Andrey
                (Andrey)
                    January 30, 2020,  9:48am
              41
              dtb-$(CONFIG_ARCH_MEDIATEK) += \
	mt2701-evb.dtb \
	mt6580-evbp1.dtb \
	mt6589-aquaris5.dtb \
	mt6592-evb.dtb \
#	mt7623a-rfb-emmc.dtb \
#	mt7623a-unielec-u7623-02-emmc-512m.dtb \
#	mt7623n-rfb-nand.dtb \
	mt7623n-bananapi-bpi-r2.dtb \
	mt8127-moose.dtb \
	mt8135-evbp1.dtb
dtb-$(CONFIG_ARCH_ZX) += zx296702-ad1.dtb
dtb-$(CONFIG_ARCH_ASPEED) += aspeed-bmc-opp-palmetto.dtb \
	aspeed-bmc-opp-romulus.dtb \
	aspeed-ast2500-evb.dtb
endif
Still not makes. Eroor:
g  -o /home/andrey/eMMC/banana-pi/openwrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/image-mt7623n-bananapi-bpi-r2.dtb /home/andrey/eMMC/banana-pi/openwrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/image-mt7623n-bananapi-bpi-r2.dtb.tmp
Error: /home/andrey/eMMC/banana-pi/openwrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/linux-4.14.167/arch/arm/boot/dts/mt7623.dtsi:389.25-26 syntax error
FATAL ERROR: Unable to parse input tree
make[5]: *** [Makefile:70: /home/andrey/eMMC/banana-pi/openwrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/image-mt7623a-unielec-u7623-02-emmc-512m.dtb] Error 1
make[5]: *** Waiting for unfinished jobs....
make[5]: *** [Makefile:70: /home/andrey/eMMC/banana-pi/openwrt/build_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/linux-mediatek_mt7623/image-mt7623n-bananapi-bpi-r2.dtb] Error 1
make[5]: Leaving directory '/home/andrey/eMMC/banana-pi/openwrt/target/linux/mediatek/image'
make[4]: *** [Makefile:19: install] Error 2
make[4]: Leaving directory '/home/andrey/eMMC/banana-pi/openwrt/target/linux/mediatek'
make[3]: *** [Makefile:13: install] Error 2
make[3]: Leaving directory '/home/andrey/eMMC/banana-pi/openwrt/target/linux'
time: target/linux/install#111.63#40.04#107.67
make[2]: *** [target/Makefile:25: target/linux/install] Error 2
make[2]: Leaving directory '/home/andrey/eMMC/banana-pi/openwrt'
make[1]: *** [target/Makefile:19: /home/andrey/eMMC/banana-pi/openwrt/staging_dir/target-arm_cortex-a7+neon-vfpv4_musl_eabi/stamp/.target_install] Error 2
make[1]: Leaving directory '/home/andrey/eMMC/banana-pi/openwrt'
make: *** [/home/andrey/eMMC/banana-pi/openwrt/include/toplevel.mk:227: world] Ошибка 2
                frank-w
                (Frank W.)
                    January 30, 2020, 10:02am
              42
              mhm
			     "mediatek,mt2701-apmixedsys",
			     "syscon";
		reg = <0 0x10209000 0 0x1000>;
		#clock-cells = <1>;
	hdmi_phy: phy@10209100 {
		compatible = "mediatek,mt7623-hdmi-phy",
			     "mediatek,mt2701-hdmi-phy";
		reg = <0 0x10209100 0 0x24>;
		clocks = <&apmixedsys CLK_APMIXED_HDMI_REF>;
		clock-names = "pll_ref";
		clock-output-names = "hdmitx_dig_cts";
		#clock-cells = <0>;
		#phy-cells = <0>;
		status = "disabled";
	rng: rng@1020f000 {
		compatible = "mediatek,mt7623-rng";
		reg = <0 0x1020f000 0 0x1000>;
i guess you miss hdmi related constants (if your line 389 matches mine)…
so try disabling all hdmi related stuff with /* … */
i think it’s easier to use openwrts dts(i) and only replace pcie related stuff
                Andrey
                (Andrey)
                    January 30, 2020, 10:44am
              43
              Comment out all hdmi stuff and compiled succesfully. But cpu stall again.
