Graceful Router Power Down
{ EDIT: Updated the script to enable PCIe Link Power Management. The NVMe ‘Unsafe Shutdown’ counter no longer increments during a Power Off. }
You have hard drive(s) attached to your router. You’re not sure if just yanking power is going to cause corruption.
smartctl --all /dev/nvme0
SMART/Health Information (NVMe Log 0x02, NSID 0xffffffff)
Critical Warning:                   0x00
Temperature:                        47 Celsius
Available Spare:                    100%
Available Spare Threshold:          10%
Percentage Used:                    0%
Data Units Read:                    1,080,727 [553 GB]
Data Units Written:                 109,464 [56.0 GB]
Host Read Commands:                 4,728,544
Host Write Commands:                618,993
Controller Busy Time:               0
Power Cycles:                       23
Power On Hours:                     16
Unsafe Shutdowns:                   9 <=<=<=<=<=< THIS
Media and Data Integrity Errors:    0
Error Information Log Entries:      0
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Temperature Sensor 1:               47 Celsius
Temperature Sensor 2:               62 Celsius
If you issue:
halt
… or:
poweroff
… the router just reboots.
So let’s set it up for a graceful shutdown.
First, create the shutdown script:
vi /etc/prep-unplug
… press i to enter editing mode, then paste this code in:
#!/bin/sh
echo "Shutting down router... please wait..."
service log stop 2>/dev/null
ip link set eth0 down 2>/dev/null
ip link set eth1 down 2>/dev/null
if [ -d /sys/class/leds ]; then
    for led in /sys/class/leds/*; do
        echo none > "$led/trigger" 2>/dev/null
        echo 0 > "$led/brightness" 2>/dev/null
    done
fi
block umount 2>/dev/null
sync
sleep 5
sync
sleep 5
# Cut power to the software layer first
echo 1 > /sys/bus/pci/devices/0000:01:00.0/remove 2>/dev/null
sync
# Cut physical slot power
echo "auto" > /sys/bus/pci/devices/0000:00:00.0/power/control 2>/dev/null
sleep 2
if [ -f /sys/class/gpio/watchdog-enable/value ]; then
    echo 0 > /sys/class/gpio/watchdog-enable/value 2>/dev/null
fi
sleep 20
echo "When the router LEDs go dark, it is safe to pull the power."
while true; do
    sleep 1
done
Press Esc to exit editing mode, then :wq to save and exit.
Make that file executable:
chmod +x /etc/prep-unplug
That stops the ‘Unsafe Shutdowns’ counter from incrementing, because the NVMe drive is synced and powered down when power to the router is pulled.
Next:
vi /etc/profile
Press i to enter editing mode, then scroll to the bottom of that file and enter:
alias poweroff='/etc/prep-unplug'
Initialize the changes:
source /etc/profile
The above catches terminal commands. If you issue poweroff from the terminal, it’ll run the /etc/prep-unplug script.
But, if you have automated internal tasks or third-party cron scripts calling /sbin/poweroff explicitly, an alias won’t catch that. You can fix this by dropping a symbolic wrapper script higher up in the system path execution priority (/usr/sbin/).
vi /usr/sbin/poweroff
Press i to enter editing mode, then enter:
#!/bin/sh
exec /etc/prep-unplug
Make it executable:
chmod +x /usr/sbin/poweroff
When a service calls poweroff, the system searches /usr/sbin/. The /usr/sbin/poweroff script intercepts the hardware system call, and runs the /etc/prep-unplug script.
Make it all impervious to firmware updates. Under System >> Backup / Flash Firmware >> Configuration tab, add to the list:
/etc/profile
/etc/prep-unplug
/usr/sbin/poweroff
… then click the Save button at bottom.
Ensure the system sees it:
which poweroff
… which should return:
/usr/sbin/poweroff
type poweroff
poweroff is an alias for /etc/prep-unplug
Ok, the above completed, now comes the fun part. Let’s add a button under System >> Reboot to shut down the router gracefully from the LuCI interface.
First, if you don’t already have it, install luci-app-filemanager. It’s very nice. You can browse through the files on the router, and edit them, all in the LuCI interface.
Now, we’re going to go to:
/www/luci-static/resources/view/system/reboot.js
Record the contents of that file in a text editor, so if things go wrong, you can just paste the original code back in, save it, and everything is back to normal.
My original file contents (yours may be different… if so, I recommend knowing javascript so you can pick out where to inject the code to place the Power Off button.
