It looks like working!
MMC read: dev # 1, block # 4096, count 24576 ... 24576 blocks read: OK
bootm flag=0, states=70f
## Booting kernel from Legacy Image at 84000000 ...
   Image Name:   ARM OpenWrt Linux-4.19.98
   Data Size:    2722566 Bytes = 2.6 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
Starting kernel ...
[    0.000000] Linux version 4.19.98 (andrey@andrey-notebook) (gcc version 8.3.0 (OpenWrt GCC 8.3.0 r12176-a09408fa57)) #0 SMP PREEMPT Tue Feb 4 11:23:48 2020
[    0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] OF: fdt: Machine model: Bananapi BPI-R2
[    0.000000] random: get_random_bytes called from start_kernel+0x7c/0x440 with crng_init=0
[    0.000000] percpu: Embedded 15 pages/cpu s30348 r8192 d22900 u61440
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 523117
[    0.000000] Kernel command line: earlyprintk console=ttyS2,115200 vmalloc=496M block2mtd.block2mtd=/dev/mmcblk1,65536,RootFs,5 mtdparts=RootFs:512k(mbr)ro,512k(uboot)ro,512k(config)ro,512k(factory)ro,32M(ker2
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 2068284K/2097148K available (6144K kernel code, 208K rwdata, 1496K rodata, 1024K init, 233K bss, 28864K reserved, 0K cma-reserved, 1564668K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xe1000000 - 0xff800000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0800000   ( 520 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (7136 kB)
[    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 209 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 234 kB)
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000005] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[    0.000017] Switching to timer-based delay loop, resolution 76ns
[    0.000170] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 147020034397 ns
[    0.000185] sched_clock: 32 bits at 13MHz, resolution 76ns, wraps every 165191050201ns
[    0.000456] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[    0.000470] pid_max: default: 32768 minimum: 301
[    0.000601] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000614] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001254] CPU: Testing write buffer coherency: ok
[    0.060043] Setting up static identity map for 0x80100000 - 0x80100060
[    0.080040] rcu: Hierarchical SRCU implementation.
[    0.120103] smp: Bringing up secondary CPUs ...
[    0.360580] smp: Brought up 1 node, 4 CPUs
[    0.360593] SMP: Total of 4 processors activated (104.00 BogoMIPS).
[    0.360600] CPU: All CPU(s) started in SVC mode.
[    0.370586] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 3
[    0.370891] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.370912] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.371125] pinctrl core: initialized pinctrl subsystem
[    0.371836] NET: Registered protocol family 16
[    0.372125] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.372955] No ATAGs?
[    0.442493] usbcore: registered new interface driver usbfs
[    0.442547] usbcore: registered new interface driver hub
[    0.442613] usbcore: registered new device driver usb
[    0.443839] clocksource: Switched to clocksource arch_sys_counter
[    0.444849] NET: Registered protocol family 2
[    0.445469] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.445498] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.445540] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[    0.445600] TCP: Hash tables configured (established 4096 bind 4096)
[    0.445700] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.445731] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.445910] NET: Registered protocol family 1
[    0.446959] No memory allocated for crashlog
[    0.447109] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    0.451819] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.451832] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.456662] bounce: pool size: 64 pages
[    0.456686] io scheduler noop registered
[    0.456695] io scheduler deadline registered (default)
[    0.463065] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.484178] 11002000.serial: ttyS0 at MMIO 0x11002000 (irq = 194, base_baud = 1625000) is a ST16650V2
