Hi. I installed the various latest linux images from Banana Pi BPI-M4 Zero | BananaPi Docs on SD. Installed bananapi-config, аs needed. Tried to transfer image to eMMC, transfer/copy process freezes at random moment and won’t resume. Similar actions with images from Bananapi M4 Zero - Armbian normally install Linux on eMMC. But there is another problem - Ethernet does not work. Absent at all.
please see online documents:
I used this guide. It hangs at this stage. The percentage indicator stops at some value and everything does not change anymore.
In my opinion, this is due to a misconfiguration of DT. The kernel description mentions “orangepi” (?!!)Linux/Ubuntu/20240314-Bpi-m4zero_1.0.1_ubuntu24.04_jammy_minimal_linux6.1.31
pi@bpi-m4zero:~$ apt show linux-image-next-sun*
Package: linux-image-next-sun50iw9
Version: 1.0.1
Status: install ok installed
Priority: optional
Section: kernel
Source: linux-6.1.31-sun50iw9
Maintainer: Banana Pi <[email protected]>
Installed-Size: 150 MB
Provides: linux-image, linux-image-orangepi, orangepi-next
Homepage: https://www.kernel.org/
Download-Size: unknown
APT-Manual-Installed: yes
APT-Sources: /var/lib/dpkg/status
Description: Linux kernel, orangepi version 6.1.31-sun50iw9 next
This package contains the Linux kernel, modules and corresponding other
files, version: 6.1.31-sun50iw9.
