How have you wrote the file to sdcard (unpack)? Are bootswitches right? Bl2 is not found,this is part of the base image built by uboot pipeline
gunzip -c bpi-r64_jammy_6.1.img.gz | sudo dd bs=1M status=progress conv=notrunc,fsync of=/dev/sdb
the mechanical switch on the board is correct, other systems boot from SD
where should the Bl2 be ?
i have this structure
sdb1, sdb2, sdb3 - have no fs
sdb4, sdb5 - have
This is how r64 image is done:
Edit:
Seems the r64_header was not written
dd: failed to open 'r64_header_sdmmc.bin': No such file or directory
Maybe i have missed to add it while moving to newer atf code
Try to flash it to offset 0 of your card
Not sure why pipeline was not failing because of this error
Added missing file and updating build.sh so it should fail if file is missing again (newer atf version)
Thank you Frank, its help me
dd if=r64_header_sdmmc.bin status=progress conv=notrunc,fsync of=/dev/sdb
can i replace the system to emmc, and how do it?
I have not used emmc on r64,but basicly you can compile bl2 and fip for emmc and use the emmc header the same way…on later boards bl2 has to be flashed to boot0 partition and partconf needs to be set correctly (but if you have already vendor image booting from emmc this should be already done)
no, i have not vendor image
can you describe more detail ?
where to get the bl2 and fip ? what to write in partconf ?
and may be it possible to boot from eMMC but root mount from SATA ? or redirect boot from SATA ?
my pipeline does not compile it yet, so you have to do the steps my pipeline does for emmc
so just clone my uboot-repo, switch to desired branch (2024-01-bpi is newest one)
but writing emmc instead of sdmmc into build.conf after switching to atf-branch
buildimage does not work yet, but you can flash sdmmc-image to emmc, write bl2 to boot0 and emmc-header and fip to emmc-user-partition (mmcblkX without pY) to the same positions as the createimg does above
you set partconf in uboot (need to check which dev via mmc dev or mmc list - first number, here 0 - is emmc on r64)
mmc partconf 0 1 1 0
or
mmc partconf 1 1 1 0
edit: have added r64 emmc bl2/fip to pipeline in 2024-01-bpi
when pipeline is ready you should be able to get the files for flashing
make sure you change /etc/fstab to emmc before booting rootfs else it cannot be mounted.
Seems you need to set root for emmc in uEnv.txt,as i only set partition in checksd (on r64 in bananapi/bpi-r64/linux on bpi-boot partition)
And yes you can copy rootfs to sata drive and need to change fstab again and change root-var in uEnv.txt,but first make emmc working ![]()
@Krantic have you emmc booting till uboot or kernel?
Hello Frank
no, i cant
i did this
# dd if=bpi-r64_emmc_bl2.img of=/dev/mmcblk0boot0
# mkfs -t ext4 /dev/mmcblk0
# mount /dev/mmcblk0 /mnt
copy fs
# cp bpi-r64_emmc_fip.bin /mnt/bpi-r64_emmc_fip.bin
# cp r64_header_emmc.bin /mnt/r64_header_emmc.bin
# mmc partconf 0 1 1 0
ERROR: unknown command 'partconf'
# mmc extcsd read /dev/mmcblk0boot0 | grep 'PARTITION_CONFIG'
Boot configuration bytes [PARTITION_CONFIG: 0x01]
and i got
*** U-Boot Boot Menu ***
1. Enter kernel-name to boot from SD/EMMC.
2. Boot kernel from TFTP.
3. Boot from SD/EMMC.
mmc 1:4
U-Boot console
Loading Boot0000 ‘mmc 1:4’ failed
Loading from BootNext failed, falling back to BootOrder
EFI boot manager: Cannot load any image
BPI-R64>
not creating filesystem direct on this device…use the sdmmc image to write to mmcblkX and then replace boot-headers (emmc-header and fip), not copy them to filesystem but flashing to right positions see build.sh in mtk-atf branch above
if mmc-partconf is missing i need to add it in uboot first…
mhm, strange SUPPORT_EMMC_BOOT is set in r64 defconfig, so it should be available
ah, you try it from linux…mmc partconf is uboot command…the mmc excsd needs additional mmc-utils to be installed in linux
wonder why uboot is loaded and it looks like efiboot/bootdefault is triggered instead of my builtin environment
may it be done like this?