[    0.504749] 11003000.serial: ttyS1 at MMIO 0x11003000 (irq = 195, base_baud = 1625000) is a ST16650V2
[    0.525259] 11004000.serial: ttyS2 at MMIO 0x11004000 (irq = 196, base_baud = 1625000) is a ST16650V2
[    1.026624] console [ttyS2] enabled
[    1.030610] mtk_rng 1020f000.rng: registered RNG driver
[    1.030753] random: fast init done
[    1.039399] random: crng init done
[    1.039734] loop: module loaded
[    1.046678] mt6323-regulator mt6323-regulator: Chip ID = 0x2023
[    1.062487] libphy: Fixed MDIO Bus: probed
[    1.089609] libphy: mdio: probed
[    1.092983] mt7530 mdio-bus:00: Linked as a consumer to regulator.6
[    1.099283] mt7530 mdio-bus:00: Linked as a consumer to regulator.17
[    1.105739] mt7530 mdio-bus:00: Dropping the link to regulator.17
[    1.111845] mt7530 mdio-bus:00: Dropping the link to regulator.6
[    1.117938] mtk_soc_eth 1b100000.ethernet: generated random MAC address b2:a2:bb:d1:f3:9d
[    1.126553] mtk_soc_eth 1b100000.ethernet: connected mac 0 to PHY at fixed-0:00 [uid=00000000, driver=Generic PHY]
[    1.137290] mtk_soc_eth 1b100000.ethernet eth0: mediatek frame engine at 0xe10e0000, irq 207
[    1.145713] netif_napi_add() called with weight 256 on device
[    1.152234] xhci-mtk 1a1c0000.usb: Linked as a consumer to regulator.3
[    1.158798] xhci-mtk 1a1c0000.usb: Linked as a consumer to regulator.2
[    1.165501] xhci-mtk 1a1c0000.usb: xHCI Host Controller
[    1.170703] xhci-mtk 1a1c0000.usb: new USB bus registered, assigned bus number 1
[    1.181151] xhci-mtk 1a1c0000.usb: hcc params 0x01401198 hci version 0x96 quirks 0x0000000000210010
[    1.190199] xhci-mtk 1a1c0000.usb: irq 204, io mem 0x1a1c0000
[    1.196626] hub 1-0:1.0: USB hub found
[    1.200380] hub 1-0:1.0: 1 port detected
[    1.204628] xhci-mtk 1a1c0000.usb: xHCI Host Controller
[    1.209819] xhci-mtk 1a1c0000.usb: new USB bus registered, assigned bus number 2
[    1.217182] xhci-mtk 1a1c0000.usb: Host supports USB 3.0 SuperSpeed
[    1.223467] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.231953] hub 2-0:1.0: USB hub found
[    1.235716] hub 2-0:1.0: 1 port detected
[    1.240079] xhci-mtk 1a240000.usb: Linked as a consumer to regulator.3
[    1.246642] xhci-mtk 1a240000.usb: Linked as a consumer to regulator.2
[    1.253311] xhci-mtk 1a240000.usb: xHCI Host Controller
[    1.258535] xhci-mtk 1a240000.usb: new USB bus registered, assigned bus number 3
[    1.268967] xhci-mtk 1a240000.usb: hcc params 0x01401198 hci version 0x96 quirks 0x0000000000210010
[    1.278018] xhci-mtk 1a240000.usb: irq 205, io mem 0x1a240000
[    1.284406] hub 3-0:1.0: USB hub found
[    1.288158] hub 3-0:1.0: 1 port detected
[    1.292363] xhci-mtk 1a240000.usb: xHCI Host Controller
[    1.297583] xhci-mtk 1a240000.usb: new USB bus registered, assigned bus number 4
[    1.304944] xhci-mtk 1a240000.usb: Host supports USB 3.0 SuperSpeed
[    1.311226] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.319826] hub 4-0:1.0: USB hub found
[    1.323574] hub 4-0:1.0: 1 port detected
[    1.327914] i2c /dev entries driver
[    1.332801] mtk-thermal 1100b000.thermal: Device not calibrated, using default calibration values
[    1.342340] mtk-wdt 10007000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[    1.350586] cpu cpu0: Linked as a consumer to regulator.4
[    1.356002] cpu cpu0: dummy supplies not allowed for exclusive requests
[    1.363595] sdhci: Secure Digital Host Controller Interface driver
[    1.369754] sdhci: Copyright(c) Pierre Ossman
[    1.374840] mtk-msdc 11230000.mmc: Linked as a consumer to regulator.2
[    1.381372] mtk-msdc 11230000.mmc: Linked as a consumer to regulator.1
[    1.413961] mtk-msdc 11240000.mmc: Got CD GPIO
[    1.418550] mtk-msdc 11240000.mmc: Linked as a consumer to regulator.2
[    1.448654] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.459531] NET: Registered protocol family 10
[    1.464863] Segment Routing with IPv6
[    1.468552] NET: Registered protocol family 17
[    1.469062] mmc0: new high speed MMC card at address 0001
[    1.478413] 8021q: 802.1Q VLAN Support v1.8
[    1.482652] ThumbEE CPU extension supported.