'use strict';'require view';'require rpc';'require ui';'require uci';var callReboot=rpc.declare({object:'system',method:'reboot',expect:{result:0}});return view.extend({load:function(){return uci.changes();},render:function(changes){var body=E([E('h2',_('Reboot')),E('p',{},_('Reboots the operating system of your device'))]);for(var config in(changes||{})){body.appendChild(E('p',{'class':'alert-message warning'},_('Warning: There are unsaved changes that will get lost on reboot!')));break;}
body.appendChild(E('hr'));body.appendChild(E('button',{'class':'cbi-button cbi-button-action important','click':ui.createHandlerFn(this,'handleReboot')},_('Perform reboot')));return body;},handleReboot:function(ev){return callReboot().then(function(res){if(res!=0){L.ui.addNotification(null,E('p',_('The reboot command failed with code %d').format(res)));L.raise('Error','Reboot failed');}
L.ui.showModal(_('Rebooting…'),[E('p',{'class':'spinning'},_('Waiting for device...'))]);window.setTimeout(function(){L.ui.showModal(_('Rebooting…'),[E('p',{'class':'spinning alert-message warning'},_('Device unreachable! Still waiting for device...'))]);},150000);L.ui.awaitReconnect();}).catch(function(e){L.ui.addNotification(null,E('p',e.message))});},handleSaveApply:null,handleSave:null,handleReset:null});
The updated code to place the Power Off button:
'use strict';
'require view';
'require rpc';
'require ui';
'require uci';
'require fs';
var callReboot = rpc.declare({
	object: 'system',
	method: 'reboot',
	expect: { result: 0 }
	load: function() {
	render: function(changes) {
		var body = E([
			E('h2', _('Reboot / Power Off')),
			E('p', {}, _('Reboots or gracefully halts the router operating system.'))
		for (var config in (changes || {})) {
			body.appendChild(E('p', { 'class': 'alert-message warning' }, _('Warning: There are unsaved changes that will get lost.')));
			break;
		body.appendChild(E('button', {
			'class': 'cbi-button cbi-button-action important',
			'style': 'margin-right: 10px;',
			'click': ui.createHandlerFn(this, 'handleReboot')
		}, _('Perform reboot')));
			'class': 'cbi-button cbi-button-reset important',
			'style': 'background-color: #cc0000; color: white;',
			'click': ui.createHandlerFn(this, 'handlePowerOff')
		}, _('Power Off')));
		return body;
	handleReboot: function(ev) {
		return callReboot().then(function(res) {
			if (res != 0) {
				L.ui.addNotification(null, E('p', _('The reboot command failed with code %d').format(res)));
				L.raise('Error', 'Reboot failed');
			L.ui.showModal(_('Rebooting...'), [ E('p', { 'class': 'spinning' }, _('Waiting for device...')) ]);
			window.setTimeout(function() {
				L.ui.showModal(_('Rebooting...'), [ E('p', { 'class': 'spinning alert-message warning' }, _('Device unreachable. Still waiting for device...')) ]);
			}, 150000);
		}).catch(function(e) {
			L.ui.addNotification(null, E('p', e.message))
	// Runs prep-unplug and suppresses the expected network disconnection error
	handlePowerOff: function(ev) {
		L.ui.showModal(_('Shutting Down...'), [
			E('p', {}, _('Please wait...')),
			E('p', { 'class': 'alert-message warning', 'style': 'margin-top: 10px;' }, _('When the router LEDs go dark, power down the router.'))
		// Remove the .catch() notification - the network link is supposed to break
		fs.exec('/etc/prep-unplug');
		return Promise.resolve();
	handleSaveApply: null,
	handleSave: null,
	handleReset: null
Make it impervious to firmware updates: Under System >> Backup / Flash Firmware >> Configuration, enter:
… in the list, and click the ‘Save’ button.
Again, if your original code varies from the above, think twice about applying this change!
There was a change in ATF that caused this behaviour. To undo this change apply:
This commit to ATF
The above takes care of shutdowns, but plain old reboots also trigger the NVMe drive to increment its ‘Unsafe Shutdowns’ counter. Let’s fix that.
Create a new script:
vi /etc/prep-reboot
#!/bin/sh
# Stop system logging and shut down network interfaces
sync
sleep 5
sync
sleep 5
# Cut power to the NVMe software layer first
sync
sleep 2
# /sbin/reboot is a sym-link to busybox
exec /bin/busybox reboot -f
chmod +x /etc/prep-reboot
Next, we issue:
vi /etc/profile
alias reboot='/etc/prep-reboot'
source /etc/profile
The above catches terminal commands. If you issue reboot from the terminal, it’ll run the /etc/prep-reboot script.
vi /usr/sbin/reboot
#!/bin/sh
exec /etc/prep-reboot
Make it executable:
chmod +x /usr/sbin/reboot
When a service calls reboot, the system searches /usr/sbin. The /usr/sbin/reboot script intercepts the hardware system call, and runs the /etc/prep-reboot script.
/etc/profile
(NOTE: If you’ve done the procedure in the first post above (for shutdown), /etc/profile is already in the list.)
/etc/prep-reboot
/usr/sbin/reboot
which reboot
/usr/sbin/reboot
type reboot
reboot is an alias for /etc/prep-reboot
