U-Boot 2014.04-rc1 (Mar 05 2019 - 02:09:09)
g_nr_bank = 1.
g_total_rank_size = 0x80000000
DRAM: 2 GiB
WARNING: Caches not enabled
MMC: emmc: 0, sdcard: 1
booting from SD card
dev_num = 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
bootargs = board=bpi-r2 earlyprintk console=tty1 fbcon=map:0 console=ttyS0,115200 vmalloc=496M debug=7 initcall_debug=0 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
Net: Eth0
Uip activated
Hit any key to stop autoboot: 0
dev_num = 1
mmc1 is current device
dev_num = 1
MMC read: dev # 1, block # 4096, count 24576 ... 24576 blocks read: OK
bootm flag=0, states=70f
## Booting kernel from Legacy Image at 84000000 ...
Image Name: ARM OpenWrt Linux-4.14.167
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 7814049 Bytes = 7.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.167 (andrey@andrey-notebook) (gcc version 8.3.0 (OpenWrt GCC 8.3.0 r12138-1e3bfbafd3)) #0 SMP PREEMPT Sun Jan 26 22:00:26 2020
[ 0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Bananapi BPI-R2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] random: get_random_bytes called from start_kernel+0x8c/0x3f0 with crng_init=0
[ 0.000000] percpu: Embedded 15 pages/cpu s29708 r8192 d23540 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260974
[ 0.000000] Kernel command line: earlyprintk console=ttyS0,115200 vmalloc=496M block2mtd.block2mtd=/dev/mmcblk1,65536,RootFs,5 mtdparts=RootFs:512k(mbr)ro,512k(uboot)ro,512k(config)ro,512k(factory)ro,32M(ker2
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 1011520K/1048576K available (6144K kernel code, 177K rwdata, 1392K rodata, 18432K init, 234K bss, 37056K reserved, 0K cma-reserved, 516096K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe1000000 - 0xff800000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0800000 ( 520 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0900000 - 0xc1b00000 (18432 kB)
[ 0.000000] .data : 0xc1b00000 - 0xc1b2c400 ( 177 kB)
[ 0.000000] .bss : 0xc1b31410 - 0xc1b6bc58 ( 235 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000006] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.000017] Switching to timer-based delay loop, resolution 76ns
[ 0.000146] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 147020034397 ns
[ 0.000161] sched_clock: 32 bits at 13MHz, resolution 76ns, wraps every 165191050201ns
[ 0.000373] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.000388] pid_max: default: 32768 minimum: 301
[ 0.000512] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000526] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001102] CPU: Testing write buffer coherency: ok
[ 0.040016] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.060014] Hierarchical SRCU implementation.
[ 0.100072] smp: Bringing up secondary CPUs ...
[ 0.310509] smp: Brought up 1 node, 4 CPUs
[ 0.310523] SMP: Total of 4 processors activated (104.00 BogoMIPS).
[ 0.310531] CPU: All CPU(s) started in SVC mode.
[ 0.320513] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 3
[ 0.320722] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.320743] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.320926] pinctrl core: initialized pinctrl subsystem
[ 0.321575] NET: Registered protocol family 16
[ 0.321845] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.322523] No ATAGs?