[    1.486058] mmc1: host does not support reading read-only switch, assuming write-enable
[    1.486909] Registering SWP/SWPB emulation handler
[    1.495403] mmcblk0: mmc0:0001 8GTF4R 0 B
[    1.504361] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[    1.510737] mmc1: new high speed SDHC card at address 0002
[    1.517077] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[    1.523468] mmcblk0gp0: mmc0:0001 8GTF4R partition 4 3.64 GiB
[    1.529778] mmcblk1: mmc1:0002 N/A   7.44 GiB
[    1.534751] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (250:0)
[    1.543404]  mmcblk0gp0: p1
[    1.571128] mtk-pcie 1a140000.pcie: PCI host bridge to bus 0000:00
[    1.577289] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x1a160000-0x1a16ffff])
[    1.586704] pci_bus 0000:00: root bus resource [mem 0x60000000-0x6fffffff]
[    1.593524] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.601125] PCI: bus0: Fast back to back transfers disabled
[    1.606674] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.614635] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.624676] PCI: bus1: Fast back to back transfers disabled
[    1.630350] pci 0000:02:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    1.637370] pci 0000:02:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[    1.644385] pci 0000:02:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[    1.651387] pci 0000:02:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[    1.658400] pci 0000:02:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[    1.667137] PCI: bus2: Fast back to back transfers disabled
[    1.672706] pci 0000:00:00.0: BAR 8: assigned [mem 0x60000000-0x600fffff]
[    1.679459] pci 0000:00:01.0: BAR 8: assigned [mem 0x60100000-0x601fffff]
[    1.686204] pci 0000:00:01.0: BAR 9: assigned [mem 0x60200000-0x602fffff pref]
[    1.693368] pci 0000:00:00.0: BAR 1: assigned [mem 0x60300000-0x6030ffff]
[    1.700116] pci 0000:00:01.0: BAR 1: assigned [mem 0x60310000-0x6031ffff]
[    1.706862] pci 0000:00:01.0: BAR 7: assigned [io  0x1000-0x1fff]
[    1.712908] pci 0000:01:00.0: BAR 0: assigned [mem 0x60000000-0x60001fff 64bit]
[    1.720187] pci 0000:00:00.0: PCI bridge to [bus 01]
[    1.725124] pci 0000:00:00.0:   bridge window [mem 0x60000000-0x600fffff]
[    1.731864] pci 0000:02:00.0: BAR 6: assigned [mem 0x60200000-0x6020ffff pref]
[    1.739041] pci 0000:02:00.0: BAR 5: assigned [mem 0x60100000-0x601001ff]
[    1.745788] pci 0000:02:00.0: BAR 4: assigned [io  0x1000-0x100f]
[    1.751834] pci 0000:02:00.0: BAR 0: assigned [io  0x1010-0x1017]
[    1.757893] pci 0000:02:00.0: BAR 2: assigned [io  0x1018-0x101f]
[    1.763951] pci 0000:02:00.0: BAR 1: assigned [io  0x1020-0x1023]
[    1.769997] pci 0000:02:00.0: BAR 3: assigned [io  0x1024-0x1027]
[    1.776054] pci 0000:00:01.0: PCI bridge to [bus 02]
[    1.780977] pci 0000:00:01.0:   bridge window [io  0x1000-0x1fff]
[    1.787032] pci 0000:00:01.0:   bridge window [mem 0x60100000-0x601fffff]
[    1.793765] pci 0000:00:01.0:   bridge window [mem 0x60200000-0x602fffff pref]
[    1.801099] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[    1.807310] pcieport 0000:00:00.0: Signaling PME with IRQ 217
[    1.813114] pcieport 0000:00:00.0: AER enabled with IRQ 217
[    1.818835] pcieport 0000:00:01.0: enabling device (0140 -> 0143)
[    1.824999] pcieport 0000:00:01.0: Signaling PME with IRQ 218
[    1.830811] pcieport 0000:00:01.0: AER enabled with IRQ 218
[    1.836618] mt7530 mdio-bus:00: Linked as a consumer to regulator.6
[    1.842895] mt7530 mdio-bus:00: Linked as a consumer to regulator.17
[    2.004057] libphy: dsa slave smi: probed
[    2.008206] mt7530 mdio-bus:00 wan (uninitialized): PHY [dsa-0.0:00] driver [Generic PHY]
[    2.017023] mt7530 mdio-bus:00 lan0 (uninitialized): PHY [dsa-0.0:01] driver [Generic PHY]
[    2.025831] mt7530 mdio-bus:00 lan1 (uninitialized): PHY [dsa-0.0:02] driver [Generic PHY]
[    2.034624] mt7530 mdio-bus:00 lan2 (uninitialized): PHY [dsa-0.0:03] driver [Generic PHY]
[    2.043412] mt7530 mdio-bus:00 lan3 (uninitialized): PHY [dsa-0.0:04] driver [Generic PHY]
[    2.054376] DSA: tree 0 setup
[    2.057847] 9 cmdlinepart partitions found on MTD device RootFs
[    2.063716] Creating 9 MTD partitions on "RootFs":
[    2.068628] 0x000000000000-0x000000080000 : "mbr"
[    2.073885] 0x000000080000-0x000000100000 : "uboot"
[    2.079183] 0x000000100000-0x000000180000 : "config"
[    2.084545] 0x000000180000-0x000000200000 : "factory"
[    2.090012] 0x000000200000-0x000002200000 : "kernel"
[    2.095384] 0x000002200000-0x000004200000 : "recovery"
[    2.100913] 0x000004200000-0x000044200000 : "rootfs"
[    2.106273] mtd: device 6 (rootfs) set to be root filesystem
[    2.113148] 1 squashfs-split partitions found on MTD device rootfs
[    2.119304] 0x0000047f0000-0x000044200000 : "rootfs_data"
[    2.125165] 0x000044200000-0x0000c4200000 : "usrdata"
[    2.130601] 0x0000c4200000-0x0001dc400000 : "bmtpool"
[    2.136079] block2mtd: mtd0: [RootFs] erase_size = 64KiB [65536]
[    2.142179] hctosys: unable to open rtc device (rtc0)
[    2.151811] VFS: Mounted root (squashfs filesystem) readonly on device 31:6.
