 269.549738] [WMT-CORE][E]opfunc_hif_conf(874):WMT-CORE: WMT HIF info added
succeed.(Node:/[ 269.557929] vcn18: mode operation not allowed
dev/stpwmt, fd:3)
chip id is 0x7623
chiId:0x7623, setting to property(D?)
chiId:0x7623
run SOC chip flow
create pwr on thread ok
root@bpi-r2:~# [ 269.565295] [WMT-CONSYS-HW][E]mtk_wcn_consys_hw_reg_ctrl(290):Read CONSYS chipId(0xfffff093)
[ 269.667753] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[ 269.683691] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[ 269.691161] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
enter power on connsys flowpatch name pre-fix:ROMv2_lm_patch
fwVersion:0x8a00
/etc/firmware/ROMv2_lm_patch_1_0_hdr.bin
fw Ver in patch: 0x8a00
read patch info:0x22,0x00,0x06,0x00
gpatchnum = [2]
gdwonseq = [2]
/etc/firmware/ROMv2_lm_patch_1_1_hdr.bin
read patch info:0x21,0x00,0x0e,0xf0
gdwonseq = [1]
cmd(srh_patch) resp(ok)
[ 270.254157] [STP] mtk_wcn_stp_psm_enable:[W] STP Not Ready, Dont do Sleep/Wakeup
root@bpi-r2:~# ip a
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1504 qdisc pfifo_fast state UP group default qlen 1000
link/ether 6e:7f:c2:2b:84:d7 brd ff:ff:ff:ff:ff:ff
inet6 fe80::6c7f:c2ff:fe2b:84d7/64 scope link
3: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 16:e3:c9:da:46:30 brd ff:ff:ff:ff:ff:ff
4: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
link/sit 0.0.0.0 brd 0.0.0.0
5: wan@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
6: lan0@eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN group default qlen 1000
link/ether 08:00:00:00:00:01 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.11/24 brd 192.168.0.255 scope global lan0
7: lan1@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
8: lan2@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
9: lan3@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
10: aux@eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
root@bpi-r2:~#
Now that I found your release page, I will try with one from your CI
Steps I followed
Clean old folders
rm -rf BPI-BOOT
rm -rf BPI-ROOT
Get the build
wget https://github.com/frank-w/BPI-Router-Linux/releases/download/CI-BUILD-5.15-main-5.15.103-2023-03-18_2023/bpi-r2_5.15.103-main.tar.gz
gunzip bpi-r2_5.15.103-main.tar.gz
tar -xf bpi-r2_5.15.103-main.tar
Boot partition
mkdir -p boot
sudo mount /dev/sdb1 boot
sudo rm -r boot/bananapi/bpi-r2/linux
sudo cp -r BPI-BOOT/bananapi/bpi-r2/linux boot/bananapi/bpi-r2
sudo umount boot
Root partition
mkdir -p root
sudo mount /dev/sdb2 root
sudo rsync -a BPI-ROOT/ root
sudo umount root
Still no luck
root@bpi-r2:~# uname -a
Linux bpi-r2 5.15.103-bpi-r2-main #1 SMP Sat Mar 18 20:23:21 UTC 2023 armv7l GNU/Linux
root@bpi-r2:~# ip a
link/ether 56:4e:25:d7:d7:af brd ff:ff:ff:ff:ff:ff
inet6 fe80::544e:25ff:fed7:d7af/64 scope link
link/ether c2:6a:d1:00:27:97 brd ff:ff:ff:ff:ff:ff
root@bpi-r2:~# lsmod
Module Size Used by
spidev 20480 0
lima 61440 0
gpu_sched 40960 1 lima
pwm_mediatek 16384 0
spi_mt65xx 20480 0
mtk_pmic_keys 16384 0
ip_tables 24576 0
x_tables 36864 1 ip_tables
[ 384.043894] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 384.078283] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 384.085224] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 384.093926] cfg80211: failed to load regulatory.db
[ 384.113332] [MTK-WIFI] WIFI_init: mtk_wmt_WIFI_chrdev driver(major 155) installed.