[   22.468477] INFO: rcu_preempt detected stalls on CPUs/tasks:
[   22.474101]  2-...: (0 ticks this GP) idle=02a/140000000000000/0 softirq=37/37 fqs=1051
[   22.482121]  (detected by 0, t=2102 jiffies, g=-281, c=-282, q=4)
[   22.488169] Sending NMI from CPU 0 to CPUs 2:
[   85.518475] INFO: rcu_preempt detected stalls on CPUs/tasks:
[   85.524092]  2-...: (0 ticks this GP) idle=02a/140000000000000/0 softirq=37/37 fqs=3673
[   85.532112]  (detected by 0, t=8407 jiffies, g=-281, c=-282, q=4)
[   85.538156] Sending NMI from CPU 0 to CPUs 2:
                frank-w
                (Frank W.)
                    January 30, 2020, 11:16am
              44
              Then any of openwrts changes causing cpu stall…afair i had not applied any special patches for pci,but i can look later when i’m at home…
Maybe try 4.19? have not yet found a way to enable this kernel… i see LINUX_4_19, but it has no available option to select via menuconfig, only platform depended “selected by”'s
i can enable if i select target=qemu virtual, but if i change back to mediatek arm it’s n again ;( @moore  how can we select 4.19 as kernel for r2?
$ git log --oneline -- drivers/pci/host/pcie-mediatek.c
38ee346ac1fe PCI: mediatek: Fix mtk_pcie_find_port() endpoint/port matching logic
d84c246b7360 PCI: mediatek: Use PCI_NUM_INTX
43e6409db64d PCI: mediatek: Add MSI support for MT2712 and MT7622
db271747a04d PCI: mediatek: Use bus->sysdata to get host private data
b099631df160 PCI: mediatek: Add controller support for MT2712 and MT7622
1eacd7b84e04 PCI: mediatek: Switch to use platform_get_resource_byname()
c681c93067b8 PCI: mediatek: Add a structure to abstract the controller generations
4f6f0460448d PCI: mediatek: Rename port->index and mtk_pcie_parse_ports()
e10b7a184ccf PCI: mediatek: Use readl_poll_timeout() to wait for Gen2 training
608fcac7ce31 PCI: mediatek: Explicitly request exclusive reset control
637cfacae96f PCI: mediatek: Add MediaTek PCIe host controller support
$ git log --oneline -- drivers/phy/mediatek/phy-mtk-tphy.c
4290940dcb07 phy: phy-mtk-tphy: use auto instead of force to bypass utmi signals
554a56fc83f6 phy: phy-mtk-tphy: fix NULL point of chip bank
cd4ec4b03dc1 phy: phy-mt65xx-usb3: add mediatek directory and rename file
                moore
                (moore liu)
                    January 30, 2020,  1:43pm
              45
              Change from 4.14 to 4.19 in this Makefile.
                Andrey
                (Andrey)
                    January 30, 2020,  3:51pm
              46
              In armbain kernel 4.19not allow two gmac on switch and totally lose routing abilities (all 4ports bridget together with one MAC address).  But everythin else works perfect. Lets try it on openwrt
Tonight i try to compile openwrt with 4.19 kernel and tomorrow check it onboard.
                Andrey
                (Andrey)
                    January 30, 2020,  3:53pm
              47
              Cant ‘make kernel_menuconfig’
SHELL= flock /home/andrey/eMMC/banana-pi/openwrt/tmp/.linux-4.19.tar.xz.flock -c '  	/home/andrey/eMMC/banana-pi/openwrt/scripts/download.pl "/home/andrey/eMMC/banana-pi/openwrt/dl" "linux-4.19.tar.xz" "" "" "@KERNEL/linux/kernel/v4.x"    '
Cannot find appropriate hash command, ensure the provided hash is either a MD5 or SHA256 checksum.
make[2]: *** [Makefile:20: /home/andrey/eMMC/banana-pi/openwrt/dl/linux-4.19.tar.xz] Error 255
make[2]: Leaving directory '/home/andrey/eMMC/banana-pi/openwrt/target/linux/mediatek'
make[1]: *** [Makefile:13: menuconfig] Error 2
make[1]: Leaving directory '/home/andrey/eMMC/banana-pi/openwrt/target/linux'
make: *** [/home/andrey/eMMC/banana-pi/openwrt/include/toplevel.mk:161: kernel_menuconfig] Ошибка 2
                frank-w
                (Frank W.)