[    2.159934] Freeing unused kernel memory: 1024K
[    2.164553] Run /sbin/init as init process
[    2.482571] init: Console is alive
[    2.486720] init: - watchdog -
[    3.475541] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    3.694050] raid6: int32x1  gen()   217 MB/s
[    3.863995] raid6: int32x1  xor()   188 MB/s
[    4.033921] raid6: int32x2  gen()   260 MB/s
[    4.203910] raid6: int32x2  xor()   189 MB/s
[    4.373952] raid6: int32x4  gen()   253 MB/s
[    4.544010] raid6: int32x4  xor()   175 MB/s
[    4.714027] raid6: int32x8  gen()   217 MB/s
[    4.884054] raid6: int32x8  xor()   142 MB/s
[    5.053934] raid6: neonx1   gen()   542 MB/s
[    5.223846] raid6: neonx1   xor()   511 MB/s
[    5.393896] raid6: neonx2   gen()   821 MB/s
[    5.563867] raid6: neonx2   xor()   715 MB/s
[    5.733894] raid6: neonx4   gen()   955 MB/s
[    5.903853] raid6: neonx4   xor()   795 MB/s
[    6.073880] raid6: neonx8   gen()   829 MB/s
[    6.243853] raid6: neonx8   xor()   747 MB/s
[    6.248083] raid6: using algorithm neonx4 gen() 955 MB/s
[    6.253347] raid6: .... xor() 795 MB/s, rmw enabled
[    6.258191] raid6: using neon recovery algorithm
[    6.266174] xor: measuring software checksum speed
[    6.363841]    arm4regs  :  1249.200 MB/sec
[    6.463852]    8regs     :  1082.800 MB/sec
[    6.563849]    32regs    :   911.600 MB/sec
[    6.663835]    neon      :  1634.000 MB/sec
[    6.667980] xor: using function: neon (1634.000 MB/sec)
[    6.745503] Btrfs loaded, crc32c=crc32c-generic
[    6.755392] SCSI subsystem initialized
[    6.765734] ahci 0000:02:00.0: enabling device (0140 -> 0143)
[    6.771538] ahci 0000:02:00.0: SSS flag set, parallel bus scan disabled
[    6.778174] ahci 0000:02:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl IDE mode
[    6.786247] ahci 0000:02:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs
[    6.795592] scsi host0: ahci
[    6.798833] scsi host1: ahci
[    6.801848] ata1: SATA max UDMA/133 abar m512@0x60100000 port 0x60100100 irq 218
[    6.809286] ata2: SATA max UDMA/133 abar m512@0x60100000 port 0x60100180 irq 218
[    7.145278] ata1: SATA link down (SStatus 0 SControl 300)
[    7.485279] ata2: SATA link down (SStatus 0 SControl 300)
[    7.493257] usbcore: registered new interface driver usb-storage
[    7.499419] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    7.507929] init: - preinit -
[    7.868065] mt7530 mdio-bus:00 lan1: configuring for phy/gmii link mode
[    7.874836] IPv6: ADDRCONF(NETDEV_UP): lan1: link is not ready
[   11.937678] mount_root: loading kmods from internal overlay
[   11.954344] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[   11.961828] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[   13.398914] block: attempting to load /etc/config/fstab
[   13.404909] block: unable to load configuration (fstab: Entry not found)
[   13.411588] block: no usable configuration
[   13.416153] mount_root: jffs2 not ready yet, using temporary tmpfs overlay
[   13.434811] urandom-seed: Seed file not found (/etc/urandom.seed)
[   13.491492] procd: - early -
[   13.494454] procd: - watchdog -
[   14.158207] procd: - watchdog -
[   14.162086] procd: - ubus -
[   14.237278] procd: - init -
[   14.484479] kmodloader: loading kernel modules from /etc/modules.d/*
[   14.499859] urngd: v1.0.2 started.