dd if=/dev/sdb5 of=/dev/mmcblk0
i have installed utils
# history | grep mmc-
213 apt install mmc-utils
not sure if you can set partconf with mmc-utils, but 0x1 imho is wrong…afair it should be 0x48, but if emmc boots till uboot…mhm, but it does not look like mine…
try booting in uboot from sdcard and run the mmc partconf
please post full output…it looks like emmc was preflashed, but it should be blank on userparttion after you created the filesystem on mmcblk0 directly without partition.
you need at least boot till uboot from emmc and if uboot itself can read sata drive you can boot from it (afair on r64 uboot was able to access sata).
tried to flash from uboot alone:
check order of mmc devices, start and list usb content
BPI-R64> mmc list
mmc@11230000: 0 (eMMC)
mmc@11240000: 1
BPI-R64> usb start
starting USB...
Bus usb@1a0c0000: xhci-mtk usb@1a0c0000: hcd: 0x000000001a0c0000, ippc: 0x000000
xhci-mtk usb@1a0c0000: ports disabled mask: u3p-0x0, u2p-0x0
xhci-mtk usb@1a0c0000: u2p:2, u3p:1
Register 300010f NbrPorts 3
Starting the controller
USB XHCI 0.96
scanning bus usb@1a0c0000 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
BPI-R64>
BPI-R64> ls usb 0:1 r64
512 r64_header_emmc.bin
65597 bpi-r64_emmc_bl2.img
988948 bpi-r64_emmc_fip.bin
3 file(s), 2 dir(s)
switch to boot0 block and write bl2
BPI-R64> mmc partconf 0 1 1 1
BPI-R64> fatload usb 0:1 $loadaddr r64/bpi-r64_emmc_bl2.img
ERROR: reserving fdt memory region failed (addr=0 size=43000000 flags=4)
65597 bytes read in 16 ms (3.9 MiB/s)
BPI-R64> printenv loadaddr
loadaddr=0x44000000
BPI-R64> mmc write ${loadaddr} 0x0 0x400
MMC write: dev # 0, block # 0, count 1024 ... 1024 blocks written: OK
switch to userpart and flash first emmc-header
BPI-R64> mmc partconf 0 1 1 0
BPI-R64> fatload usb 0:1 $loadaddr r64/r64_header_emmc.bin
512 bytes read in 10 ms (49.8 KiB/s)
load and write fip (uboot)
BPI-R64> fatload usb 0:1 $loadaddr r64/bpi-r64_emmc_fip.bin
988948 bytes read in 92 ms (10.3 MiB/s)
BPI-R64> mmc write ${loadaddr} 0x800 ${filesize}
MMC write: dev # 0, block # 2048, count 988948 ... 988948 blocks written: OK
BPI-R64>
bl2 boots up but seems i need fip-partition (so i have to flash image first)
BPI-R64>
F0: 102B 0000
F5: 480A 0031
F5: 480A 0031
F3: 0000 0000
V0: 0000 0000 [0001]
00: 0000 0000
BP: 0400 0041 [0000]
G0: 1190 0000
T0: 0000 02E7 [000F]
Jump to BL
NOTICE: BL2: v2.9(release):44cbe55c6 emmc
NOTICE: BL2: Built : 09:10:57, Feb 1 2024
NOTICE: WDT: Cold boot
NOTICE: WDT: disabled
NOTICE: CPU: MT7622
ERROR: Partition 'fip' not found
ERROR: FIP boot source initialization failed with -2
PANIC at PC : 0x0000000000205318
i try to include emmc in r64 createimg…to not need flash sdmmc first and replace header and fip…so i can test the created image directly
pipeline is running…
BPI-R64> mmc list
mmc@11240000: 1 (SD)
BPI-R64> usb start
starting USB...