[ 0.383604] usbcore: registered new interface driver usbfs
[ 0.383661] usbcore: registered new interface driver hub
[ 0.383730] usbcore: registered new device driver usb
[ 0.384858] clocksource: Switched to clocksource arch_sys_counter
[ 0.385875] NET: Registered protocol family 2
[ 0.386334] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.386378] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.386439] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.386537] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.386568] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.386733] NET: Registered protocol family 1
[ 0.511604] No memory allocated for crashlog
[ 0.511820] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.516106] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.516117] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.520675] bounce: pool size: 64 pages
[ 0.520697] io scheduler noop registered
[ 0.520706] io scheduler deadline registered (default)
[ 0.525559] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.526387] console [ttyS0] disabled
[ 0.546947] 11004000.serial: ttyS0 at MMIO 0x11004000 (irq = 194, base_baud = 1625000) is a ST16650V2
[ 1.031234] console [ttyS0] enabled
[ 1.035282] mtk_rng 1020f000.rng: registered RNG driver
[ 1.035426] random: fast init done
[ 1.044047] random: crng init done
[ 1.047472] loop: module loaded
[ 1.051250] mt6323-regulator mt6323-regulator: Chip ID = 0x2023
[ 1.066560] libphy: Fixed MDIO Bus: probed
[ 1.093915] mtk_soc_eth 1b100000.ethernet: chip id = 7623
[ 1.099494] libphy: mdio: probed
[ 1.102696] drivers/net/ethernet/mediatek/mtk_eth_soc.c:mtk_mdio_init[412]0 df143000
[ 1.110438] mtk_soc_eth 1b100000.ethernet: generated random MAC address f2:67:d8:64:44:ea
[ 1.128629] mtk_soc_eth 1b100000.ethernet: connected mac 0 to PHY at fixed-0:00 [uid=00000000, driver=Generic PHY]
[ 1.139342] mtk_soc_eth 1b100000.ethernet eth0: mediatek frame engine at 0xe10e0000, irq 204
[ 1.147764] mtk_soc_eth 1b100000.ethernet: generated random MAC address ca:21:8c:8d:87:b9
[ 1.166650] mtk_soc_eth 1b100000.ethernet: connected mac 1 to PHY at fixed-0:01 [uid=00000000, driver=Generic PHY]
[ 1.177348] mtk_soc_eth 1b100000.ethernet eth1: mediatek frame engine at 0xe10e0000, irq 204
[ 1.186781] xhci-mtk 1a1c0000.usb: xHCI Host Controller
[ 1.191991] xhci-mtk 1a1c0000.usb: new USB bus registered, assigned bus number 1
[ 1.202393] xhci-mtk 1a1c0000.usb: hcc params 0x01401198 hci version 0x96 quirks 0x0000000000210010
[ 1.211447] xhci-mtk 1a1c0000.usb: irq 202, io mem 0x1a1c0000
[ 1.217706] hub 1-0:1.0: USB hub found
[ 1.221459] hub 1-0:1.0: 1 port detected
[ 1.225700] xhci-mtk 1a1c0000.usb: xHCI Host Controller
[ 1.230891] xhci-mtk 1a1c0000.usb: new USB bus registered, assigned bus number 2
[ 1.238258] xhci-mtk 1a1c0000.usb: Host supports USB 3.0 SuperSpeed
[ 1.244626] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.253100] hub 2-0:1.0: USB hub found
[ 1.256874] hub 2-0:1.0: 1 port detected
[ 1.261490] xhci-mtk 1a240000.usb: xHCI Host Controller
[ 1.266720] xhci-mtk 1a240000.usb: new USB bus registered, assigned bus number 3
[ 1.277092] xhci-mtk 1a240000.usb: hcc params 0x01401198 hci version 0x96 quirks 0x0000000000210010
[ 1.286145] xhci-mtk 1a240000.usb: irq 203, io mem 0x1a240000
[ 1.292316] hub 3-0:1.0: USB hub found
[ 1.296083] hub 3-0:1.0: 1 port detected
[ 1.300278] xhci-mtk 1a240000.usb: xHCI Host Controller
[ 1.305491] xhci-mtk 1a240000.usb: new USB bus registered, assigned bus number 4
[ 1.312834] xhci-mtk 1a240000.usb: Host supports USB 3.0 SuperSpeed
[ 1.319212] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.327680] hub 4-0:1.0: USB hub found
[ 1.331432] hub 4-0:1.0: 1 port detected
[ 1.335760] i2c /dev entries driver
[ 1.340591] mtk-thermal 1100b000.thermal: Device not calibrated, using default calibration values
[ 1.350115] mtk-wdt 10007000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 1.358197] cpu cpu0: dummy supplies not allowed for exclusive requests
[ 1.365715] sdhci: Secure Digital Host Controller Interface driver
[ 1.371844] sdhci: Copyright(c) Pierre Ossman
[ 1.435377] mtk-msdc 11240000.mmc: Got CD GPIO
[ 1.490215] mmc0: new high speed MMC card at address 0001
[ 1.496210] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.501991] mmcblk0: mmc0:0001 8GTF4R 0 B
[ 1.506370] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[ 1.512575] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[ 1.520570] NET: Registered protocol family 10
[ 1.525781] mmcblk0gp0: mmc0:0001 8GTF4R partition 4 3.64 GiB
[ 1.525953] Segment Routing with IPv6
[ 1.533574] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (250:0)
[ 1.535179] NET: Registered protocol family 17
[ 1.543397] mmcblk0gp0: p1
[ 1.547023] 8021q: 802.1Q VLAN Support v1.8
[ 1.553691] ThumbEE CPU extension supported.
