Hello,
just a quick question, is there any way to make SD card image under OSX without using linux/windows virtual machine? The Phoenix Card something doesn’t have official pages (DOH].
Thanks, Regards, Petr Sourek
EDIT: OK, as usual no help from @SinoVoip so if someone is interested…
These instructions sux hard… https://bananapi.gitbooks.io/bpi-m3/content/how_to_burn_android_image_to_emmc.html
If you want to flash it, the manual on the page is almost correct but…
Press and HOLD u-boot button, with the button still pressed, plug the BPI-M3 into computer and still keep holding the u-boot button and start the BPI-M3 the process will start.
The hold button is kind of missing in the manual so I had to find it somewhere else…
And by the way you can use software mentioned here, not some „Google docs“ kind of links http://linux-sunxi.org/LiveSuit
