DNSmasq statistics
[ EDIT: Updated the Stats tab to include a ‘Restart DNSmasq’ button. ]
[ EDIT: Updated the /www/luci-static/resources/view/network/dns.js script to show 3 decimal places on Cache Hit Rate. ]
You’re a curious person. You want to know how your router is performing. But you don’t want to have to slog through a thousand and one command-line commands with their various inscrutable flags.
Let’s work on that a bit. We’re going to create a sub-tab under Network >> DNS >> Stats which will display the dnsmasq cache statistics.
First, edit the ACL file:
vi /usr/share/rpcd/acl.d/luci-mod-network.json
… press i to enter editing mode, then change this:
        "luci-mod-network-dns": {
                "description": "Grant access to DNS configuration",
                "read": {
                        "ubus": {
                                "luci-rpc": [ "getHostHints" ]
                        "uci": [ "dhcp" ]
                "write": {
                        "uci": [ "dhcp" ]
… to this:
		"read": {
			"ubus": {
				"luci-rpc": [ "getHostHints" ],
				"dnsmasq": [ "metrics" ]
			"uci": [ "dhcp" ]
                "write": {
                    "uci": [ "dhcp" ],
                    "ubus": {
                        "rc": [ "init" ]
… press Esc to exit editing mode, then :wq to save and exit.
Restart the relevant service:
/etc/init.d/rpcd restart
You’ll have to log back in after that service restart.
Now we’re going to edit the file which creates the page at Network >> DNS.
vi /www/luci-static/resources/view/network/dns.js
… press i to enter editing mode.
Look for the following code:
s.tab('ipsets',_('IP Sets'));o=s.taboption('general',form.Value,...
… and inject the Stats tab in there thusly:
s.tab('ipsets',_('IP Sets'));s.tab('stats', _('Stats'));o=s.taboption('general',form.Value,
Now look at the very end of the file for:
return m.render();}});
Line your cursor up at the beginning of that code blurb, and press Enter several times to create some space for our code.
Now we inject our code above that last line, in the blank space you just created:
o = s.taboption('stats', form.DummyValue, '_stats_render');
o.title = _('DNSmasq Statistics');
o.render = function() {
    var container = E('div', { 'id': 'dnsmasq-stats-wrapper', 'style': 'margin-top: 15px;' });
    // Create local memory anchors to track subtracted values
    var offsets = { hits: 0, forwarded: 0, total_inserted: 0, disc: 0, off: 0, req: 0, ack: 0 };
    var getMetrics = L.rpc.declare({
        object: 'dnsmasq',
        method: 'metrics',
        params: []
    var restartService = L.rpc.declare({
        object: 'rc',
        method: 'init',
        params: [ 'name', 'action' ]
    // Extracts live leases
    var getLiveLeases = L.rpc.declare({
        object: 'luci-rpc',
        method: 'getDHCPLeases',
        params: []
    function updateDashboard(res) {
        // Upon reset button push, zero all variables
        var hits = Math.max(0, (res.dns_local_answered || 0) - offsets.hits);
        var forwarded = Math.max(0, (res.dns_queries_forwarded || 0) - offsets.forwarded);
        var total = hits + forwarded;
        var hitRate = total > 0 ? ((hits / total) * 100).toFixed(3) + '%' : '0.000%';
        var inserted = Math.max(0, (res.dns_cache_inserted || 0) - offsets.total_inserted);
        var disc = Math.max(0, (res.dhcp_discover || 0) - offsets.disc);
        var off = Math.max(0, (res.dhcp_offer || 0) - offsets.off);
        var req = Math.max(0, (res.dhcp_request || 0) - offsets.req);
        var ack = Math.max(0, (res.dhcp_ack || 0) - offsets.ack);
        container.innerHTML = '';
        container.appendChild(E('div', { 'class': 'cbi-map-descr' }, _('DNSmasq Statistics')));
        // Create the tables container
        var section = E('div', { 'class': 'cbi-section' }, [
            E('h3', {}, _('DNS Performance Summary')),
            E('div', { 'class': 'table', 'style': 'max-width:550px; margin-bottom:20px;' }, [
                E('div', { 'class': 'tr' }, [E('div', { 'class': 'td font-weight-bold' }, _('Cache Hit Rate')), E('div', { 'class': 'td', 'style': 'font-size:1.4em; color:#22c55e; font-weight:bold;' }, hitRate)]),
                E('div', { 'class': 'tr' }, [E('div', { 'class': 'td' }, _('Cache Hits (Local Answered)')), E('div', { 'class': 'td' }, hits.toString())]),
                E('div', { 'class': 'tr' }, [E('div', { 'class': 'td' }, _('Cache Misses (Forwarded)')), E('div', { 'class': 'td' }, forwarded.toString())]),
                E('div', { 'class': 'tr' }, [E('div', { 'class': 'td' }, _('Total Queries Evaluated')), E('div', { 'class': 'td' }, total.toString())]),
                E('div', { 'class': 'tr' }, [E('div', { 'class': 'td' }, _('Cache Insertions')), E('div', { 'class': 'td' }, inserted.toString())]),
                E('div', { 'class': 'tr' }, [E('div', { 'class': 'td' }, _('Evictions (Forced Live Frees)')), E('div', { 'class': 'td', 'style': res.dns_cache_live_freed > 0 ? 'color:#ef4444; font-weight:bold;' : '' }, (res.dns_cache_live_freed || 0).toString())])