[ 1.557951] Registering SWP/SWPB emulation handler
[ 1.572501] mmc1: host does not support reading read-only switch, assuming write-enable
[ 1.572876] DSA: switch 0 0 parsed
[ 1.582849] mmc1: new high speed SDHC card at address 0002
[ 1.583870] DSA: tree 0 parsed
[ 1.592450] mmcblk1: mmc1:0002 N/A 7.44 GiB
[ 1.784039] libphy: dsa slave smi: probed
[ 1.788307] Generic PHY dsa-0.0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=dsa-0.0:00, irq=POLL)
[ 1.798888] Generic PHY dsa-0.0:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=dsa-0.0:01, irq=POLL)
[ 1.809538] Generic PHY dsa-0.0:02: attached PHY driver [Generic PHY] (mii_bus:phy_addr=dsa-0.0:02, irq=POLL)
[ 1.820018] Generic PHY dsa-0.0:03: attached PHY driver [Generic PHY] (mii_bus:phy_addr=dsa-0.0:03, irq=POLL)
[ 1.830511] Generic PHY dsa-0.0:04: attached PHY driver [Generic PHY] (mii_bus:phy_addr=dsa-0.0:04, irq=POLL)
[ 1.867051] 9 cmdlinepart partitions found on MTD device RootFs
[ 1.872928] Creating 9 MTD partitions on "RootFs":
[ 1.877840] 0x000000000000-0x000000080000 : "mbr"
[ 1.883046] 0x000000080000-0x000000100000 : "uboot"
[ 1.888329] 0x000000100000-0x000000180000 : "config"
[ 1.893651] 0x000000180000-0x000000200000 : "factory"
[ 1.899176] 0x000000200000-0x000002200000 : "kernel"
[ 1.904522] 0x000002200000-0x000004200000 : "recovery"
[ 1.910046] 0x000004200000-0x000044200000 : "rootfs"
[ 1.915499] mtd: device 6 (rootfs) set to be root filesystem
[ 1.922441] 1 squashfs-split partitions found on MTD device rootfs
[ 1.928593] 0x0000047a0000-0x000044200000 : "rootfs_data"
[ 1.934418] 0x000044200000-0x0000c4200000 : "usrdata"
[ 1.939869] 0x0000c4200000-0x0001dc400000 : "bmtpool"
[ 1.945346] block2mtd: mtd0: [RootFs] erase_size = 64KiB [65536]
[ 1.951443] hctosys: unable to open rtc device (rtc0)
[ 1.956604] clk: Not disabling unused clocks
[ 1.960877] vusb: disabling
[ 1.963650] vmc: disabling
[ 1.966358] vgp1: disabling
[ 1.969148] vcamaf: disabling
[ 1.990437] Freeing unused kernel memory: 18432K
[ 2.003154] init: Console is alive
[ 2.007334] init: - watchdog -
[ 2.018782] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 2.195158] raid6: int32x1 gen() 217 MB/s
[ 2.364955] raid6: int32x1 xor() 188 MB/s
[ 2.535084] raid6: int32x2 gen() 260 MB/s
[ 2.705004] raid6: int32x2 xor() 189 MB/s
[ 2.874942] raid6: int32x4 gen() 253 MB/s
[ 3.044962] raid6: int32x4 xor() 175 MB/s
[ 3.215112] raid6: int32x8 gen() 217 MB/s
[ 3.385065] raid6: int32x8 xor() 142 MB/s
[ 3.554886] raid6: neonx1 gen() 539 MB/s
[ 3.724905] raid6: neonx1 xor() 511 MB/s
[ 3.894907] raid6: neonx2 gen() 821 MB/s
[ 4.064883] raid6: neonx2 xor() 715 MB/s
[ 4.234879] raid6: neonx4 gen() 954 MB/s
[ 4.404881] raid6: neonx4 xor() 794 MB/s
[ 4.574921] raid6: neonx8 gen() 833 MB/s
[ 4.744861] raid6: neonx8 xor() 747 MB/s
[ 4.749092] raid6: using algorithm neonx4 gen() 954 MB/s
[ 4.754356] raid6: .... xor() 794 MB/s, rmw enabled
[ 4.759200] raid6: using neon recovery algorithm
[ 4.766894] xor: measuring software checksum speed
[ 4.864856] arm4regs : 1249.200 MB/sec
[ 4.964892] 8regs : 1083.200 MB/sec
[ 5.064866] 32regs : 911.600 MB/sec
[ 5.164851] neon : 1642.400 MB/sec
[ 5.168997] xor: using function: neon (1642.400 MB/sec)
[ 5.186119] Btrfs loaded, crc32c=crc32c-generic
[ 5.196064] SCSI subsystem initialized
