HOSTAPD doesn't work on bootup, only when signed in
I’m following this guide: https://pimylifeup.com/raspberry-pi-wireless-access-point
As long as I’m logged in, everything works fine - but when I reboot, instead of hostapd starting, I get an error message:
FAILED Failed to start Advanced IEEE 02.1#802.1X/WPA/WPA2/EAP Authenticator. See ‘systemctl status hostapd.service’ for details.
I can’t check the log because as soon as I log in, hostapd is called and running just fine.
I’ve been using this image: 2020-04-28-raspbian-stretch-bpi-m2z-sd-emmc.img
Anyone got ideas?
Hm. I’m using Raspbian, not Armbian - the raspi-config doesn’t have that option to create an AP unfortunately. Worth the try, though - thanks.
Maybe I should give Armbian another try - I’ve got spare SD cards.
Armbian is better in just about every way.