Bus usb@1a0c0000: xhci-mtk usb@1a0c0000: hcd: 0x000000001a0c0000, ippc: 0x000000001a0c4700
USB XHCI 0.96
scanning bus usb@1a0c0000 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
you have a usb storage in front-usb-port??
but you can also put the files somewhere else where you can access them from uboot…you can also flash the image from linux to the emmc (/dev/mmcblkX)
lets look how it goes now ![]()
root@bpi-r64:~# cat /proc/partitions
major minor #blocks name
179 0 31166976 mmcblk1
179 1 2048 mmcblk1p1
179 2 512 mmcblk1p2
179 3 512 mmcblk1p3
179 4 102400 mmcblk1p4
179 5 6291456 mmcblk1p5
179 8 7634944 mmcblk0
179 16 4096 mmcblk0boot0
179 24 4096 mmcblk0boot1
8 0 2015232 sda
8 1 460672 sda1
8 2 1553408 sda2
root@bpi-r64:~# mount /dev/sda2 /mnt
root@bpi-r64:~# gunzip -c /mnt/bpi-r64_emmc.img.gz | dd bs=1M status=progress conv=notrunc,fsync of=/dev/mmcblk0
i have put it to the usb (sdb6) but no seen the files
BPI-R64> ls usb 0:0 r64
BPI-R64> ls usb 0:6 r64
BPI-R64> ls usb 0:5 r64
BPI-R64> ls usb 0:4 r64
BPI-R64> ls usb 0:3 r64
BPI-R64>
“r64” in my output is a folder on my usb-stick ![]()
just leave it and you should see files
r64-emmc image works ![]()
F0: 102B 0000
F5: 480A 0031
F5: 480A 0031
F3: 0000 0000
00: 0000 0000
G0: 1190 0000
T0: 0000 0221 [000F]
Jump to BL
NOTICE: WDT: [40000000] Software reset (reboot)
NOTICE: CPU: MT7622
NOTICE: BL2: Booting BL31
NOTICE: BL31: v2.9(release):5ea2352da sdmmc
NOTICE: BL31: Built : 10:22:10, Feb 3 2024
U-Boot 2024.01-bpi (Feb 03 2024 - 10:21:40 +0000)
CPU: MediaTek MT7622
Model: mt7622-bpi-r64
DRAM: 1 GiB
Core: 60 devices, 23 uclasses, devicetree: separate
MMC: mmc@11230000: 0, mmc@11240000: 1
Loading Environment from nowhere... OK
In: serial@11002000
Out: serial@11002000
Err: serial@11002000
Net:
Warning: ethernet@1b100000 (eth0) using random MAC address - 3a:16:32:21:e4:ff
eth0: ethernet@1b100000
Hit any key to stop autoboot: 0
BPI-R64>
for others who try too:
- flash emmc-image from sdcard linux:
gunzip -c /mnt/bpi-r64_emmc.img.gz | dd bs=1M status=progress conv=notrunc,fsync of=/dev/mmcblk0 - boot sdcard-uboot and flash bl2 to boot0 + set boot0 bootable like described here (emmc-header and fip already in the emmc-image so no need to flash again…only for updating uboot fip reflash is needed)
i put in to the root
BPI-R64> ls usb 0:0
3018/
System Volume Information/
434 "5:AB>2K9 4>:C<5=B.txt
4 file(s), 2 dir(s)
BPI-R64> fatload usb 0:0 $loadaddr bpi-r64_emmc_bl2.img
65597 bytes read in 13 ms (4.8 MiB/s)
BPI-R64>
loadaddr=0x44000000
BPI-R64>
and i have the error during boot
fit=bpi-r64.itb
5763796 bytes read in 1000 ms (5.5 MiB/s)
not boot, at all (
neither from the flash neither from emm
F0: 102B 0000
F5: 4801 0000
F5: 480A 0031
F3: 4002 0000
F2: 300C 0000
00: 1005 0000
F5: 480A 0031
F5: 480A 0031
F3: 4002 0000
F2: 300C 0000
01: 102A 0001
02: 1005 0000
BP: 0000 00C0 [0001]
T0: 0000 0379 [000F]
System halt!
bootrom does not find your bl2…so either partconf is wrong or bl2 is missing
try booting uboot from sdmmc and then do the bl2-steps till the second mmc partconf
loadaddr=0x44000000
does not booted from SD
have you written bl2 to sdmmc instead of emmc?