[   14.523356] RPC: Registered named UNIX socket transport module.
[   14.529326] RPC: Registered udp transport module.
[   14.534005] RPC: Registered tcp transport module.
[   14.538666] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   14.553374] Installing knfsd (copyright (C) 1996 [email protected]).
[   14.568232] Loading modules backported from Linux version v5.4-rc8-0-gaf42d3466bdc
[   14.575814] Backport generated by backports.git v5.4-rc8-1-0-g368e8c51
[   14.587243] usbcore: registered new interface driver ums-alauda
[   14.593676] usbcore: registered new interface driver ums-cypress
[   14.600262] usbcore: registered new interface driver ums-datafab
[   14.606790] usbcore: registered new interface driver ums-freecom
[   14.613316] usbcore: registered new interface driver ums-isd200
[   14.619925] usbcore: registered new interface driver ums-jumpshot
[   14.626613] usbcore: registered new interface driver ums-karma
[   14.633087] usbcore: registered new interface driver ums-sddr09
[   14.639626] usbcore: registered new interface driver ums-sddr55
[   14.646343] usbcore: registered new interface driver ums-usbat
[   14.655564] xt_time: kernel timezone is -0000
[   14.679577] Intel(R) Wireless WiFi driver for Linux
[   14.684465] Copyright(c) 2003- 2015 Intel Corporation
[   14.689655] iwlwifi 0000:01:00.0: enabling device (0140 -> 0142)
[   14.695850] iwlwifi 0000:01:00.0: pci_enable_msi failed - -22
[   14.740230] PPP generic driver version 2.4.2
[   14.754798] NET: Registered protocol family 24
[   14.771690] kmodloader: done loading kernel modules from /etc/modules.d/*
[   14.962867] iwlwifi 0000:01:00.0: loaded firmware version 17.3216344376.0 op_mode iwlmvm
[   14.971033] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 7260, REV=0x144
[   14.998674] iwlwifi 0000:01:00.0: base HW address: 0c:8b:fd:5a:5a:73
[   22.653913] mt7530 mdio-bus:00 lan0: configuring for phy/gmii link mode
[   22.660900] br-lan: port 1(lan0) entered blocking state
[   22.666349] br-lan: port 1(lan0) entered disabled state
[   22.672102] device lan0 entered promiscuous mode
[   22.677008] device eth0 entered promiscuous mode
[   22.683701] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[   22.695173] mt7530 mdio-bus:00 lan1: configuring for phy/gmii link mode
[   22.702218] br-lan: port 2(lan1) entered blocking state
[   22.707716] br-lan: port 2(lan1) entered disabled state
[   22.713726] device lan1 entered promiscuous mode
[   22.721479] mt7530 mdio-bus:00 lan2: configuring for phy/gmii link mode
[   22.728728] br-lan: port 3(lan2) entered blocking state
[   22.734109] br-lan: port 3(lan2) entered disabled state
[   22.740309] device lan2 entered promiscuous mode
[   22.747962] mt7530 mdio-bus:00 lan3: configuring for phy/gmii link mode
[   22.755158] br-lan: port 4(lan3) entered blocking state
[   22.760552] br-lan: port 4(lan3) entered disabled state
[   22.766994] device lan3 entered promiscuous mode
[   22.776829] mt7530 mdio-bus:00 wan: configuring for phy/gmii link mode
[   22.783462] IPv6: ADDRCONF(NETDEV_UP): wan: link is not ready
[   22.924012] jffs2_scan_eraseblock(): End of filesystem marker found at 0x0
[   22.932170] jffs2_build_filesystem(): unlocking the mtd device...
[   22.932175] done.
[   22.940290] jffs2_build_filesystem(): erasing all blocks after the end marker...
[   32.473926] vusb: disabling
[   32.484158] vmc: disabling
[   32.486867] vmch: disabling
[   32.489643] vgp1: disabling
[   32.492434] vcamaf: disabling