[ 5.208973] usbcore: registered new interface driver usb-storage
[ 5.215094] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 5.228349] init: - preinit -
[ 5.289498] IPv6: ADDRCONF(NETDEV_UP): lan1: link is not ready
[ 6.315253] mt7530 3.switch lan1: Link is Down
[ 9.357040] procd: - early -
[ 9.359949] procd: - watchdog -
[ 10.029345] procd: - watchdog -
[ 10.033242] procd: - ubus -
[ 10.086405] procd: - init -
[ 10.204171] kmodloader: loading kernel modules from /etc/modules.d/*
[ 10.221107] RPC: Registered named UNIX socket transport module.
[ 10.222308] urngd: v1.0.2 started.
[ 10.227016] RPC: Registered udp transport module.
[ 10.235073] RPC: Registered tcp transport module.
[ 10.239735] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 10.254717] Installing knfsd (copyright (C) 1996 [email protected]).
[ 10.264991] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 10.275694] Loading modules backported from Linux version v5.4-rc8-0-gaf42d3466bdc
[ 10.283205] Backport generated by backports.git v5.4-rc8-1-0-g368e8c51
[ 10.290975] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.300788] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 10.323807] usbcore: registered new interface driver ums-alauda
[ 10.330554] usbcore: registered new interface driver ums-cypress
[ 10.337500] usbcore: registered new interface driver ums-datafab
[ 10.344206] usbcore: registered new interface driver ums-freecom
[ 10.350988] usbcore: registered new interface driver ums-isd200
[ 10.357716] usbcore: registered new interface driver ums-jumpshot
[ 10.364483] usbcore: registered new interface driver ums-karma
[ 10.371211] usbcore: registered new interface driver ums-sddr09
[ 10.378048] usbcore: registered new interface driver ums-sddr55
[ 10.384808] usbcore: registered new interface driver ums-usbat
[ 10.397124] xt_time: kernel timezone is -0000
[ 10.415559] Intel(R) Wireless WiFi driver for Linux
[ 10.420401] Copyright(c) 2003- 2015 Intel Corporation
[ 10.446860] PPP generic driver version 2.4.2
[ 10.452232] NET: Registered protocol family 24
[ 10.465657] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 15.680377] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.686268] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 15.693877] br-lan: port 1(lan0) entered blocking state
[ 15.699374] br-lan: port 1(lan0) entered disabled state
[ 15.705197] device lan0 entered promiscuous mode
[ 15.709792] device eth0 entered promiscuous mode
[ 15.716003] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 15.727883] br-lan: port 2(lan1) entered blocking state
[ 15.733120] br-lan: port 2(lan1) entered disabled state
[ 15.739318] device lan1 entered promiscuous mode
[ 15.746883] br-lan: port 3(lan2) entered blocking state
[ 15.752120] br-lan: port 3(lan2) entered disabled state
[ 15.758412] device lan2 entered promiscuous mode
[ 15.765706] br-lan: port 4(lan3) entered blocking state
[ 15.770940] br-lan: port 4(lan3) entered disabled state
[ 15.777561] device lan3 entered promiscuous mode
[ 15.791393] IPv6: ADDRCONF(NETDEV_UP): wan: link is not ready
[ 16.715485] mt7530 3.switch lan0: Link is Down
[ 16.795569] mt7530 3.switch wan: Link is Down
[ 16.800159] mt7530 3.switch lan3: Link is Down
[ 16.800502] mt7530 3.switch lan2: Link is Down