                    January 30, 2020,  5:47pm
              48
              Try make clean before…was working in my test
                Andrey
                (Andrey)
                    January 31, 2020,  4:45am
              49
              andrey@andrey-notebook:~/eMMC/banana-pi/openwrt$ make clean
 make[1] clean
andrey@andrey-notebook:~/eMMC/banana-pi/openwrt$ make kernel_menuconfig -j5 V=s
make[1]: Entering directory '/home/andrey/eMMC/banana-pi/openwrt/scripts/config'
make[1]: Leaving directory '/home/andrey/eMMC/banana-pi/openwrt/scripts/config'
export MAKEFLAGS= ;make V=ss -C target/linux menuconfig
make[1]: Entering directory '/home/andrey/eMMC/banana-pi/openwrt/target/linux'
make[2]: Entering directory '/home/andrey/eMMC/banana-pi/openwrt/target/linux/mediatek'
mkdir -p /home/andrey/eMMC/banana-pi/openwrt/dl
                frank-w
                (Frank W.)
                    February 1, 2020,  6:41am
              50
              You could try this
http://support.easycwmp.org/view.php?id=345
do you have additional packages included? md5sum/shaXsum available?
Maybe “make defconfig” works…found it somewhere
                Andrey
                (Andrey)
                    February 3, 2020, 10:05am
              51
              in busybox-coreutils both md5 and sha256 packets is enabled. defconfig i do in first try, its not helps.
                frank-w
                (Frank W.)
                    February 3, 2020, 10:13am
              52
              i guess in your openwrt-folder something is cached and breaks kernel_menuconfig
for comparision my state:
$ git diff
diff --git a/target/linux/mediatek/Makefile b/target/linux/mediatek/Makefile
index 28101a70d9..4d7df98520 100644
--- a/target/linux/mediatek/Makefile
+++ b/target/linux/mediatek/Makefile
@@ -9,7 +9,7 @@ SUBTARGETS:=mt7622 mt7623 mt7629
 FEATURES:=squashfs nand ramdisk fpu
 MAINTAINER:=John Crispin <[email protected] >
-KERNEL_PATCHVER:=4.14
+KERNEL_PATCHVER:=4.19
 include $(INCLUDE_DIR)/target.mk
 DEFAULT_PACKAGES += \
this is shown when i run make kernel_menuconfig: openwrt_menuconfig.txt  (65,7 KB)
seems like openwrt knows no “make mrproper” to clean really all…maybe try clone it again in new folder, make change to 4.19 and try again
                Andrey
                (Andrey)
                    February 4, 2020,  6:01am
              53
              Build successfully in new folder. Looks like pci must work but only one gmac have in dts file. mt7623n-bananapi-bpi-r2.dts  (5.0 КБ) I reach board later and try to boot it with builded image. I guess it not be able to be a router with only one gmac.
                moore
                (moore liu)
                    February 4, 2020,  6:59am
              54
              Just bump to kernel 4.19 and you can try it again, thanks.
                Andrey
                (Andrey)
                    February 4, 2020, 11:26am
              55
              My image not boot at all
MMC read: dev # 1, block # 4096, count 24576 ... 24576 blocks read: OK
bootm flag=0, states=70f
## Booting kernel from Legacy Image at 84000000 ...
   Image Name:   ARM OpenWrt Linux-4.19.98
   Data Size:    2920073 Bytes = 2.8 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
Starting kernel ...
                Andrey
                (Andrey)
                    February 4, 2020, 11:29am
              56
              You mean i can git clone to new folder, make menuconfig to select my needed packages, kernel_menuconfig my bootargs, and it simple be working? Like normal openwrt-ready router?
                frank-w
                (Frank W.)
                    February 4, 2020, 11:39am
              57
              Looks like wron console cmdline…of there is ttyS0 uart2 needs to be first in mt7623.dtsi
Easiest way should be dropping ttyS0 from cmdline…then the alias/choosen for stdout should be used
                Andrey
                (Andrey)
                    February 4, 2020, 11:53am
              58
              Im already delete image and build folder. Now i trying to git clone new iteration. @Moore  say now it with 4.19 kernel already.
And yes, new kernel uses other tty pins. And for 4.19 bootargs for SD booting will be
earlyprintk console=ttyS2,115200n8 vmalloc=496M block2mtd.block2mtd=/dev/mmcblk1,65536,RootFs,5 mtdparts=RootFs:512k(mbr)ro,512k(uboot)ro,512k(config)ro,512k(factory)ro,32M(kernel),32M(recovery),1024M(rootfs),2048M(usrdata),-(bmtpool) rootfstype=squashfs,jffs2
                moore
                (moore liu)
                    February 4, 2020, 12:45pm
              59
              Yes, ethernet and pcie can wotk normally with kernel 4.19, thanks.
