How to enable NFS in Kernel
[warn] Not starting NFS kernel daemon: no support in current kernel. … (warning).
any plans to enable this or is there something i can do to enable this myself?
i am using
armbian (support emmc) Version 1.0 Release date 09/12/2015 Default login pi/bananapi Kernel Version 3.4 MD5 110f29c44140d67fe7ffc3b8b73f3483
I need the same thing, Trying to compile the kernel natively with very little success at the moment.
HI: you can download BPI-M3-bsp. try again
Hello, When I try to run the ./build.sh natively, on the M3 boards I get an error with: arch/arm/mach-sunxi/pm/standby/gen_check_code: arch/arm/mach-sunxi/pm/standby/gen_check_code: cannot execute binary file /root/BPI-M3-bsp/linux-sunxi/arch/arm/mach-sunxi/pm/standby/Makefile:102: recipe for target ‘arch/arm/mach-sunxi/pm/standby/resume1.code’ failed make[3]: *** [arch/arm/mach-sunxi/pm/standby/resume1.code] Error 126
Is it possible to compile this kernel without a x86 machine ?