            E('h3', {}, _('DHCP Server Counters')),
                E('div', { 'class': 'tr' }, [E('div', { 'class': 'td' }, _('Active DHCPv4 Leases')), E('div', { 'class': 'td' }, (res.leases_allocated_4 || 0).toString())]),
                E('div', { 'class': 'tr' }, [E('div', { 'class': 'td' }, _('Active DHCPv6 Leases')), E('div', { 'class': 'td' }, (res.leases_allocated_6 || 0).toString())]),
                E('div', { 'class': 'tr' }, [E('div', { 'class': 'td' }, _('DHCP Discovers / Offers')), E('div', { 'class': 'td' }, (res.dhcp_discover || 0) + ' / ' + (res.dhcp_offer || 0))]),
                E('div', { 'class': 'tr' }, [E('div', { 'class': 'td' }, _('DHCP Requests / ACKs')), E('div', { 'class': 'td' }, (res.dhcp_request || 0) + ' / ' + (res.dhcp_ack || 0))])
        // Reset button
        var resetBtn = E('button', {
            'type': 'button',
            'class': 'cbi-button cbi-button-reset',
            'style': 'margin-top: 10px;',
            'click': function() {
                offsets.hits = res.dns_local_answered || 0;
                offsets.forwarded = res.dns_queries_forwarded || 0;
                offsets.total_inserted = res.dns_cache_inserted || 0;
                offsets.disc = res.dhcp_discover || 0;
                offsets.off = res.dhcp_offer || 0;
                offsets.req = res.dhcp_request || 0;
                offsets.ack = res.dhcp_ack || 0;
                updateDashboard(res);
                ui.addNotification(null, E('p', _('DNSmasq statistics display has been reset to zero.')), 'info');
        }, _('Reset Statistics'));
        // Restart button
        var restartBtn = E('button', {
            'type': 'button',
            'class': 'cbi-button cbi-button-action',
            'style': 'margin-top: 10px; margin-left: 10px;',
                restartService('dnsmasq', 'restart').then(function() {
                    ui.addNotification(null, E('p', _('DNSmasq service has been restarted.')), 'info');
                }).catch(function(err) {
                    ui.addNotification(null, E('p', _('Failed to restart DNSmasq: ') + (err.message || 'Unknown Error')), 'error');
        }, _('Restart DNSmasq'));
        // Group both buttons into the same container div
        section.appendChild(E('div', { 'style': 'margin-top: 15px; margin-bottom: 25px;' }, [resetBtn, restartBtn]));
        container.appendChild(section); // Appends the populated container elements into view DOM
    function fetchLiveMetrics() {
        return Promise.all([
            L.resolveDefault(getMetrics(), {}),
            L.resolveDefault(getLiveLeases(), {})
        ]).then(function(results) {
            var res = results[0] || {};
            var leaseObj = results[1] || {};
            var ipv4Leases = Array.isArray(leaseObj.dhcp_leases) ? leaseObj.dhcp_leases : [];
            var ipv6Leases = Array.isArray(leaseObj.dhcp6_leases) ? leaseObj.dhcp6_leases : [];
            res.leases_allocated_4 = ipv4Leases.length;
            res.leases_allocated_6 = ipv6Leases.length;
            return res;
    // Execute initial paint
    fetchLiveMetrics().then(updateDashboard);
    // 5-second polling
    L.Poll.add(function() {
        if (document.getElementById('dnsmasq-stats-wrapper') && container.parentNode && container.parentNode.style.display !== 'none') {
            return fetchLiveMetrics().then(updateDashboard);
    }, 5);
    return container;
Press Esc to exit editing mode, then :wq to save and exit.
Then restart your browser and load that page (you may need to flush your browser cache).
The Reset button doesn’t actually ‘reset’ anything, it just zeroes the values for that session by offsetting the existing values. If you navigate away from that tab, then navigate back to that tab, the original values will display. This is handy for short-term testing of dnsmasq, while preserving the underlying statistics.
Make the changes impervious to firmware updates. Add:
… to System >> Backup / Flash firmware >> Configuration tab, then click the Save button.
If you want a quick-n-dirty code snippet that you can use at the CLI, and which mimics the output of the page we created above:
/bin/sh -c 'eval $(ubus call dnsmasq metrics | jsonfilter -e "[email protected]_local_answered" -e "[email protected]_queries_forwarded"); total=$((hits + miss)); if [ $total -gt 0 ]; then rate=$(awk "BEGIN {printf \"%.2f\", ($hits/$total)*100}"); else rate="0.00"; fi; printf "Cache Hit Rate: %s%%\nHits: %d\nMisses: %d\nTotal: %d\n" "$rate" "$hits" "$miss" "$total"'
… which should return something like:
Cache Hit Rate: 71.16%
Hits: 28773
Misses: 11663
Total: 40436
I’ve got the Custom Commands package, so I dropped it in there. Note that you have to prepend that command with /bin/sh -c to get it to work, because Custom Commands usually runs commands via exec.
The first Custom Command can’t actually be run in Custom Commands (hence the (SSH) tag)… I store it in Custom Commands so I don’t forget it.