[ 385.444029] [WMT-STP-EXP][E]mtk_wcn_wmt_msgcb_reg(384):ERROR! mtk_wcn_wmt_msgcb_reg_f cb is null
init combo devic[ 442.935929] [WMT-DETECT][I]wmt_detect_open:open major 154 minor 0 (pid 592)
e
[ 442.944354] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191037),arg(0)
Opened combo dev[ 442.951827] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (1074034433),arg(30243)
ice
get device[ 442.960522] set current consys chipid (0x7623)
[ 442.966322] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191036),arg(30243)
set device id : [ 442.975011] [WMT-MOD-INIT][I]do_common_drv_init:start to do common driver init, chipid:0x00007623
30243
[ 442.989877] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[ 442.997426] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[ 443.004856] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
[ 443.015111] [WMT-MOD-INIT][I]do_common_drv_init:finish common driver init
[ 443.022073] [WCN-MOD-INIT][E]do_connectivity_driver_init(58):do common driver init failed, ret:-1
[ 443.031039] [WLAN-MOD-INIT][I]do_wlan_drv_init:CONFIG_MTK_COMBO_WIFI is not defined
do module init: [ 443.039317] [WMT-DETECT][I]wmt_detect_close:close major 154 minor 0 (pid 592)
30243
[1] 609
open device node[ 455.307732] [WMT-CORE][E]opfunc_hif_conf(874):WMT-CORE: WMT HIF info added
succeed.(Node:/[ 455.315921] vcn18: mode operation not allowed
dev/stpwmt, fd:3)
chip id is 0x7623
chiId:0x7623
run SOC chip flow
root@bpi-r2:~# [ 455.323922] [WMT-CONSYS-HW][E]mtk_wcn_consys_hw_reg_ctrl(290):Read CONSYS chipId(0xfffff093)
[ 455.417182] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[ 455.433112] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[ 455.440592] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
fwVersion:0x8a00
gpatchnum = [2]
gdwonseq = [2]
gdwonseq = [1]
[ 456.002596] [STP] mtk_wcn_stp_psm_enable:[W] STP Not Ready, Dont do Sleep/Wakeup
root@bpi-r2:~# ip a
root@bpi-r2:~#
Since you mention the .80, I try this one.
Clean old folders
rm -rf BPI-BOOT
rm -rf BPI-ROOT
Get the build
wget https://github.com/frank-w/BPI-Router-Linux/releases/download/CI-BUILD-5.15-main-5.15.80-2022-11-28_1508/bpi-r2_5.15.80-main.tar.gz
gunzip bpi-r2_5.15.80-main.tar.gz
tar -xf bpi-r2_5.15.80-main.tar
Boot partition
mkdir -p boot
sudo umount boot
Root partition
mkdir -p root
sudo umount root
It still doesn’t work.
Linux bpi-r2 5.15.80-bpi-r2-main #1 SMP Mon Nov 28 15:08:19 UTC 2022 armv7l GNU/Linux
[ 135.731277] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 135.763721] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 135.770683] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 135.779383] cfg80211: failed to load regulatory.db
[ 135.799421] [MTK-WIFI] WIFI_init: mtk_wmt_WIFI_chrdev driver(major 155) installed.
[ 137.129955] [WMT-STP-EXP][E]mtk_wcn_wmt_msgcb_reg(384):ERROR! mtk_wcn_wmt_msgcb_reg_f cb is null
init combo devic[ 157.375853] [WMT-DETECT][I]wmt_detect_open:open major 154 minor 0 (pid 452)
e
[ 157.384348] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191037),arg(0)
Opened combo dev[ 157.391759] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (1074034433),arg(30243)
ice
get device[ 157.400432] set current consys chipid (0x7623)
[ 157.406252] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191036),arg(30243)
set device id : [ 157.414926] [WMT-MOD-INIT][I]do_common_drv_init:start to do common driver init, chipid:0x00007623
30243
[ 157.429727] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[ 157.437260] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[ 157.444686] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
[ 157.454973] [WMT-MOD-INIT][I]do_common_drv_init:finish common driver init
[ 157.461939] [WCN-MOD-INIT][E]do_connectivity_driver_init(58):do common driver init failed, ret:-1
[ 157.470918] [WLAN-MOD-INIT][I]do_wlan_drv_init:CONFIG_MTK_COMBO_WIFI is not defined
do module init: [ 157.479275] [WMT-DETECT][I]wmt_detect_close:close major 154 minor 0 (pid 452)
30243
[1] 473
open device node[ 186.257747] [WMT-CORE][E]opfunc_hif_conf(874):WMT-CORE: WMT HIF info added
succeed.(Node:/[ 186.266192] vcn18: mode operation not allowed
dev/stpwmt, fd:3)
chip id is 0x7623
chiId:0x7623
run SOC chip flow
root@bpi-r2:~# [ 186.273907] [WMT-CONSYS-HW][E]mtk_wcn_consys_hw_reg_ctrl(290):Read CONSYS chipId(0xfffff093)
[ 186.367209] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[ 186.383158] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[ 186.390631] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
fwVersion:0x8a00
gpatchnum = [2]
gdwonseq = [2]
gdwonseq = [1]
[ 186.951212] [STP] mtk_wcn_stp_psm_enable:[W] STP Not Ready, Dont do Sleep/Wakeup
root@bpi-r2:~# ip a
link/ether de:87:5b:45:b4:40 brd ff:ff:ff:ff:ff:ff
inet6 fe80::dc87:5bff:fe45:b440/64 scope link
link/ether 36:fe:97:44:1d:11 brd ff:ff:ff:ff:ff:ff
root@bpi-r2:~#
I don’t know what am I missing
